Battery replacement on 430 | FerrariChat
Discussion in '360/430' started by tonyl8281, Nov 6, 2017.
  1. tonyl8281
    tonyl8281 Karting
    Jul 1, 2014
    102
    Hi. It looks like I need to replace the battery on my 07 430. Is there anything I should look out for or is different from a ‘normal’ car? Does a YouTube vid exist of someone carrying out this job?
    Thanks for any help
  2. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    Hi Tony. A million threads on this topic. Search feature is your friend. Nothing special required battery wise for your car. I use Interstate. You can change it yourself.
    whatheheck likes this.
  3. Ahmed_Z
    Ahmed_Z Karting
    217
    Washington DC area
    Ahmed
  4. ShadowF430
    ShadowF430 Formula Junior
    Mar 29, 2017
    270
    Portland
    Jason
    Easy to do from what I’ve seen and the vid above. Ive read lots of people use the interstate battery. Interstate MT7-48/H6 from what I’ve researched is the best and is a AGM. Priced around $250
  5. rugby
    rugby Formula Junior
    Apr 10, 2015
    364
    Atlanta
    I don't think I would install the Bosch flooded lead-acid battery used in that video. In cars where the battery is inside the passenger compartment, AGM batteries are a better choice. There is no possibility of an acid spill with an AGM.
    For the same amount of money as the wet-cell Bosch, you can get something like a DieHard Gold AGM dry-cell.
    whatheheck and BlacktopRacing like this.
  6. Corsair66
    Corsair66 Formula Junior
    Mar 14, 2016
    337
    Clermont, FL
    Ken
    I used the Interstate MT7-34R in my F430 and it's been running like a champ for several months. I drive the car 3-4 times per week, so no trickle charger for me.
  7. ShadowF430
    Mar 29, 2017
    270
    Portland
    Jason
    I’ve also been told the mt7-34r is another battery. Mixed reviews about if the 48/h6 will fit ok in the F430 as the 34r is slightly smaller. Might be the 34r to go with as it also has a higher CCA and cranking amps
  8. tonyl8281
    tonyl8281 Karting
    Jul 1, 2014
    102
    Hi guys,
    Thanks so much for your advice and help, really appreciated.
    Tony
  9. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    Hey guys any updates on preferred 430 batteries or is the Interstate MT7-48/H6 still the preferred choice. The trickle from my scud was unplugged and not sure I want to risk a jump. Thinking of either using a bench charge to see if I can charge the battery or just getting a new one.
  10. Flyingbrick242
    Flyingbrick242 Formula Junior
    677
    Northern AZ.
    Recently replaced my battery with interstate MTZ/34R my understanding is this is the latest generation of MT7/34R it worked and installed perfectly..
  11. Flyingbrick242
    677
    Northern AZ.
    Forgot to mention it was for a 2007 F430...Sept build date if that makes any difference..
  12. FazTaz
    FazTaz Karting
    Aug 19, 2004
    107
    Northern NJ
    Great thanks will order that one.
