Battery life | FerrariChat
Battery life
Discussion in '456/550/575' started by No Quarter, Jul 9, 2025.
  1. No Quarter
    No Quarter Karting
    Dec 29, 2016
    102
    Denmark
    Michael
    I'm just back from a 10 day non-Ferrari vacation, and the 456 was just locked, and now battery is flat. Is it normal it eats so much juice standing still, or time for battery? Do you guys use the cut out every time it's stationary for a few days?
  2. Mirek
    Mirek Formula 3
    1,495
    Los Angeles, CA
    Mirek
    I do not keep mine on a tender or cut it out but I do drive it every other day or so. I recently let it sit for 11 days whilst on vacation and it started right up upon return. Just one datapoint.
    I had all sorts of screwy and related things happen when my alternator(s) were on the way out.
    No Quarter likes this.
  3. No Quarter
    No Quarter Karting
    Dec 29, 2016
    102
    Denmark
    Michael
    It got 4 green lights on a CTEK in 1½ hours. Started it, had a good 1 hour drive. Coming home, idling, voltmeter shows 14.1, so I think alternator is fine. Engine off, voltmeter showed 12.9. I'll keep an eye on it for a few days...
    Mirek likes this.
  4. Bluebottle
    Bluebottle F1 Veteran
    8,534
    Newbury, Berkshire, England
    I used to have the same issue with my 550. If you can't keep it connected to a battery tender, then keep one of these (or similar) in the boot and top it up every 3 months.
  5. ixlr8
    ixlr8 Formula Junior
    Aug 24, 2015
    355
    Eastern Shore- Virginia
    Jim
    I can go about 2 months without starting my 550 before the battery says no go. I put a battery tender on it every few weeks to keep it topped off so it is always ready to go. My first reaction is that if your battery is a no go after 2 weeks, then I suspect it is time to replace it. How old is the battery?
  6. tazandjan
    39,195
    Never give a battery a second chance is a good rule. Still might be worthwhile doing a test to see if she is leaking over about 40 ma. Procedure is in the WSMs. Mine typically last about 7 years and are never on a tender.
  7. No Quarter
    No Quarter Karting
    Dec 29, 2016
    102
    Denmark
    Michael
  8. tazandjan
    39,195
    That is a heat shield to keep engine heat away from the battery. Not sure what the plug is.
  9. No Quarter
    No Quarter Karting
    Dec 29, 2016
    102
    Denmark
    Michael
    The plug that I thought was OEM is for CTEK with Ctek 56-263
  10. tazandjan
    39,195
    None of the early 65° V12s (456-575 and some early 612s) came from the factory with a CTEK charger. There was an optional Zivan charger with connector.
  11. TwoMinds
    TwoMinds Karting
    96
    London
    Colin C
  12. chris_columbia
    chris_columbia Formula Junior
    868
    Columbia MD
    Chris
    456 is a pain to deactivate the battery because of the doors. If I know it will sit, I put both windows down slightly before disconnecting battery. Otherwise, the window seals get damaged. What radio do you have? If aftermarket check it's drain. Very easy to check car electrical drain if you put an amp meter between battery terminal and post.
  13. Aerosurfer
    Aerosurfer Formula 3
    1,888
    Indianapolis
    Nick
    Just open both doors before you turn off the battery then good to go
  14. JohnnyRay
    JohnnyRay F1 Rookie
    3,626
    Central FL/NW WI
    12.6V is a normal "float" voltage for a conventional lead-acid battery...
