News
Battery Tender 488 Spider
Discussion in '458 Italia/488/F8' started by Noodles1, Nov 5, 2019.
  1. Noodles1
    Noodles1 Rookie
    Nov 5, 2019
    3
    Nick DImitra
    How can I determine if a battery tender for 488 Spider is working correctly?
  3. NeuroBeaker
    NeuroBeaker Moderator
    Moderator
    Oct 1, 2008
    32,319
    Huntsville, AL., USA
    Andrew
    Welcome! :D
    As you've begun with a technical question, I've moved your thread to the 488 model area where you'll probably get more targeted assistance. Good luck!
    All the best,
    Andrew.
  4. klinkman
    klinkman Formula Junior
    369
    Silicon Valley
    Eric C
    The light turns from amber to green.
  5. Noodles1
    Noodles1 Rookie
    Nov 5, 2019
    3
    Nick DImitra
    Hi Klinkman - Thanks for the reply. Currently, I plug it in and hit reset button, I get solid green. Then I attach to the car and after one minute I get flashing green. No amber at all.
  6. klinkman
    369
    Silicon Valley
    Eric C
    Sounds like car battery is fully charged.
    The flashing is the connecting/communicating part. It should turn solid after a short time.
    If you want to check it, disconnect your car from charger for 24-48 hrs. It should be amber when you plug it back in.
  8. Noodles1
    Noodles1 Rookie
    Nov 5, 2019
    3
    Nick DImitra
    Thank you Klinkman - I will follow your suggested steps and report back. Much thanks!
