battery tell tales | FerrariChat
battery tell tales
Discussion in '360/430' started by dodgeboy, May 21, 2012.
  1. dodgeboy
    dodgeboy Karting
    Dec 29, 2005
    116
    Bloomfield
    I am lucky enough to still have my original battery in my F430 from 2005 with no issues to date. Common sense suggest Im near or even past the battery life( 7 years). It does fire up and show no signs of "lack of power" Ill likely order the recommended inter state battery soon, Im just curious waht tell tales did folks see as they near the end or do they just drop out of function.
    THX
  2. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    If it's going to leave you stranded, it will be when your far from home on a sunday evening.............
    Most auto parts stores, or Sears, have a battery tester. It puts a load on the battery & will give you an idea of it's ability to hold a charge & it's overall reserve power.
    That's where I would start. The only hassle is gaining access to the battery posts to have it checked (under the passenger foot rest)
  3. Jeffg11
    Jeffg11 Formula Junior
    May 31, 2004
    567
    Michigan
    Jeff Grabowski
    #3 Jeffg11, May 21, 2012
    Mike,
    I replaced an Interstate with an Odyssey. It dropped right in the car. I would notice a battery light during the crank cycle. When my car was inspected before purchase Penske/Wynn tested the battery and noted that it should be replaced.
    Jeff
    ODYSSEY MODEL 34R-PC1500T
    Pulse (5-second) Hot Cranking Amps (PHCA) 34R-PC1500T
    Cold Cranking Amps (CCA) 850
    20Hr Nominal Capacity (Ah) 68
    Reserve Capacity Minutes 135
    Dimensions
    L x W x H - Inches 10.85 x 6.76 x 7.82
    Metric Dimensions
    L x W x H - mm 275.6 x 171.7 x 198.6
    Weight (lbs) 49.5
    Weight (kg) 22.4
    Application Notes
  4. vegas
    vegas Formula Junior
    Nov 22, 2009
    294
    Australia
    I just replaced the battery in my (360) as it totally died one cold morning - as is often the case. I didn't really notice any tell tales signs - probably because it slowly deteriorated over time. But when i put the new one in there was a big difference - it cranked faster, fired up quicker and seemed to idle better when cold.
    So you may not notice signs of it approaching total failure as it may be progressive as was the case with mine. I'd get it tested, but when in doubt, get it changed, the electronics in these cars are far too fickle to play around with potential for sharp voltage swings etc.
  5. SnowmanUK
    SnowmanUK Karting
    Dec 11, 2010
    174
    London, UK
    If the battery is weak and you don't use the car for while it will not have enough power to start the car. On the other hand it may have just enough power to turn the engine slowly, but in either case the dash lights will pulse and the voltage spikes this is indicative of can damage the car's electronics - the dash module and ABS/ASR ECU for example (which are expensive to fix).
