battery voltage dropping | FerrariChat
Discussion in '206/246' started by champtc, Aug 11, 2007.
  1. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    I am having an issue with my battery voltage dropping. The battery holds a charge and shows about 12.04 when running at 1500 idle. This initially alarmed me as it should be 13.4 so I thought that there might be charging issues. I suspected alternator & voltage regulator and tested them. They seemed ok, I checked & cleaned the fuses & sanded down large fuse on engine firewall. I checked & cleaned engine,battery grounds & cables...no issues. However with the key turned on (engine not running) the voltage drops from 12.04 down and keeps going lower-like 11.8, 11.6 and keeps going down (without the engine running). I disconnected the alt and had the same issue. I suspected that the alternator was not charging the battery, however that seems to be a secondary issue (if even the case). The battery is just dropping quickly without the engine even being on. I ran this engine on battery alone for hours when I was rebuilding it (it was on the floor) and it ran for a long time without the alternator even being attached to the car. I was thinking of disconnecting the fuel pump & seeing if I still had the voltage dropping so fast. I think that even with the key on the battery initially powers the fuel pump and I was thinking maybe there is a short between the fuel pump & the battery. I guess it must be a short somewhere but not sure where else to look? Any insight much appreciated!
  2. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    The battery is completely discharged. The alternator is doing nothing. Charge the battery and fix whatever is broken with the alternator.
    A discharged battery will show 12 volts under no load if no cell has shorted. Odds are that batttery is OK. Hook it up to a charger, charge it and test it under load. Most larger chargers have a test function. If not, put battery in car and turn on headlights. If voltage is around 12 volts and stays there, you are in business.
    Don't do any alternator testing without the battery hooked up. With no battery, the alternator voltage can go very high and possibly fry your radio or ignition system.
    Alternator has two wires going to it, Field and Output. There is a fuse box on the front firewall just in front of the front Oil Filler. Check both fuses and check voltage on both lines. Key on, engine stopped, field should be high and output should be battery voltage. Start engine. When battery voltage is low, field voltage should be high and alternator should charge battery to about 14 volts. As battery voltage rises, field voltage drops and so does charge current. No field voltage indicates a bad fuse or bad regulator or bad wiring. High voltage on field and no output from alternator indicates bad alternator brushes or something more dire in the alternator. You can check field with an ohm meter if you pull the field fuse. I have to replace brushes every 30-40,000 miles. Of course you could have connected the field wire to the wrong terminal on the alternator. I have! Field wire goes to terminal about an inch from output terminal.
    Find the problem before cleaning all the wires. More faster. Good luck.
  3. champtc
    Apr 18, 2004
    732
    ok...battery charged up & showing 12.7 volts...I turn lights on only (low beams) it drops to 12.05 volts & stays there...turn lights off & voltage goes to 12.63 volts(again the motor is off) . At 12.63 volts I turn key on until fuel pump kicks in..voltage drops to 12.30 and stays there. I turn off key & voltage rises to 12.62. I turn key back on to start fuel pump & turn lights on & voltage drops to 11.99 and stays there. I turn lights off (with fuel pump on) and voltage rises to 12.29 and stays there. I turn car off and go to bed (while neighbors suspect odd goings on in my garage at 9 at night!) I have to recheck the field voltage etc tomorrow (but grounds cleaned & fuses checked and/or replaced). Another wise sage suggested the voltage reulator as the culprit. However, I want to check everything before I replacce that. As usual all advice welcomed! Thanks
  4. John Corbani
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Sounds like battery is fine. Now onwards to why no charging. Good luck.
  5. dm_n_stuff
    Dec 10, 2003
    43,756
    26.806311,-81.755805
    Dave M.
    #5 dm_n_stuff, Aug 13, 2007
  6. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    This is the Angelo Walace works?
  7. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Yes, this is from Angelo Wallace's translation of the workshop manual.
    Jim S.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Check the wires running to the alternator from that fuse box. They are probably in a piece of plastic tubing. I've had them corrode down to almost nothing. You can't see it because of the tubing.
  9. champtc
    Apr 18, 2004
    732
    This has been a long process for me. I am not quite finished with it yet but when I am I hope to save many people a lot of time , money & aggravation (by example). There is a shot I will have a bunch done by tomorrow or weds and I will give you installment #1 of this issue. Hint- it was a huge pain in the rear!!
  10. champtc
    Apr 18, 2004
    732
    OK...finally just about done with my alternator troubles on my '74 us GTS. I was having difficulty getting a full charge to the battery and extensively tested the voltage regulator & alternator, fuses , grounds and battery. I probably ran 25 tests to see what was wrong. I tried the voltage regulator & installed a new voltage regulator ( they are all the same mine came from a VW), I tested the field wire, The output from the alternator. I did everything as I wanted to be 100% sure that it was not the alternator, The bottom line was i couldnt get higher than 11.5 on the field wire nor higher than 11.25-12 on the alternator or battery no matter what I did. I made the decision to pull the alternator which was a VERY tough job. It would have taken me probably less time to pull the engine. Maybe it will be much faster the second time I do it but it was a real pain. It is important to loosen the gas tank strap and shove the tank as far over as you can the extra 1/4- 3/8" is really needed to get the alternator out through the bottom under the oil cooler hoses and along side of the gas tank. The hoses coming from the aluminum radiator tubes have to come out too. I also pulled the alternator waffle housing and bracket that holds it to the engine. I was able to get this out down through the area by the shift linkage & radiator hoses (where they go thru the tunnel in the center of the car). My alternator had been rebuilt before I put the engine back into my 74 246 GTS. However after it was not working & I pulled it I sent the alternator back to the rebuilder and this time he said that the brushes had become soaked in oil & weren't charging. I cant figure this out as the engine was bone dry and has no oil leaks. In any case I decided to try to retrofit a regular GM alternator on the car just to see if i could do it and if it would work. I bought one from Jegs for about 110 bucks and it was an externally regulated unit. I also bought a euro alternator bracket from Dinoparts.de. I had tried to get the bracket(was told that they werent available)when I had the engine out to make the alteration at that time and to get rid of the waffle aluminum cannister housing that is on the Us versions. If your engine is out you should consider doing this...MUCH easier to work on & see. If you look at OMGJON's rebuild he has the euro bracket and thats what alerted me to the fact that they are available. It was pretty expensive 300 bucks or so but well made and I wanted to change mine. So I put the GM alternator in which has a smaller diameter pulley and a slightly wider groove which is giving me some slipping on the belt (as a reminder the US version cars have a narrow "v" belt which is smaller diameter than the euro belts). However, I am waiting for another pulley which I may fit to the alternator & see if it fits better. In any case the new GM alternator was giving me 15.25 at the battery which was too high. I was using my original red Dino Voltage regulator. I switched to a VW voltage regulator( I paid about 35 bucks) and the voltage dropped to high the low 14's . I dont know why this is except maybe the smaller pulley on the GM alternator spins faster than the original(larger) pulley on the magnetti marelli unit and in combo with the original voltage regulator was too much.( I intend to take apart the red Dino voltage regulator & look at it). I am not 100% sure about why this is happening but the replacement VW voltage regulator has given me the right voltage. I also replaced the 60 amp fuse as mine had melted ( and although it was one of the first things that I checked & it was ok -not sure when but at some point along the way it went) after I checked it initially. I bought two of them (about $50 bucks each which is crazy) and I now keep a spare in the glove box. However, here is an easy cheap fix (temporary) get a modern 60 amp fuse and if your original melts you can gently push the new style one into the slot and place it along one side of the original. The thickness of the original will keep it in place & the circuit will be continued through this fuse. It certainly will get you home until you can spend $50 bucks for a new one! If you repalce your alternator with a GM unit or any other unit with a smaller diameter pulley you will have to make a longer adjusting arm for the alternator. The geometry of the original Magnetti Marelli unit had it closer to the block due to the size of the pulley & the original shorter adjusting arm will fit. The new adjusting arm that I made is about 4" x 6" and is bent into a right angle. I may put a different pulley on this unit just to try it but I took the car out for a spint tonight and it all worked great. I really enjoy working on my car and if it wasnt for the helpful people on fchat (and a HUGE thanks to JS) I wouldn't be able to do any of it. I actually enjoy fixing it more than driving it (kinda sick huh?) Thanks and if I can help any one please feel free to ask.
  11. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Tom - you are now designated the world's Dino alternator expert. Good job.
    Jim S.
  12. dm_n_stuff
    Dec 10, 2003
    43,756
    Dave M.
    Jim, it's from the Ferrari Version I think. Cover is different than Wallace's.
    I swappped my Original alternator for one from a late 80's Alfa. More amps, works great. Did require a custom bracket, but the pulley wheel from the original fit right on it. It had its own regulator, so mine is now for decoration only.
    Everything works, car charges at just above idle.
    Tom, great job. Glad it worked out. As to it being tough to remove, what isn't on this car? Well, besides the wheels and the cash from our wallets.
    DM
  13. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Dave - I suspect that Wallace's translation simply copied much of the workshop manual. If you have the original workshop manual and this charging discussion is in it, then the source is Ferrari. I stand corrected.
    Jim S.
