BATTERY TENDER | FerrariChat
BATTERY TENDER
Discussion in 'Technical Q&A' started by Rosso Corsa, May 16, 2006.
  1. Rosso Corsa
    Rosso Corsa Karting
    Jan 24, 2006
    101
    No.Fork Long Island
    Lee
    My 1987 328 sits in the garage for weeks at times (not by choice), I like to get a battery tender and connect to the sigarette lighter so the battery will stay constanly charged to proper level, can anyone help me with wich battery tender would be best for the 328? Thanks in advance. Lee
  2. JCR
    JCR F1 World Champ
    10,903
    H-Town, Tejas
  3. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    You should probably be specific as to what type of battery you are using...a standard battery or a Optima type battery. I had read some place that the Optima batteries may not play well with battery tenders / trickle chargers. Maybe there is someone here that can back that up or say there is no harm.
  4. snafu
    snafu Karting
    Mar 2, 2004
    59
    Cincinnati, Ohio
    David W
    I have an 86 328 with a Battery Tender brand model # 012-0123. that has worked good for me. I also have it on a motorcycle and Miata. No problems in the past.
  5. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Thats something worth looking into, I use an optima battery, on the dream garage link they refer to a Us3300 thats suitable for the Optimas
  6. Ricambi America
    Sponsor Owner
    Deltran Battery Tender. The Best. Period. End of Story.
  7. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    Absolutely. No question.
  8. L8Braker
    L8Braker Formula 3
    Nov 10, 2003
    1,567
    Asheville NC
    Jeremy Stafford
  9. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,958
    MO
    Omar
    If I am not going to drive it for a week or two, I just pull the quick release battery cable in my 328.
  10. LarryS
    LarryS Formula Junior
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    I had a problem with 2 battery tenders not keeping m/c batteries charged properly. I emailed the company, they said they had a new model and replace both of them for a s/h charge ($16?? ea.). I asked 3 times if the original ones I had had a defect, they would never say that, they did say the updated one would solve my issues and was compatable with all types of batteries, unlike the earlier model.
    They seem to work fine now.
    FYI, the updated style has the blinking led at partial charge, original did not have that feature.
  11. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    Do a search on this board for "battery tender", and you'll find at least a dozen threads describing how many of us have used Deltran and/or Schumacher chargers, and which ones have cigar plugs and how to make your own too.
    vty,
    --Dennis
  12. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
  13. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    I agree !!! Big time !!!
  14. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
    When I needed one, Algar Ferrari of Philadelphia supplied it and it was a Deltran. Great product. Many Ferrari garages I see have this Battery Tender...no overload. Works great. In fact, many Ferrari dealers include a Deltran tender when you buy a Ferrari...at least that's what a couple dealerships told me.
  15. Tifoso Ferrari
    Tifoso Ferrari Formula Junior
    Nov 7, 2005
    578
    Upper Volta
    Gianni Cagate
    Ferrari NA service in San Rafael, CA installed an Interstate trickle charger within my 575M's factory wiring harness. Interstate part #920008
  16. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I have in Interstate on my 360 which is very good.
    I think there is fundamentally one manufacturer and multiple labels applied.
    I have seen 2-3 units that look identical to mine with a vendor different label.
    It's around $60 and it is very good.
  17. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Does that mean it has short circuit protection?
  18. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Agreed!
  19. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    With my 88 328 I use a Deltran Battery Tender with a 25' cable extension and cigarette lighter adapter. Works great! And the extension cable lets me leave the tender on the shelf instead of inside the car and the cable is thin enough that I can easily close the car door with the cable running out the bottom of the door opening.
  20. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    How much?
  21. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    These are great. I have 13 vehicles, boats and stuff to keep the batteries up. They work well an are cool so less fire hazard.
    The other option you may want to use is the Ford Gt has a charger that comes with the car. it is made to plug into a lighter socket. I have three of these for my cars that are in my garage at home. The cars I have stored offsite i use Battery Tender. The FGT plug in may save you money if you have to have someone connect the pigtail. I did this for my F430 and it is easy. I am not sure on your model.
    Be sure your lighter socket power stays on when the ignition is off. my 360 Modena did, my F430 does not, hence BT for the F430.
    The Bt is about $67 and the Ford GT charger at a dealer is $95.
    Good luck,
    lee
  22. Solreaver
    Solreaver Rookie
    Mar 14, 2007
    1
    I have a tender set up permanently in the trunk with an ex cord running to a timer on the wall, 2 hours a day it charges. Plenty of time to keep the battery fresh.
  23. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    Go straight to the source
    www.batterytender.com
    I use a bunch of the "junior" tenders for the newer cars and I have some of the regular size for the cars with older OEM batteries from the 50's and 60's
    I have 24 Deltran Battery Tenders in total and I've never had a battery problem with a car hooked up to any of them. The Tenders come with several different options to hook them up. Most of my cars have a connector wired permanently to the battery posts, but I also have a couple of clip on connectors. In some of the more modern Ferraris, the batteries can be inaccessible, but there is always a connector block somewhere in the car that's easy to get to.
  24. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    I'm going to agree with that. Hard-wire it, check the green light daily, unplug before driving (don't laugh) and have a nice day.
  25. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Deltran is the manufacturer of the Battery Tender.
    I prefer the Battery Tender Waterproof 800. It has all the features of the Jr., but it also has " The interior is completely encapsulated, protected from shock, vibration, and moisture by an electrically insulating, thermally conductive, flame retardant, UL recognized, synthetic epoxy resin compound."
    A bit safer and 800ma
    http://batterytender.com/product_info.php?products_id=36&osCsid=7f4b218184b489668527beee00b4feba
    I own four
