News
Battery Tender
Discussion in '360/430' started by RIX 360, Jan 15, 2010.
  1. RIX 360
    RIX 360 Karting
    May 12, 2004
    87
    West Palm Beach, FL.
    Ric Newman
    Besides the passenger footwell in a 430 is there a battery terminal location in the trunk to hook up a battery tender. Any other ideas.
    Thanks for your help,
    Ric
  3. andrew911
    andrew911 F1 Rookie
    2,868
    Northern NJ
    If the 430 is set up like the 360, there may be terminals behind the driver's seat behind the access panel...
  4. RAKLAW
    RAKLAW Formula Junior
    Mar 22, 2009
    405
    Westchester,NY & Sarasota FL
    RAK
    Suggest you review a recent Thread about the Batter Maintainer in the 430 section.. Several of us have issues with the factory unit.
  5. RIX 360
    RIX 360 Karting
    May 12, 2004
    87
    Ric Newman
    I have used the Battery Tender on all my cars for years and all has been OK. I was just looking for an alternative place to hook it up. Looks like it'll be in the passenger footwell.
  6. Green
    Green Karting
    Apr 13, 2008
    152
    Houston, TX
    Yes, I hook up my tender into a plug in the trunk (on the left side up front).
  8. RIX 360
    RIX 360 Karting
    May 12, 2004
    87
    Ric Newman
    The only plug I see is on the firewall and not made for a charger. Am I missing something ???
  9. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,823
    Florida
    Lee
    #7 leead1, Jan 15, 2010
    I have 16 cars and all of them have vattery tenders. I have not had any problems and the factory will help with special requirements if asked. One of my old cars had a 6 volt system and I changed the battery to 8 volt to help start it better. Battery Tender provided a 8 volt tender. I like them because they run very cool although on a real dead battery they do have some heat for a short time.
    I am sure you find a way to hook up your pig tail near the engine. But why bother.
    I think it is better to get close to the battery. on my F430 that is on the passenger side in the front seat where your feet are. That is where I have my pig tail. It is easy to plug in for storage.
    Some of the 360's and 430's have a plug in the trunk in front of the windshield. It is on the right at the very top.
    Lee
  10. RIX 360
    RIX 360 Karting
    May 12, 2004
    87
    Ric Newman
    Just put the pig tail in, passenger side in front of the seat.
  11. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,064
    Santa Barbara County
    Sam
    My 430 Spider came with a plug-in behind the driver seat. I do not know if it came from the factory that way or installed by the dealer. I purchased the car new in Dec. 07 and it came with the tender ready to just plug into it
  13. ENDOSURG
    ENDOSURG Karting
    Dec 9, 2008
    70
    Massena,New York
    Vijaykumar Mandalaywala
    yes there is one located behind driver's seat.Remove the panel it is secured with 3-4 screws.As you pull the panel you will see the positive terminal and just to the right(towards the door) about 6 inches from the positive terminal you will find a ground bolt hook up the negative to this bolt.you can leave a pigtail from the side outside and cover the panel.
  14. enasiwear
    enasiwear Rookie
    Jan 16, 2010
    28
    Huntington Beach, Ca
    Whats a battery tender?
  15. RobD
    RobD Formula 3
    Nov 10, 2003
    1,181
    #12 RobD, Jan 17, 2010
    It is a low amperage battery charger that keeps the battery charged when the car is not in use. Modern cars' electronics (alarm, key-less entry, etc.) draw power even when the car is parked. Without a tender, the Ferrari's gel battery would be dead within a couple of weeks. Mine once went dead after 10 days.
    Unlike a trickle charger, a battery tender is computer controlled and will not over-charge the battery. This is the one I have: http://batterytender.com/automotive/battery-tender-plus-12v-at-1-25a.html
  16. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Uhhh... don't you mean a 12-volt system? I don't think anyone makes any 8-volt anything for automobiles. Nowadays, it either 12-volt or 24-volt.
