Battery switch on negative cable- replace with solid cable to ground? | FerrariChat
Discussion in '308/328' started by ds190, Sep 2, 2023.
  1. ds190
    ds190 Rookie
    Jul 9, 2012
    30
    Baltimore
    I am hunting around for suspect grounds while trying to figure out my total loss of electrical power when turning key to start position. I pulled that battery switch apart and I notice the female end is cracked slightly. I cleaned the metal contacts; it seems to snap back in soundly. There is not much metal to metal contact with this switch imho.
    Is it common to replace this setup with a solid negative cable to ground? Or order a replacement negative cable to battery switch?
    Thanks for your input.
  2. Ehamilton
    Ehamilton F1 Rookie
    2,638
    Durham, NC; USA
    Eric Hamilton
    I would be frankly amazed if that were the source of your electrical problem, but it's easy enough to test: jumper cable from negative battery post to any solid metal in front, see if the problem goes away.
    If that is the problem, best to replace it with a better quick disconnect instead of a solid wire - you don't want the unfused wires to starter and alternator to be hot when you're working with the alternator belt so the disconnect is very handy.
    Rifledriver likes this.
  3. fatbillybob
    Aug 10, 2002
    29,004
    socal
    On Ferraris my friends and I mostly DIY guys routinely harden as much Ferrari electricals as possible including the kind of electrical cut off you describe. If you feel a need to be able to cut power without unbolting your negative terminal I would use high quality electrical cutoffs we use in boats for marine environment and racecars. Note that many racecar cutoffs have extra terminals and circuitry you don't need because we need to completely cit power so that the engine dies when power cut and not run on alternator power. That's a requirement you do not have as a simple cutoff. So you can buy a racecar 6 terminal cutoff or simple 2 terminal cutoff or use slick relay based cutoffs with a hidden interior switch that can be used as one extra layer of theft deterrence. A thief can get in your car turn key and get nothing like dead battery unless he knows where you unmarked switch is hiding. That unmarked switch can even be keyed for added security.
  4. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    I can understnd this could die.
    i bought two master cutoff made in China, install one, save extra spare. in one nut rotation the internals failed disconnect so must used spare.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Voltage Drop testing can quickly identify/pinpoint any issue with grounds/cables, etc.
    FWIW, if you are not familiar with it, voltage drop testing isn't about checking battery voltage at the battery and then checking to see what the voltage is further down the line. It checks the amount of drop along ONE side of the current path (+ or -) at a time. Unlike testing system voltage, a V drop test can detect faulty cables/connections that show good "voltage" (and would show no/minimal/acceptable resistance on a multimeter) but can't pass sufficient current to do the job. Starter circuits are famous for this behavior. Watch some on-line videos or read descriptions re voltage drop testing.
  6. Rifledriver
    37,100
    Since Ferrari started to use those switches and having been in a couple of Ferraris largest dealers I am aware of one case where one needed replacement.
  7. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Strong Install can destroy it . I did
    The posts are jamb nuts. Take care. I rotated too hard and felt perhaps internals move, then cutoff failed. replaced with 2nd Chinese unit and was very careful not to over tight the jamb nuts, no internal mmove and now works 100%
  8. Rifledriver
    37,100
    You can break anything by mishandling it.. Does not make it a bad part.
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    So true! I have a friend in New York who's opinion is to tighten any fitting to as tight as you can get it and if he happens to have the 1/2" drive socket on the 1/8" bolt, the result is not hard to predict! But he's a superb carrier of heavy items!
  10. sltillim
    sltillim Formula 3
    1,696
    San Diego
    I started my path with my car and having a similar experience. I had multiple issues that caused the drop.
    Dirty and corroded grounds.
    loose battery cables (but they looked tight...)
    The brushes wore down in my alternator - it needed servicing. I did the regulator too...
    At first there was a unconnected wire hiding in my "umbilical chord" between the alternator and the starter
    The plastic base for the terminals on the starter deteriorated and crumbled away, causing a loose connection.
    There are tons of places in the middle it could be....
  11. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I would never recommend solid wire for any electrical connection in a vehicle.
