Battery Questions in Testarossa | FerrariChat
Discussion in 'Boxers/TR/M' started by LW RedTR, May 19, 2006.
  1. LW RedTR
    LW RedTR Karting
    Jan 12, 2006
    173
    California
    My 88 Testarossa had a new Interstate Megatron 75 put in in 2004. The battery still takes a charge, but if I don't drive the car a distance in about two days, the battery drains down to nothing. It seems that the battery is a good quality, and while I didn't own the car until January, this seems like too short a life for a battery.
    I took it out, put in an Exide Optimal 84 with the newer rolled cores yesterday evening and then put the Interstate on a battery charger. Within 5 hours it was showing as charged.
    This makes me think that there is something about my Testarossa, or Testarossas in general that discharges a battery within three days of non-use. Anybody here have any experience with this?
  2. SFchallenge
    SFchallenge F1 World Champ
    Jun 28, 2004
    11,945
    Sgp, KL, HK & London
    Jon Wijaya
    Maybe there's a leak somewhere in the electrical system? Got to send it to someone familiar in this to trace the wirings/fusebox. If not there's a switch up front, near the battery to turn it off if you don't use it. Sometimes a new earth cable helps.
  3. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    i don't think it's normal. my TR sometimes is not driven for 3 or 4 days in a row, and the battery is fine. my guess is an electrical problem somewhere causing a drain. or the alternator not recharging it well enough.
    john
  4. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Definitely not normal. I can go for weeks without having a problem.
  5. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Sounds more like alternator trouble, I had a similar problem and found it was the wires connected to the alternator.
    There are 2 wires that fit in a white separator plug, take off the plug and take out the wires remembering which position they were in (plug only goes in one way) and clean them thoroughly put them back carefully and try again. It worked for me, failing that it could be the alternator itself which can be cheaply refurbished. Oddly enough my battery was also shot to hell and I bought a new one with more cranking power and everythings great now :D
    **You can also turn off the battery when you leave the car in the garage if you want to there is a black switch just near the battery on the side of the wheel arch!
  6. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,602
    Pacific NW
    Anthony C.
    Isn't the ability of a battery to be charged different from the ability to hold it's charge? I know that when a battery has been drained a few times, it can start to lose its capacity and thus its ability to hold the charges. I would probably unhook the Interstate battery from the power source and check again in 2-3 days to see if it still has power in it before heading down the alternator road, as that road can be pretty expensive. Also, are you still experiencing the same problem with the new Exide battery? If not, then it is not the alternator but the Interstate battery that is the problem. You can also just take your car to any auto supply store or Sears to have them check your alternator/charging system to see if they are functioning properly.
  7. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    True best to get battery and alternator checked first but if it does turn out to be alternator it doesn't have to be expensive they can be reconditioned fairly cheaply. He never mentioned if the battery light was staying on while the car is running as mine was???
  8. LW RedTR
    LW RedTR Karting
    Jan 12, 2006
    173
    California
    The battery light is not staying on while the car is running.
    I took it out today, and upon return hooked up the new Exide battery to my charger, and it immediately went into "charge" mode. In the meantime, yesterday and today, I put the charger on the Interstate Battery while it was outside of the car, and it took a charge up to storage.
    I'm starting to think that I'm not recharging after cold crank start up, and that I should check the wires on the alternator, or the alternator. The engine is running as smooth as silk, and everything else is PERFECT, so I hate to start messing around, but I'm concerned that if the battery isn't recharging, I may end up with a dead battery out on the road somewhere (although now that I know my Interstate is still good, I suppose I could take it with me as a back up, but it is a pain changing out a battery in the dark..)
  9. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    If the battery lights not on then it doesn't point to the alternator, if I was you I'd whip it down to your nearest auto electrician and he'll soon tell you if your batteries ****ed
  10. Magnum6464
    Magnum6464 Formula Junior
    Mar 5, 2006
    319
    Quebexico, Canada
    Mario
    In my 16 years of experience playing with electrical problems…here is what I would do. First turn everything on and check to see if the voltage gauge goes way down or if a warning light goes on. Then check all connectors to the alternator and battery, remove one at a time, clean, add electrical Dielectric Grease contact. Also most regular priced after market radios do this after a few years when not used all the time. It could also be if you have an alarm system that is going bad…what you need to do it plug a multi-meter to the battery and check for amp draw. You can also unplug the radio and alarm if you are handy enough to do it. Then check a week later to see if you found your problem.
    An alternator either works or doesn’t. plug your multi-meter to it and check how much voltage comes out, should be about 14.4V anything lower, It’s not charging your battery very good. An alternator give out about 18-19V, the internal regulator provides the right amount coming out, 14 or so. If your regulator doesn’t work it will let all the voltage through. A regulator is like a river damn, it either controls the flow or lets everything go through and then your battery overcharges, it boils, then the sulfuric acid evaporates and the reason you have to fill it distilled water.
    Now if your voltage is too low, when you drive you need to drive for at least an hour to recharge the drain done to the battery when starting it. A good battery should have at least 600 CCA. A battery has a virtual memory of some sorts, if it only gets charged to 50% all the time (like when driving) it will only recharge at that level even if your charger says its full cap.
