Battery Tie Down? | FerrariChat
Battery Tie Down?
Discussion in '308/328' started by Rv5, Feb 4, 2008.
  1. Rv5
    Rv5 Formula Junior
    Dec 22, 2005
    333
    Ross V
    The 84 308 I recently picked up has an optima red top up front that is just sitting in place. There are no straps or ties of any sort holding it down. What kind of mechanism did ferrari use to secure these? I need to get that battery held in place.
  2. Steve Magnusson
    26,799
    Search on "battery toe clamp" for several threads.
  3. BigTex
    79,380
    Houston, Texas
    Bubba
    It's a wedge clamp that clamps the base at the bottom........fastened by a bolt into a plate on the framing members.
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    It has a bottom bracket that attaches to the lower lip of most batteries. It wedges the battery in and lockes it down with 1 bolt
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Yes, it's in front of the battery facing the radiator.
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Or else it & it's bolt are rattling around inside your spoiler. ;)
    Found mine down there after I'd had the car for 4 years & needed to fix the spoiler. Hold-down was a tad rusty, but a thorough sand blasting & POR15 treatment solved that. BTW, POR15 is battery acid resistant.
  7. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Any pics of this posted around anywhere?
  8. miketuason
    Feb 24, 2006
    15,810
    Cerritos, CA.
    #8 miketuason, Feb 6, 2008
  9. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Thanks Mike
  10. 308 GTB
    308 GTB F1 World Champ
    11,719
    New Jersey
    Barry Wolinsky
    Ross,
    You'll be pleased with the Optima Red Top. I intstalled mine 5 years ago and do not use a Battery Tender. I do drive my 308 regularly and the battery has always provided full cranking power.
    The battery clamp you see pictured will just barely engage the lip at the base of the battery as there is some interference by the the central cylinder. Play with the clamp a bit, tighten the bolt securely and it will engage.
    Barry
  11. Papa Duck
    Papa Duck Formula Junior
    Jan 16, 2006
    351
    Las Vegas, NV
    Carl
    Barry, I am glad that I was not the only one who had problems keeping the Optima clamped down. I never could get mine to stay in place for very long. I guess I didn't have the patience to fiddle with it long enough to get it to hold tight.
  12. 308 GTB
    11,719
    New Jersey
    Barry Wolinsky
    That clamp was designed long before the Optima was even thought of, Carl. I did get my clamp to engage securely and it has stayed that way for the past five years, even with track use. If it hadn't, I was prepared to fabricate a new clamp to acommodate the Optima.
