Battery replacement options?? | FerrariChat
Discussion in '360/430' started by adam, Jan 13, 2008.
  1. adam
    adam Rookie
    Jun 3, 2006
    20
    My '06 430 battery is dead. My fault - I was traveling for a month and it wasn't on the trickle charger. What are my options for a non-oem battery that will actually fit well?
    thanks in advance. (I did search the threads but could not find a specific brand/model recommendation).
  2. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Try the Odessay 925 it requires some alteration to the hold down posts but is a lighter and far superior battery
  3. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    Specifically the Odessey PC925T with terminal posts. See www.odysseybatteries.com
  4. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Thank you for the full spec definition.
  5. MARIOF430
    MARIOF430 Karting
    May 8, 2007
    172
    Portland ,Or.
    Michael
    Why couldn't he use a OPTIMA is the ODESSEY Battery better?
  6. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    The Odyssey is much smaller than the OEM battery, so the retaining bar sits much lower than the short threads on the hooks. Use a stack of washers under the nuts as a thick spacer.
  7. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Yes, Odessey is better but also the Optima won't fit.
  8. lgrf50
    lgrf50 Formula 3
    Jan 18, 2005
    1,257
    you can use, interstate MTP91, must install vent tube.
  9. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Correct
