Battery Replacement Northern NJ | FerrariChat
Discussion in '360/430' started by Jeffs360spider, Dec 16, 2014.
  1. Jeffs360spider
    Jun 25, 2014
    35
    Northern New Jersey
    Jeff S
    I am a new 360 owner... purchased over the summer. I recently purchased a new Odyssey battery. I would like to bring the battery and CTEK eyelets to a local installer to have it installed. Does anyone recommend a shop in Morris County NJ or close by? Are there things to be concerned about when replacing a battery?
  2. acmw
    acmw Formula Junior
    Apr 28, 2006
    575
    Nj
    Alex
    do it your self , not hard at all should take 10 min max. literally.
  3. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    Gotta pull the carpet back and put the eyelets on there, it's not a hard job but you have to sorta reach in there through the passenger floorboard.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Make sure you have the radio code (if stock) and wait a little while for relearn when turning on (threads here or in the owners handbook)
  5. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Disconnect ground first to avoid sparks. Not a hard job. If you've got the money then let someone else do it.
    Alan
  6. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,479
    Broadway pert in Passaic if close to you
  7. shmluisfc
    shmluisfc Karting
    May 31, 2012
    199
    I just bumped into this. :) I am the owner of Broadway Performance. Thanks for the recommendation Shark.
    To the OP, congrats on your 360! I will install your battery and Ctek eyelids free of charge. :) I can also read your clutch life/plug in your diag port and do a minor check up free of charge of you'd like. PM me anytime.
  8. sunir
    Oct 30, 2014
    758
    MD
    Sunir
    ^^^ now that's a great way to start with a service provider...Broadway putting best foot forward in good faith.
  9. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Jeff, come over my house one weekend and I will help you. Seriously.
    Dan
  10. Jeffs360spider
    Jun 25, 2014
    35
    Northern New Jersey
    Jeff S
    Wow... I am so impressed by the offers. I wish I had seen them yesterday. I just had the work done at Powertech in Rockaway NJ today. I bought the Odyssey 34R-PC1500T battery that was listed as the proper battery for the 360 but it did not fit in the OEM bracket. I have seen a number of people list this battery as the correct battery and it is also the batter listed on the Odyssey website but this battery was too tall. Powertech had to fabricate a bracket to make the fit work. Its all done now and everything fit fine but I didn't expect there to be this type of problem. On a separate note, I am having an issue with the trip odometer / odometer. The display will only show the trip odometer and the button will not switch to the actual odometer. This problem occurred the other day when my battery was almost dead and barely started the car. Even with a new battery, the toggle between the two will not work. I have read about this problem previously but I do not know if anyone has a solution. Please help. Dan, I see that you live in Seattle... I think that's a bit far from NJ but I do appreciate the offer of getting to know other Ferrari owners. Shmluisfc... where are you located?
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #11 whatheheck, Dec 20, 2014
    Hi Jeff,
    Yes, I didnt realize you are in east coast so yes its quite a drive LOL!
    If you are nearby come on over and I will help you.
    Interesting that they claim your 360 battery bracket wont fit the optima 34R as mine fits perfect and I too have a 360. Photo below.
    Oh well its all done and looks like you are happy so that is all that matters.
    Take care and drive safely!
    Dan
