Battery tender | FerrariChat
Battery tender
Discussion in '360/430' started by Rostami6, Sep 9, 2014.
  1. Rostami6
    Rostami6 Formula Junior
    545
    Austin TX
    Amir
    Hello everyone?
    I need to get a battery tender and I know most people recommend the ctek. Is there a particular model that would work best on both 430 and a Testarossa. I am normally very good at driving my car on a regular basis. However I have a feeling I won't be putting as many miles on the F430 with the arrival of the new TR. I also have an incoming 308 in a couple of weeks, so the 430 may not get a whole lot of use in the near future. Any recommendation on a particular one that can work on all three? or should I just get one for each one?
  2. ttforcefed
    ttforcefed F1 World Champ
    19,256
  3. howl
    howl Formula Junior
    Apr 10, 2011
    505
    Chicago/Boca
    Tom
    I have both multi 4.3 and 3300 by ctek. Both are good. They are not that expensive. I have one for each of my cars.
  4. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    Another vote for the 4.3.
  5. yronZFF
    yronZFF Formula Junior
    Dec 21, 2009
    749
    FIVE-O
    Ron
    I have the same ctek 3300 that I've been using for about 5 years ... 2 years on my former 355, and now 3 years for my 430. It's always been connected all the time and both cars have always started right up.
    I would get either a 3300 or 4.3 for each of your cars.
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    CTEK 7002. It can handle AGM batteries. Lesser models can lead to AGM battery failure. If you have a 360 or 430, which mounts the battery in the passenger compartment, consider an AGM battery. Can't leak.
  7. F456 V12
    F456 V12 F1 Veteran
    5,257
    Coto de Caza
    Christian
    I used a Deltran Tender Plus, rock solid, cheap enough to use one per car. My Mclaren came with a CTEK, seems to do much better than the Ferrari OEM, but 325 per unit, save the money and get a Deltran unit.
    MB
  8. Graz
    Graz Formula 3
    Oct 15, 2012
    2,329
    New Jersey and Florida
    Graziano
    +1
  9. handdoc
    handdoc Karting
    Apr 3, 2014
    154
    ctek 4.3, get one for each car, about $60 shipped on ebay each
    ctek is what ferrari uses
  10. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I concur. Wonder if you can get the mating connector so that you can hook it up to the factory connector on the 430. CTEK should be able to supply it because as handdoc said they make the one for Ferrari. You may want to get the CTEK comfort pigtails and hook one up to each car. It has lights on it to let you know when to hook up the tender -- that way you only need one tender. Just a thought.
    Alan
    Accessories - CTEK Battery Chargers
  11. Rostami6
    545
    Austin TX
    Amir
    Thank you guys, All very helpful.
  12. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    You can never have too many F-cars, Amir!
  13. Rifledriver
    37,090
    These are the best I have ever used.
    I used to use a number of others and settled on the Deltran for a while but had a few of those fail too.
    I buy, use, install and sell a LOT of tenders. Never used one as good or reliable.
    Granite Digital - Save A Battery
    I use the 9999
  14. Rostami6
    545
    Austin TX
    Amir
    This^^ :)
  15. marky1
    marky1 Formula 3
    1,130
    Mark
    My Scuderia came with the 3300. It's not up to the job, hardly ever fully charged the battery. I bought the CTEK MXS 7.0 (US model is US7002) and works perfect now. Has a setting for gel batteries too.
  16. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    +1. I have used Deltran the Tender Plus as well as the jr for years without a problem.
    Batterymart sells the jr for ~$23. The Plus is more, but still very reasonable.
    Battery Tender Plus 12 Volt 1.25 Amp Battery Charger: BatteryMart.com
  17. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    I have a CTEK 4.3 and i am fully satisfied. Highly recommend it ...
  18. f355spider
    f355spider F1 World Champ
    18,044
    I own close to a dozen various brands of battery tenders, including a Granite....I have not found a significant performance difference in spite of claims of desulfation modes, and multiple charging steps...they seem to all do the job adequately, from a $20 Schumacher, to the ones that cost $150 or more. I say get whatever floats your boat and makes you feel better. Though you might heed Rifledriver's advice, since he obviously sees and uses way more of these than the rest of us...
    When it comes to battery replacement, I have found absorbed glass mat (AGM) designs do seem to last longer. I like the East Penn and Sears Platinum brands...
  19. BigJay2050
    BigJay2050 F1 Veteran
    7,191
    I use the same exact unit; and I tweaked one of the extension cables for it so I could plug into the factory charging port with some help from a thread I found here -- works like a champ.
  20. wkumari
    wkumari Karting
    Jul 15, 2011
    169
    Northern Virginia
    Warren
    Yeah, they don't seem to sell the Ferrari pigtail - probably some silly licensing thing.
    Anyway, I have just (yesterday) parted with my Murcielago and gotten a 599. This means I need to build myself another CTEK to Ferrari cable. I could probably build some extras if folk are interested, but they would probably be somewhat pricey ( ~$89) because of the cost of connectors, time, etc. If enough folk are interested I'll look into doing this.
    Instructions on making your own:
    http://www.ferrarichat.com/forum/showthread.php?t=347563
  21. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    #21 Falcon Wing, Sep 13, 2014
  22. BigJay2050
    7,191
    I actually used your thread to make mine for the Granite Digital. Thanks for the detail! :D
    Also, the Granite Digital that RifleDriver mentioned includes the Wall Mount bracket.
    Amazon carries them too: http://www.amazon.com/gp/product/B008MUHIIW/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B008MUHIIW&linkCode=as2&tag=httpwwwmicr02-20&linkId=SOG2QFR2V4LZPFT5
  23. wkumari
    wkumari Karting
    Jul 15, 2011
    169
    Northern Virginia
    Warren
    You are most welcome! Glad it helped.
  24. wkumari
    wkumari Karting
    Jul 15, 2011
    169
    Northern Virginia
    Warren
    #24 wkumari, Oct 3, 2014
    And I ended up making another for for my 599GTB. The pinout is the same as for the F430, but (obviously enough) the indication that it is plugged in is different.
    Picture of the icon on the dash
    The cable
    And plugged into the charger port in the trunk
