Battery recommendations in the U.S.? | FerrariChat
Discussion in '308/328' started by Imperial Stormtrooper, Mar 4, 2016.
  1. Imperial Stormtrooper
    May 7, 2014
    148
    Far, Far Away
    George
    Hey,
    My battery is about 7 years old, and the only thing keeping it alive is the battery tender, so it's time to replace. I found battery recommendations on this site from 2006, so I figured I'd just ask- any recommendations for batteries sold state side? It looks like it's gotta be a size 34R?
    Appreciate the advice!
    George
  2. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Sears still sells a DieHard battery in this configuration. I've been meaning to pick one up.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    I recommend Interstate battery as mine lasted nine years and being maintained by Battery Tender.
    Costco now sells Interstate battery.
  4. Ron328
    Ron328 F1 Rookie
    2,630
    Willamette Valley, Oregon
    Ron
    #4 Ron328, Mar 4, 2016
    Just don't buy Optima. I've had 4 (red tops) die within 2 years. Unacceptable. Just installed Sears Diehard AGM 34R in my 360.
  5. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    +1 on Interstate. My FCar does not have one now but two of my other cars do and they have been great. I will buy an Interstate for the 308 when I next need a battery. No issues at all even after sitting for a while. Reasonable price as compared to an Optima.
  6. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,092
    Wellington, FL
    Duane
    I got mine at Costco.
  7. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    this... I bought my last Interstate at Costco as well. no problems. If you dont use a maintainer and leave the car undriven during the winter.... you might consider a deep cycle. It's just a bit more protection from battery damage if it gets low on charge.
  8. Rosso328
    Rosso328 F1 Veteran
    7,362
    Central FL
    Paul
    My local dealer recommends regular old Interstate.
  9. BigTex
    79,407
    Houston, Texas
    Bubba
    Yes, 24R (Reverse post), the only one Batteries Plus had, was a red Optima.
    They had a huge bad run, years ago, but that's what I dropped in there...
  10. BigTex
    79,407
    Houston, Texas
    Bubba
    Recently??
  11. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    I'm on my second Interstate and have no complaints at all.
  12. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    Interstate. I had one in my 328 from May 1994 to May 2014. No kidding, it lasted 20 years! I replaced it with another.
  13. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Had two red top Optimas go bad within two years. Stay away.
  14. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    I hate redtop
    Interstate ftw
  15. miketuason
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Wow! That's got to be the record.
  16. Jdubbya
    Jdubbya The $10 Trillion Man
    43,786
    Hell's waiting room
    Mine had an Interstate in it when I bought it and that's what I replaced it with about 10 years later.
  17. EP328
    EP328 Formula Junior
    622
    Northern California
    Ed
    Interstate
  18. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
    #18 jmaienza, Mar 5, 2016
    Does any one have a set of these battery cover nut clips for sale? They attach to the bottom of the battery cover nuts, much like a c clip.
  19. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    Odyssey battery, just make sure if you use a tender it's the right one that will handle AGM
    Sent from my SPH-L720 using Tapatalk
  20. Ron328
    Ron328 F1 Rookie
    2,630
    Ron
    Optima red top installed in my 360 July 2014, died last month (Feb '16) while hooked to a Ctek charger.
    Prior to this, 3 Red Tops replaced under warranty in my ex-328 within 2 years. One didn't even last a year.
    (Sure, I get a new battery everytime for "free," but this is not how I want things to go.)
    My first Optima bought circa 2005 lasted almost 5 years (that was good).
    I drive my car all year round.
  21. BNSC100
    BNSC100 Karting
    May 28, 2009
    127
    SC
    Michael
    Im needing to replace battery and I currently have an interstate 34R... Lead flooded.... For mounting, it has the scalloped / concave indentions that seem to fit the mounting bracket of my 1986 328 very well.... It seems that interstate no longer makes the 34R with the same "concave" mounting notches, but with outward flanges... Not tried to mount anything different and wonder if it will fasten and be as secure as the older design...
    I see lot's of people commenting on many different batteries. Three years ago, this was the only maker I could find that had the curved notches.. Am I the only one worry about this..? Apparently it must not be an issue of anyone? Maybe it's in my head, as I feel someone would have mentioned already....?
