Battery tender in absence of power outlet | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Dan488, May 26, 2023.
  1. Dan488
    Dan488 Rookie
    Feb 14, 2022
    26
    Does anyone have any recommendations on how I can hookup a battery tender in absence of a power outlet? My building has zero electrical outlets nearby. Any insight would be appreciated. Thank you.
  2. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,263
    Midwest
    Ivan Drago
    Call an electrician
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Any windows or doors nearby that you can hook up a small solar panel to? Some of them have alligator clips to attach to the battery.
  4. Dan488
    Dan488 Rookie
    Feb 14, 2022
    26
    Unfortunately no door or windows anywhere nearby.
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Not sure which model you are dealing with. Older Ferraris can tolerate a battery kill switch which is another way to stop parasitic drain.
  6. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,790
    Weston, MA
    Paul
    Do a search for portable battery packs, you might find a solution there.
  7. Jamesal925
    Jamesal925 Rookie
    Aug 3, 2022
    11
    I’d second this. Without a tender your next best option is a proper kill switch on the battery. Not as effective however as your battery will still drain over time while parked.
  8. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    I'm in exactly the same situation-
    GoalZero Yeti - Various power outputs at related price- All work great- Plug the tender in and depending on which unit you buy you can just leave it and recharge weekly or use it sporadically to top off your battery- I have the 500x because it sits in the passenger footwell and I can cover the car while charging-
    Cheers:cool:
    https://www.goalzero.com/products/goal-zero-yeti-500x-portable-power-station
    rampante550, Mirek and Dan488 like this.
  9. Dan488
    Dan488 Rookie
    Feb 14, 2022
    26
    Thanks! How long does it last you with the tender plugged in? Do you have a 488?
  10. Ivan Drago
    Jul 14, 2021
    1,263
    Midwest
    Ivan Drago
    We’ve had customers who own condos have us install outlets and even panels for them for these situations. We’ve seen an uptick in this work since electric vehicles have become more common. Other users have given some good suggestions too, things I didn’t know about.
    My initial reply was kinda short yesterday as I was running around still, so I’m sorry but yeah this work can be done, and it’s really not that expensive even if you need a panel (last one we did was $1,500 all in). Most condos we’ve dealt with have assigned spots, and if yours doesn’t you can ask about one potentially.
    This investment cost may be useful if you decide to sell the place in the future as even though the new person may not have the need for a trickle charger, electrics are becoming rather common.
  11. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    I have a 458- Once it gets into float mode it will last a few days- I use a proper 4-stage battery tender- Not the factory one- I've heard the 1000x lasts a week- Cheers
  12. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,960
    The Cold North
    Tom
  13. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    In same situation w/ vehicle at the beach pad.
    Appreciate that Yeti solution.
  14. Sunshine1
    Sunshine1 Two Time F1 World Champ
    26,886
    Miami
    I live in a Miami condo. No outlets where my spaces are or close by (no extension chords can be used, not legal/liability). I daily drive my Cali30 and usually never go on vacation more than 5 weeks at a time (although several times a year).
    But this is how I would cope with a battery which is not 100%. I asked my F. dealer what battery boost they use and they said NOCO Boost GB150 jump starter. I bought one and keep it charged at home.
    Dan488 likes this.
  15. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,467
    The 1500x probably even longer and fits in the trunk or front seat
    Shorn355 likes this.
  16. SVanDyck
    SVanDyck Formula Junior
    Oct 4, 2021
    459
    Joe Michaels
    I’m in a similar situation with a 2023 Roma. I drive the car about once a week. Also, once a week I do plug it in at friends homes. Each time I plug in I let the battery turn to green.
    My suggestion is to date women who have electrical outlets and to sleep over once a week.
    kestrou, Mirek, mar76 and 7 others like this.
  17. kmikko
    kmikko Rookie
    May 18, 2021
    11
    San Carlos
    Mikko
    2022 Portofino M - left undriven a few times for a week - no problems. Went overseas for 3 weeks and coming back turning the power on lots of scary messages come up - airbag failure, tmps failure - contact dealer come up and battery meter shows 7.5V. Plug in the trickle and 12 hours later it shows happy. Car starts fine and no issues.
  18. nickorette
    nickorette Formula Junior
    375
    Canada
    I have several exotics, live in a condo without outlets in parking. I use portable lithium power stations, I switch out every other week and weekly for F430 (parasitic drain is especially high on F430). I use bluetti 1500, gives about 48 hours of power to tender. I disconnect the Ferrari's in the winter.
    JCR likes this.
  19. Sunshine1
    26,886
    Miami
    Will research lithium power stations, that’s interesting (when being away for at least a few weeks). For now I use a NOCO boost if needed (I never had to use the device yet).
