Battery Maintainer | FerrariChat
Battery Maintainer
Discussion in '458 Italia/488/F8' started by sprinter, Oct 31, 2017.
  1. sprinter
    sprinter Rookie
    Feb 13, 2014
    17
    Cincinnati, ohio
    David J. Hall
    I recently bought a 2013 458 Spider. I hooked up the battery maintainer but it doesn't seem to be charging. Now my battery is dead. Am I doing something wrong?
  2. F485
    F485 Karting
    Oct 23, 2017
    173
    Abu Dhabi, UAE
    Fahad F458
    check with dealer
  3. RayJohns
    RayJohns F1 Veteran
    7,926
    West Coast
    Ray
    Keep in mind that the tender isn't a battery charger. How long did you leave it attached? When you attached it, did the car's screen show a picture notifying you that it sees the tender?
    If you have a voltage member, you might try taking a reading of the electrical system. This can be done directly off the battery posts or via the cigarette lighter in the console (with the ignition on). Just be careful not to blow a fuse
    If the car turns on, flip the left hand display over to the voltage screen and see where your voltage meter on the dash is reading.
    Ray
  4. junc
    junc Formula Junior
    501
    Chicago/Laguna Beach
    Jun
    The battery maintainer might be bad. I had that happen on two 458 variants. When you say it didn't seem to be charging what are you basing that off of? If the charging lights on the maintainer aren't coming on and all you see is one malfunction light then it needs to be replaced.
    F485 likes this.
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    No, the battery is dead ... a tender can never repair or load that.
    Read the many threads here please !
  6. junc
    junc Formula Junior
    501
    Jun
    Yes the battery is dead. The maintainer will not charge a dead battery. I'm referring to what may have caused the battery to have died when the maintainer was hooked up.
  7. Melvok
    Jul 25, 2008
    14,268
    Mel
    Even hooked up ... the battery of a 458 has no more life than 2-3 years imo ...
  8. junc
    junc Formula Junior
    501
    Jun
    I agree with you that the battery doesnt last that long. Could definitely be age related.
  9. Melvok
    Jul 25, 2008
    14,268
    Mel
    The electrical system of the 458 (at least) has Gremlins .... :D
  10. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,281
    i thought the ferrari chargers were notoriously unreliable
  11. Aeroengineman
    Aeroengineman Formula Junior
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    I'm beginning to think the Ferrari 458 OEM battery is getting a bad reputation created by the crappy charger they provide. I had a couple of electrical system failure notices which I learned were battery issues. So I changed the battery to an O'Reilly Auto Parts exact replacement for $183 and six months later I got one of those messages again. I noticed when I let the car sit for a week the voltages were very low, then I went on a 6 day 1500 mile drive and all the voltages returned to normal and the screens loaded quickly and it started quickly. I then had confirmation it was the stupid OEM "conditioner" that was creating the problem. BTW when I replaced the 458 battery, I put it in my GMC Sierra pickup (daily driver) a year and a half ago and no problems starting my truck. I'm currently using the CTEK MXS 5.0 with a Ferrari adapter I bought on Ebay.
    A friend of mine with a 2012 458 said he was having slow to start problems. His battery is 7 years old. I had him drive his car a half hour a day for 7 days without using the conditioner at night. His battery was fine and his car started right away. I told him to stop hooking up the Ferrari Conditioner and go get the CTEK MXS 5.0 which he did and everything is fine now.
    Based on this, I think everybody should shelve the Ferrari Conditioner and get the CTEK MXS 5.0 and not worry about their batteries failing.
    Caeruleus11 and gzachary like this.
  12. BlueIn2Red
    BlueIn2Red Karting
    Sep 29, 2006
    234
    Tring, UK
    How does that plug into the 458 conditioner socket though? Or do you mean connect it directly to the battery?
  13. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Interesting theory but isn’t the Ferrari Conditioner made by CTEK?
    Caeruleus11 likes this.
  14. boogie
    boogie Karting
    Mar 4, 2016
    192
    Boston
    Keith
    Buy a converter: https://www.ebay.com/itm/Ferrari-Battery-Charger-Tender-Adapter-for-CTEK-360-F430-458-California-599-612-/192316637726
    It is, but the charge current capability is smaller for the Ferrari charger than the MXS 5.0.
    I've never had a problem with my battery, which is what was in the car 5 years ago when I bought it. But I never lock the car in the garage.
    I suspect the residual draw from the car's electronics when the alarm is on is greater than the capacity of the Ferrari charger, so batteries systematically go dead. This is fixed by either reducing the car's residual draw by not locking the car or getting a higher capacity charger.
    Simple as that.
    Need4Spd likes this.
  15. Caeruleus11
    Caeruleus11 F1 World Champ
    11,621
    I prefer the Ctek 7002- not a problem for me in nearly 12 years of use on many different cars.
  16. Aeroengineman
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    Yes the Ferrari Conditioner is made by CTEK but it fails to do the Job and has no readouts Like the CTEK MXS 5.0 - Put the Ferrari One in the bag it came in and put it in your trunk for the next Concours event for show only.
    Solid State likes this.
