Battery Tender Installation | FerrariChat
Discussion in '308/328' started by BassMan, Oct 25, 2009.
  1. BassMan
    BassMan Formula Junior
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    I picked up a Deltran Battery Tender Plus for my 328 since my battery discharges within 2 weeks of non use.
    I tried to connect it to my battery using the tire hold down bracket as a ground. No matter what terminal I tried connecting to the Tender blinks red indicating improper connection.
    What is the proper way to connect this device?
    Also, I read some posts that there is a battery disconnect/cutoff switch. Where exactly is it located.
  2. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    #2 rolindsay, Oct 25, 2009
    The spare hold-down may not be connected to the metal frame and therefore, is not a valid connection. When I installed the tender on my Mondial QV, I attached the connectors directly to the battery cables, the wires fed forward with the plug connector ty-wrapped to the grill. I had to cut the battery clips off the supplied cable and install ring connectors - which then went on the bolts on the battery cable connectors. That is a FUSED wire and that's really important.
    I bought an extra cable and installed it the same way on my 308GTB. That way, the car that is not in use sits on the single tender. I just plug the charger's wire into the grill-mounted connections and the light goes solid red until the batteries are happy.
  3. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    I got the cigarette lighter adapter and plug my battery tender into the lighter socket. Works great! The lighter socket is a 10A circuit and the tender puts out 1.25A max so no worries about overloading it.
  4. branko
    branko F1 Rookie
    Mar 17, 2003
    3,710
    Birmingham, Alabama
    Branko Medenica
    That is the easy way to go.
  5. BassMan
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    Unfortunately, my cigarette lighter does not work - not a fuse problem. Probably need to replace it.
  6. BassMan
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    I tried using the supplied ring connectors. When I connected to both terminals, I got the blinking red. Then I tried different combinations.
    When you connected yours, did you connect to both battery terminals or did you connect to some other ground point?
  7. Euro Quattro
    Euro Quattro Formula Junior
    Apr 20, 2005
    344
    Vancouver
    Kent
    I have mine hooked up directly to the pos & negative on the battery with the supplied fused cord. Its worked fine for 10 years now. Its kind of hard to mess up unless you reverse the connections,maybe you have a bad unit.
  8. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    if your battery can't hold his charge for two weeks you've better replace it.
    the disconnect is not hard to find: open your frontlid, go to the left side of your car standing beside the left fender and reach into the dark part just in front of your headlight assy. the connections is mounted on the chassis. just pull the contector up.
    best way as you have never did this before is to use a flashlight the first time to see it happening.
  9. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    If your battery is discharging in two weeks of non use, something is wrong. It' either a bad battery or an electrical drain on it.
  10. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Most likely an electrical drain.
    A bad alternator diode can drain a battery, as well as crud between two close contacts on an electrical device that allows a small current drain.
    You can isolate a current drain in the car by removing fuses one at a time and using the milliamp function on your VOM to see if there is a small current draw on any circuit by placing a lead on each side of the fuse holder.
    To test the alternator on the car is difficult due to alternator location, but using the Ohm scale, you check between the hot terminal and alternator case, with the charging wire removed.
    You should get infinity one way,and a conductance with the leads reversed. If you get conductance both ways, you have a bad diode.
    Doug
  11. fastfred
    fastfred Formula Junior
    Sep 17, 2004
    450
    antioch calif.
    fred pedersen
    i also use the cig. lighter as a hook up and its so easy to do, just plug in and then unplug...as to opening up the bonnet and hooking up cables,it does take longer and be careful not to let the wires drag across your fender....
  12. eracer
    eracer Karting
    May 29, 2009
    141
    Michigan
    Eric W.
    I just take my battery out for the season and keep it in the warm basement. My batteries last 7 to 8 years this way.
  13. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    One precaution about taking a battery out. Setting it concrete can cause it to drain. Sounds like witchery or a job for mythbusters? The temperature of the concrete is usually much colder than the air above, causing a differential temperature between acid at the top and bottom of the battery and that causes electron flow and dead battery. Always place the battery on a piece of cardboard of wood if you must place it on a concrete floor.
    That said, the true measure of a battery is it's amp-hour capacity. Physically provided by plate area. A battery can hold a charge for 5 years but the plates will have eaten away into debris at the bottom and the battery capacity is greatly diminished.
    If you want to save money, buy the best standard battery you can find, often $80-$90 - making sure it comes with full 3 year warranty. And take it in for replacement at 2 years 11 months to get a new one free. That is the best of all worlds for lowest expense and best battery efficacy.
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,874
    Mike 996
    "One precaution about taking a battery out. Setting it concrete can cause it to drain."
    True many years ago, not now.
    Battery makers specifically address this myth on their sites such as this one:
    http://www.trojanbattery.com/Tech-Support/FAQ.aspx
  15. BassMan
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    So, I figured out why the Tender was not working initially. It turns out that if the battery is drained below a certain level, the Tender has some circuitry that prevents it from charging. Supposedly some sort of safety feature.
    Anyhow, I got the battery recharged and hooked up the tender with no problem last night.
    But now I am thinking I may need to replace the battery anyway. What is the right group size? 34?
    I haven't bought a battery in years, any suggestions? Consumer Reports liked Die Hard, Deka and Optima.
  16. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Hooked directly to the battery cables. Double (or perhaps triple) check your polarity...
  17. BassMan
    Aug 14, 2008
    626
    Long Island, NY
    Andy
    As I noted above, the problem was not the connection, just that the battery was completely drained and the Tender does not work below a certain leve.
  18. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Sorry, didn't read ahead far enough before posting. Happy Wednesday!
  19. meloyelo
    meloyelo Karting
    May 20, 2002
    245
    Houston Texas
    I really like the Die Hard Platinum. It holds a charge a lot longer than normal batteries when not used. It is a little heavier than normal and it is expensive, but I think it is worth it. I have not had to use my battery tender since I installed the Platinum about two years ago.
    my
