Battery Question | FerrariChat
Battery Question
Discussion in 'Porsche' started by CMartin348, May 2, 2011.
  1. CMartin348
    CMartin348 Formula 3
    Mar 18, 2008
    1,983
    Minneapolis, MN
    Casey
    So I left the keys in the 997 overnight and now the battery is dead. Eventually got into the trunk and now I have access to the battery. I've tried charging it and starting it and it's just not working. How long should I leave the battery charging thing on there?
    Do I just need a whole new battery?
    Casey
  2. GuyIncognito
    99,950
    how old is the car?
    you may need a new battery.
    FYI be careful hooking it up, I fried the ECU on my old 997 doing that...
  3. clickclickboom
    clickclickboom Karting
    Dec 30, 2009
    66
    PA
    Terry
    In case you need a battery. Interstate mtp-h7. Fits perfect.
  4. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    You left da keys in da kar overnight! You left da keys in da kar overnight!
    You do not deserve to own a Porsche! You must surrender your kar immediately!
    Dale
  5. CMartin348
    Mar 18, 2008
    1,983
    Minneapolis, MN
    Casey
    It's an '09 so 2 years!
    We jumped it and I took it for a 30 mile drive, got gas and it started up just fine again. We'll see if it starts in the morning.
    Thanks! :)
    Hahahahaha... :) it was an accident? :eek:
  6. jonathanp
    jonathanp Formula Junior
    Oct 31, 2003
    687
    Dallas, TX
    Jonathan Peck
    If it is an OEM Porsche battery, you probably cooked it.
    On a second note, if you DO decide to leave your keys in the ignition again, pull the key out until the lock cylinder clicks and then slide it back in. That turns all the computers off in the car and won't drain the battery. The computers won't turn back on until the key is turned to the run position again.
    It will take a good 5-6 hours to charge enough to start if the battery has any life left in it at all.
    Hope that helps.
    Jonathan @ RAC
