battery life question | FerrariChat
Discussion in '458 Italia/488/F8' started by HoodyHoo, Aug 27, 2017.
  1. HoodyHoo
    HoodyHoo Rookie
    Jul 5, 2017
    19
    San Diego
    Nathan Thompson
    How long do you guys let your 458 sit without being tethered to the trickle charger? I've noticed if I let mine sit for a week it doesn't start first try of the button and sounds weak on the turnover. Also when it does start second press it's showing electrical system failure see dealer until the next time it gets cycled off/on. I feel like the car should be fine to sit for a week easily, do I have a bad battery?
  2. benny11_85308
    benny11_85308 Karting
    Dec 12, 2016
    139
    I have the same issue. I would love to hear comments on battery life
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  3. twist-a-grip
    twist-a-grip Karting
    Oct 25, 2013
    238
    Is there a reason you're unwilling to plug it in? Tons of posts about finicky Ferrari 458 battery issues on here - it only makes sense to take the extra 30 seconds to plug it in if your car is going to sit for a while.
  4. LCW
    LCW Karting
    Dec 29, 2016
    94
    South Florida
    I always plug mine in as I drive it once a week. Having said that I feel a car in this price range should have a battery and electrical system that lasts longer than a week...
  5. moldynotepad
    moldynotepad Rookie
    Aug 16, 2014
    37
    Los Angeles
    #5 moldynotepad, Aug 27, 2017
    Hi, so the day after my car was delivered, it would not start. I freaked out and called my sales rep, John Levy of Ferrari FL. He told me that these cars need to be plugged in with the Battery Maintainer if not driven in a week--which makes sense because it took around 7 days to be delivered to Los Angeles from Florida. He was doubtful the OEM maintainer would bring the battery back to life; he recommended I buy a battery charger anywhere and just hook it up to the battery directly. But I just left the maintainer plugged in for ~48 hours and now all is good.
    I bought a CTeK Maintainer to replace my Ferrari Maintainer since it scrapes against the cement as a I move it around. The CTeK Maintainer is pretty cool, shows the 8 stages and stuff.
    Now I just keep it plugged in 24/7. I didn't know I essentially bought a Plug-in Hybrid when I bought 458. Har har.
  6. Caeruleus11
    Caeruleus11 F1 World Champ
    11,429
    I plug mine in after I drive it. That's because I know I might forget to plug it in if I leave it sitting there. So far in 4+ years no battery problems. The included tender is from CTek also but the 4.3 is a good unit. I prefer the 7002 as I think it features a little more robust circuitry to resist brownouts and also a more robust battery conditioning program- but Im not certain on that last one. One other thing to note- if your 458 has HELE- the odds are it uses an AGM battery. If your car has an AGM battery, you want to use the snowflake charging mode on CTek.
  7. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    +1. Way too easy to forget, so I just plug it in after every run.
  8. benny11_85308
    Dec 12, 2016
    139
    I am going to do that with mine for now on. Just plugged it in and it was on#2 but quickly went to 3. Going to plug in every night..thanks guys. Image Unavailable, Please Login
  9. spiders
    spiders Formula Junior
    Jun 8, 2012
    474
    #9 spiders, Aug 27, 2017
    I can leave the AGM battery on my 458 off the charger for up to 2 weeks without a low voltage issue. I don't set the alarm or lock the car because it sits in my locked garage. Longer than 2 weeks and I connect my charger.
    I don't use the Ferrari charger anymore, but rather a Bosch charger with an AGM setting. I don't take a chance by leaving the battery on the charger for extended periods of time. When the battery is fully charged, I shut off the charger.
    Replace the battery in these cars every 2 years. The cars are ridiculously dependent on the battery and systems failure is common when an otherwise good battery becomes marginal for the demands of the computers.
  10. benny11_85308
    Dec 12, 2016
    139
    Do you habe to get the battery from Ferrari?
  11. Labman
    Labman F1 Rookie
    3,799
    Long Island, NY
    Steve
    +2
  12. gernothofer@gmx.at
    Jul 24, 2017
    47
    Are there already any aftermarket solutions (for example Byte CTEK) for the original 488 charging device? My original one just broke...
  13. 100badboy100
    100badboy100 Formula Junior
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    If charging is a worry or not convenient, you could always consider installing a Battery Sense monitor from Ctek
    http://www.ctek.com/products/vehicle/ctx-battery-sense
    This way you can check your battery on your mobile phone to give you peace of mind about when to hook it up to the charger etc..
    Regards
    Michael
  14. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    829
    Michigan
    Tony
    I keep my 458 plugged in all the time. I also did this on my 430. The cars are so sensitive to voltage that it makes sense to keep them plugged in. As others have said, it takes no time to plug it in. Also, I am of the onion the batteries should be replaced every 3-4 years.
  15. Oengus
    Oengus F1 World Champ
    mines on a ctek charger all the time when not driving her
  16. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
  17. TheMayor
    104,909
    Vegas baby
    On a brand new battery expect 3 weeks MAX for it to restart after sitting.
    IMO -- ridiculous but that's the way it is.
  18. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,248
    Mel
    #18 Melvok, Aug 28, 2017
    Any charger will do ... it's just a carbattery, not the holy grail.
    Cut off the connector from the broken one and fix it on the "new" one (the white connector).
    A simple 5 Aps digital charger will not cost you over $30 imo ...
    And yes, I keep my car always on this charger ... :D Never ever encouter any starting issues !
  19. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Keep mine plugged in almost all the time. And use a surge protector as an abundance of caution.
  20. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    I always kept my 458 on the charger not knowing exactly when I was going to drive it again. I'm planning on doing the same for my ordered 488.
  21. stretchgeneral
    stretchgeneral Formula 3
    1,416
    MA/TX
    McK
    I always plug it in when I get it home. It is a habit. I have never had an issue.
  22. Melvok
    Jul 25, 2008
    14,248
    Mel
    NO !
    Any good 74 Amps battery of right formar and poles in right place will do for around $ 100 or so.
  23. obbob
    obbob Formula Junior
    774
    Has anyone had any issue with the battery going flat overnight with a hardwired dashcam?
    I plan on installing the dashcam with a Power Management system that will turn the camera off once it detects the battery is below a certain voltage, but I am worried that since Ferrari batteries seem to drain so quickly, I will end up with a dead battery from just 1-2 nights of sitting.
  24. Melvok
    Jul 25, 2008
    14,248
    Mel
    Should be possible imo ... try it :)
  25. FerrariPaula
    FerrariPaula Karting
    Nov 26, 2016
    135
    Redmond, WA USA
    I drive my 458 on average twice a week (rarely more than 5-6 days pass between starts), never plug in trickle charger, never failed to start the first time. But now I'm curious and will check how old my battery is (I've owned the car about 10 months now).
