Battery maintainer | FerrariChat
Battery maintainer
Discussion in 'California(Portofino)/Roma(Amalfi)' started by richierichcal30, Feb 28, 2025.
  1. richierichcal30
    richierichcal30 Rookie
    Feb 5, 2025
    24
    Rich White
    Hi
    Took delivery of my cali 30 today and love it …quite a cold night forecast here so was going to hook it up to the battery pack via the terminal in the boot
    Do I just plug in and switch on ? Anything else to be aware of ?
    Also if I put the boot lid down what do I do about the cable poking out ? Or do I just rest the boot lid on the cable ?
    Thanks in advance for your help
  2. Zarakoff
    Zarakoff Karting
    Jul 8, 2020
    180
    Uk
    Ian Curley
    I open the boot with cable attached
    Yes plug in and switch on and connect the magnet
    Starts red then amber then green
    I put mine in a waterproof box as I’m not sure if the unit is waterproof ?
    Mines outside but I connect it immediately when I get home .
    richierichcal30 likes this.
  3. Redneck Slim
    Redneck Slim Formula 3 Rossa Subscribed Silver Subscribed
    Mar 10, 2011
    1,664
    Palo Alto,CA,USA
    Walt Kimball
    It sounds like your car is too early to have the magnetic plug by the rear license plate. Connect the tender to the car first then plug it in. Check your Owner's Manual for details. If you don't have a manual, get one; it is filled with information that you will need.
  4. richierichcal30
    Feb 5, 2025
    24
    Rich White
    im just wondering how I close the boot lid with the cable still attached ?
  5. richierichcal30
    Feb 5, 2025
    24
    Rich White
    thanks for the reply …all I have found so far is a reference guide but no manual
    At this point I’m just wondering how I close the boot lid with the cable still attached as my connector is inside the boot
  6. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
  7. Willl
    Willl Karting
    Oct 8, 2022
    153
    Vancouver, WA
    Will
    I leave the trunk lid resting at a almost closed position.
    The trunk light will time out. You won't be able to start the car with the charger plugged in.
  8. richierichcal30
    Feb 5, 2025
    24
    Rich White
    hi
    Thanks for the reply
    I assume you cannot lock the car either with the trunk in this position ?
  9. AandSC
    AandSC Formula Junior Silver Subscribed
    Dec 12, 2016
    959
    Jax, FL
    Allen
    The owner’s manual says to run the cord out the bottom right corner of the boot. That’s where I ran mine, always closed the boot lid and had no issues.
    Willl likes this.
  10. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    I do the same. We live in a 110 year old house and I do not trust our garage to not leak, so I put the charging unit in a waterproof box.
    On the other end, I plug the battery conditioner into a surge protector, which is then plugged into the house electric.
    T
