Battery vs jump starting? | FerrariChat
Discussion in '308/328' started by Fiat4Fun, Aug 3, 2015.
  1. Fiat4Fun
    Fiat4Fun Formula Junior
    Jul 1, 2008
    317
    Sunriver OR
    Bob
    Howdy,
    So, I parked my car ( '89 328) for about 3 weeks, off the battery trickle charger. Went to start it, and it was turning slow. Tried to jump it with my new Jeep, and the starter spun the motor no problem, but it would not start. Started to smell gas, so I thought it was flooded. Waited awhile, and the starter turned the motor fine, but no start.
    So, left it alone over night, pulled the battery and stuck my Fiat battery in it, and it started right up?
    Stuck the old battery on a charger in the garage, will test it later…...
    Why would it not start via a set of jumper cables and start up via a new battery? Seems like the motor was spinning just fine off the jump start, but would not start.
    Just curious????
    Any input would be helpful
    Bob
  2. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The correct way to do it is to use the jump leads to charge the low battery (provided the battery is not faulty) by connecting the jump leads then revving the other car to 2000-3000 RPM for a few minutes.
    Then disconnect the jump leads and try to start. If you try to start via the leads the voltage drop across the leads might be too great under the load of the starter to operate the ignition system.
  3. Jdubbya
    Jdubbya The $10 Trillion Man
    43,742
    Hell's waiting room
    Could have been a loose connection or ground too.
  4. DGS
    DGS Seven Time F1 World Champ
    73,201
    MidTN
    DGS
    I had that issue on my '88 328. It would start when cold, but not when hot.
    And even jumper cables wouldn't start it when hot.
    Turns out that the battery connector was a bit corroded, and when it warmed up, it expanded more than the battery post.
    Cold, it fit. Warm, it was loose.
    That also meant that the alternator wasn't charging the battery properly, once it got warm, so the battery was low fairly often.
    I filed down the corrosion, applied some electrolyte gel, and clamped it down properly, and it was fine.
  5. SpyderGT
    SpyderGT Formula Junior
    May 15, 2005
    997
    Vancouver, BC
    Jon
    Probably a dumb question: if using a battery booster pack, are there any connection spots on a 328 apart from the battery terminals? A buddy told there was such connections on his '94 348 (recently sold) but we didn't see anything similar on my the '86 328. I haven't had any issues with battery or starting, but if I were to, it would be nice not to have to remove the spare, then the battery access panel, etc.. Thanks, Jon
  6. BigTex
    79,407
    Houston, Texas
    Bubba
    Sorry but...no.
    They provided them in the 348 because the battery was in the interior of the passenger compartment.
    On a 308 it's a toss up, you can pull the spare tire out, or jack the car and go direct to the starter solenoid in the rear.
  7. SpyderGT
    May 15, 2005
    997
    Vancouver, BC
    Jon
    Thanks BigTex. Jon
  8. Fiat4Fun
    Jul 1, 2008
    317
    Sunriver OR
    Bob
    Got the battery charged and put a load test on it,
    Did head down to the weak area. Will return it and have them test it.
    Does the ignition system need more power than the starter?
    Seems like the starter turned the motor when I jumped it…...
  9. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    The starter will draw a lot more current than the ignition system. The starter will continue to turn though, albeit more slowly, with a relatively low battery voltage but the ignition system will have a threshold voltage below which it will stop working as its an electronic system.
  10. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,531
    Raleigh
    Kevin
    Remember these cars are super old now. I recently found my battery tender struggling. Hmmm... well battery over 6 years old. I got a new battery. Still the battery tender struggling. And by struggle I mean 24 hours and still showing charging, when typically it's charged up in minutes after returning from a drive. I disconnected everything and thoroughly cleaned *all* connections, including cleaning or replacing washers between the tender connections and the battery terminal. There was no "obvious" signs of corrosion but I think this is typical with oxidation and age.
    After cleaning everything up all is well.
  11. jmaz
    jmaz Formula Junior
    Jun 27, 2011
    350
    Colorado
    Jim
    Right. I ran into this with an Alfa Spider I had. The problem was indeed that the battery voltage was too low to operate the electronics but was able to turn over the engine at a pretty rapid rate, thus fooling me into wasting time chasing ignition/fuel ghosts before finding the easy fix. Perhaps check the battery voltage with a voltmeter to see if it's at least 12V.
