Battery Tender | FerrariChat
Battery Tender
Discussion in 'Mondial' started by drbruno, Oct 18, 2015.
  1. drbruno
    drbruno Formula Junior
    751
    Toronto, ON
    Dr. Bruno L. Venditt
    Suggestions for a battery tender for my 1989 Mondial t cab? Do you connect them directly to the battery? I currently have one, but it does not fit the cigarette lighter receptacle.
  2. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    I like the Battery Minder, but Battery Tender is also good. Put a set of ring terminals on the battery, and then just plug in when you want to connect.
    Regards,
    Jerry
  3. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    search CTEK in the classifieds they are about $60
    they are the same as F OEM
    harbor freight has cheapies for 9.99
    mine is from Sears and actually is double sided taped to the battery just plug my cord into the bay
  4. drbruno
    751
    Toronto, ON
    Is it constantly attached to the battery terminals and you simply plug it in to an outlet?
  5. drbruno
    751
    Toronto, ON
    So I'm guessing no one plugs into the lighter receptacle?
  6. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Yes. There is a pretty standard connector with a cover on the connector with the ring terminals. When not in use, cover the connector.
    To connect, I open the hood, plug in the connector and then plug in the BT to the extension cord. I purposely leave my hood unlatched so I don't forget to unhook before I pull out (just ask my significiant other about doing that!!! :( )
    I do not use the cig lighter console, not sure anyone does ( I think it is key powered).
    Regards,
    Jerry
  7. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    For Mondials 3.2 the cig lighter is not key powered. For the T I don't know, but you can do an easy check. See if your phone is charging when you plug it in :)
    Ps. if you charge directly on the battery, take of the power using the power off switch that is next to the battery. You would not be the first to fry the Mondial's ECU. The battery has been tucked away deep and the chance in touching any of the metal around it is high. ;) Also use the switch when taking out the battery.
  8. Alden
    Alden F1 Rookie
    3,399
    Central Florida
    #8 Alden, Oct 19, 2015
    My 3.2 came with a factory installed plug near the battery for the emergency light. It is wired directly to the battery, I plug my charger in there.
    I did have to run new wire from the plug to the battery, the original wiring was bad.
    The plug looks like a lighter plug, but is not, it is a little different, found on BMW motorcycles too.
    Plug can be found here:
    DC 12V 24V 1 5A Motor Car Power Adapter Cigarette Lighter Plug for BMW Motorbike | eBay
    Pics of my female plug location next to the right headlight below.
    Alden
  9. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    Oh wow! I don't have that one! But then I also do not have the one in the engine bay near the oil cooler :)
  10. MrMark
    MrMark Karting
    Apr 3, 2013
    141
    Louisiana, USA
    +1 for the CTEK tenders mentioned above that are for sale in the classified forum. I couldn't be happier with mine.
  11. nygts
    nygts Rookie
    Sep 26, 2011
    31
    CTEK, same as what others mentioned above. works great.
  12. drbruno
    751
    Toronto, ON
    Any particular CTEK model that you recommend?
  13. Karsya Eins
    Karsya Eins Karting
    Jun 17, 2014
    94
    Albany, NY
    Demostene Romanucci
  14. Alden
    Alden F1 Rookie
    3,399
    Central Florida
  15. moysiuan
    moysiuan F1 Rookie
    4,103
    Canada
    BATTERYMINDER 1500 12V 1.5A MAINTENANCE CHARGER / DESULFATOR from Aircraft Spruce Canada
    I have liked this one from Aircraft Spruce (it's in Canada, lots of other items for car maintenance, sound deadening, etc. although directed at the small aircraft owner)...Very compact, whole units plugs into the wall, and I hard wired the disconnect wiring permanently on the battery, very simple to do. Also desuphanates which extends the battery life.
  16. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    Lots of good ones noted here; use whichever one you want. The one I use costs only $25.
    BatteryMINDer Plus Charger/Maintainer/Desulfator — 1.3 Amp, 12 Volt, Model# 12117 | Battery Maintainers| Northern Tool + Equipment
    Not sure why you would want to pay more just because the battery being charged is on a Ferrari... :)
    Regards,
    Jerry
  17. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    This is what I've used for years. Where "Battery Tender" has failed in the past to recycle after normal voltage drain, this $30.00 or so, Schumacher tender has yet to be fooled.
    Schumacher SEM-1562A-CA 1.5 Amp Speed Charge Battery Maintainer
    Cheers,
    Hank
  18. moysiuan
    moysiuan F1 Rookie
    4,103
    Canada
    The Battery Minder 1500 replaces the older 12117 version noted at Northern Tool, and has different microprocessor control, will apparently start to desulfonate at a lower voltage threshold than the older model. But I agree, the old discontinued model works just fine, if you can get old stock at a good price than that makes sense.
    Also, the Aircraft Spruce price is Canadian dollars, which is unfortunately at present is at a 30% discount to the USD, and the ship cost is higher too, so the to the door price difference is not much in the end. We also pay 13% total sales tax on everything. So if you think maintaining a Ferrari is pricey in the States...
    Mondial's are scarce in Canada. I would take a guess that there are maybe 10 to 20 cars actually on the road? There seem to be a few more T's than other variants, I have seen a beautiful blue one once.
    The few QV's that surface seem to be very well maintained. 3.2's rarely come up. Only seen one hardtop T years ago, a white one, it was quite striking, otherwise all cabs. All just anecdotal observation of course, from a Toronto vantage point.
  19. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    For some reasons unknown,
    it seems most of the Canadian Mondial went to Quebec.
  20. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
  21. Alden
    Alden F1 Rookie
    3,399
    Central Florida
  22. ceb39
    ceb39 Formula Junior
    Sep 17, 2012
    483
    San Francisco Area
    Chuck B
    My 87 Mondial came with a Schumacher tender mounted in front and connected to the battery. I plug the electrical cord into a timer and run for two, two hour periods a day. Have used it for two years without any problems. The one time I did not use it and let the car sit for almost three weeks the car did not start. Always used from then on.
