battery size for 400i ? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by new ulm 400i, Mar 19, 2011.
  1. new ulm 400i
    new ulm 400i Karting
    Sep 1, 2007
    117
    Taipei, Taiwan
    Lee Atkinson
    Guys, what is the biggest battery type to fit a 400i ? I'm using a 400i but it is giving up the wind on difficult starts...Could of course be the starter and I'll check cabling, but in case I need a new battery wan to make sure I get the biggest size that will fit...
    Thanks ! Lee
  2. ulf rickard
    ulf rickard Formula Junior
    Sep 28, 2009
    424
    Sweden
    Ulf Rickard
    measure the space available to go for the biggest one to fit the space, it´s easy
  3. Ak Jim
    Ak Jim F1 Veteran
    9,616
    North Pole AK
    Do you have one of the gear reduction starters?
  4. hoverland
    hoverland Formula Junior
    Aug 14, 2010
    265
    Norway
    Harald Ø
    The 400carb. allows ample space for a 30cm 17cm 22cm (wide/depth/height) which means approx 100Ah -pending model/type of battery.
    Anyway -a fresh battery is not expensive, and never wrong !
  5. full_garage
    full_garage Formula 3
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
    I have one in both of mine- Even with the battery almost flat the car turns over- Great investment...
  6. Steve Magnusson
    26,781
    Don't mean to give you more work, but (properly working) K/KE-Jet should not have any trouble starting cold or warm (and without touching the throttle). Does your difficult-to-start condition occur when cold, warm, or both?
  7. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,225
    MA
    A well charged stock sized battery in good condition should be all that you need to start the car if all of the other systems are working properly.
    Last weekend my 400i started right up after being dormant since mid-December.
    You may well need a new battery, and they are cheap, but it sounds as though there are other issues that you will need to address as well in order to get the easy starting that this car is capable of.
  8. Highmiler
    Highmiler Formula Junior
    Dec 8, 2010
    414
    Missouri
    Greg
    Battery minders are also a great investment especially if you have multiple cars in your garage.
  9. Darren C
    Darren C Formula Junior
    Feb 3, 2011
    308
    Chichester, UK
    Hi,
    I've just changed the battery on mine. The handbook says 84ah, but its really the starting amps that matter. (having said that you need the right ah for the alternator charging) Some 100ah batterys can have a low start amp (say 600a) whereas some 60ah batteries may have 640a starting current.
    After a bit of searching I found a Bosch battery with 85ah and 800a starting...perfect!
    PS The 400i reduction starter...where can I get one?
    Regards
    D
  10. new ulm 400i
    Sep 1, 2007
    117
    Taipei, Taiwan
    Lee Atkinson
    Steve, you are dead on--I'm walking thru the Injection manual to make sure it doesn't need to wind forever to start...One of the auxilary air valves is stuck shut and the thermo switch is bad (doesn't ohm out correctly). I did have to hold down the pedal when cold (to get the pumps on, explained by the broken thermo switch) but my starting/idling problem is likely because of the air valve.
    Until just last week (when the car quite running) the battery seemed to spin the motor forever and the car started OK--both the 400i and my earlier 308 seem to spin the motor quite quickly when starting (and the "high torque" starters have always seemed irrelevant to these small displacement, low compression Ferraris). But my guess is that the aux air valve stuck (suddenly making starting and running a problem), and then I was surprised how quickly the battery seemed to slow. So my focus is really everything but the battery for now, but if I do need to run out for one. The battery in there now is a type 40, it appears that a type 65 is too big.
    Btw, the other maintenance items (pumps, accumulator, filters, and even injectors) were all replaced a year ago. Warmup regulators are original, without buying a pressure gauge and learning I'll still pretend these are OK until the easy picks are used up...Lee
  11. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
  12. Glaverbel911
    Glaverbel911 Karting
    Feb 20, 2010
    79
    Neustadt ADW/Toronto
    R. Groß
    I have an Interstate Battery in my 400,, type MTP-91. works just fine with the stock starter.. its the same identical battery as in my 550.
    Robert
  13. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    I use a battery that NAPA says is for a Mercedes. For starting issues do not look for the high amp hour batteries, look for high Cold Cranking Amps. I think mine is 850 CCA.
    Of course getting the motor to start easily is best.
    Ken
  14. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Group #74..perfect fit.
  15. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    http://www.rtpnet.org/~teaa/bcigroup.html#note2
    Currently, I have a Group 34 in mine:
    Length is 10 1/4" & w/the battery shoved back towards the windshield as far as it will go, there looks to be about 3/4" space between the battery & the small steel angle on the forward side of the battery base pan.
    Width of 6 13/16" fits precisely with respect to the battery hold down bracket @ the base. The windshield motor bracket is another obstacle to the overall width.
    Height of 7 3/4" seems to be about the highest you can fit under the hood (throw a piece of 1" Styrofoam on top of the battery & shut the hood to find the ultimate height--I'd do this myself but mine is over 1000mi. away).
    I'm planning on installing a Group 65 Duracell EHP series next week & it measures 11" long but the above chart shows 12 1/16", best to measure the battery before purchase.
  16. Ashman
    Sep 5, 2002
    33,225
    MA
    #16 Ashman, Mar 24, 2011
    I guess that mine is a group 34 as well, a NAPA Legends 75 with the model number 7534 and 690 CCA rating. No clearance issues.
    Here are the specs from the NAPA website:
    http://www.napaonline.com/Search/Detail.aspx?R=NBR7534_0240740649
    Battery - NAPA Legend 75 Month
    Product Line: NAPA Batteries - Regular
    Part Number: BAT 7534
    Price:
    Availability: This part can only be purchased from your local NAPA Auto Parts store.
    Features & Benefits Maintenance free under normal operating conditions; High tech construction designed to withstand temperature extremes; Premium reserve capacity; Poly handle on popular sizes
    Features and Benefits PDF
    Warranty 75 Months/18 Months Free Replacement
    Warranty PDF
    Attributes Battery Application : Automotive
    Battery BCI # : 34
    Battery CA @ 32 Degrees F : 875
    Battery CCA @ 0 Degrees F : 700
    Battery Height : 7 7/8"
    Battery Length : 10 1/4"
    Battery Load Test Amps : 350
    Battery Posts Type : Top Mount
    Battery Reserve Capacity : 120
    Battery Voltage : 12
    Battery Weight : 37.9
    Battery Width : 6 13/16"
    Measuring State of Charge : Batteries below 12.4v (6.2v for 6 volt batteries) must be recharged before an accurate load test can be performed.
    Physical Inspection : Terminal Inspection: Broken or loose due to abuse, burn marks from shorting, damage from fire, explosion or collision.
    Safety Precautions : Batteries expel explosive gases. Keep sparks, flames, burning cigarettes or other ignition sources away at all times. Always wear safety goggles and face shield when working near batteries. Do not leave a battery on charge for more than 48 hours.
    Wet or Dry : Wet
  17. new ulm 400i
    Sep 1, 2007
    117
    Taipei, Taiwan
    Lee Atkinson
    Thanks a lot, guys ! Lee
