Battery woes | FerrariChat
Battery woes
Discussion in '360/430' started by aslowdodge, Dec 9, 2021.
  1. aslowdodge
    aslowdodge Karting
    Jun 5, 2004
    206
    Marietta, Georgia
    I have a 2005 f430. I drove it a week ago then parked it and put it on the tender. Today it's as dead as can be. It seems the door didn't shut all the way so it's been that way all week. Maybe it drained the battery faster than it could maintain? The tender says the battery is bad.
    I’ve tried to charge the battery with just the tender and it gets to 6 volts then says the battery is bad.
    Should I try a regular charger? Maybe I Need a new battery. Just seems sudden as it was always fine. Any ideas? What to get and where from.
  2. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
    How old is the battery? If it's three years or older you probably need a new one.
  3. marc996
    marc996 Karting
    May 12, 2019
    66
    marc bethell
    Given how sensitive to battery voltage these cars are I would just replace it, its probably the cheapest and easiest to change part you can do on a Ferrari!
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Put a standard battery charger on it ( not an electronic type) which will probably charge it at 4 amps and see if that helps, once you have a good overnight charge in it put the normal tender on it and see how it goes.
  5. RedNeck
    RedNeck F1 World Champ
    12,288
    The CSA
    Me
    If the battery went that low you may have to hook it up to another battery to get the voltage up. A lot of those chargers will not work (by design) if a battery has deep discharged....but I agree, if it's a few years old, just replace. I don't trust batteries that have been deep discharged.
    alex likes this.
  6. aslowdodge
    aslowdodge Karting
    Jun 5, 2004
    206
    Marietta, Georgia
    Anyone have any battery suggestions? They don’t seem to be easily found.
  7. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Interstate MTP-91
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    If you have not changed a battery in a 430, be sure to wrap insulation tale around a 10 mm deep socket when you undo the clamp bolts, very easy to short socket when taking the red one off.
    ditpixs likes this.
  9. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    That is very good advice
    A mess can be made if inattentive
  10. ditpixs
    ditpixs Karting
    Apr 22, 2019
    231
    Nor Cal - Tracy
    Aaron
  11. ditpixs
    ditpixs Karting
    Apr 22, 2019
    231
    Nor Cal - Tracy
    Aaron
    I would add, if I am thinking about it correctly, to always remove the negative terminal first for the same reason and possibly cover the post before moving to the positive side.
  12. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    Turn battery switch off first before taking any socket or wrench to it. This disconnects the ground terminal of the battery from the chassis and should avoid the short circuit that you mention.
    Qavion likes this.
  13. dgoldenz94
    dgoldenz94 Formula Junior
    Apr 13, 2020
    647
    Las Vegas
    David Gold
    Get an Antigravity battery and never worry about it again, worth every penny.
  14. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
  15. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    You beat me to it :)
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    The switch in the front boot does not disconnect everything as their are aux grounds on the negative clamp, prior to the switch
    Danedingerson and Qavion like this.
  17. Qavion
    Qavion F1 World Champ
    14,279
    Ian Riddell
    Interesting. I haven't been able to find what the additional wire/s on the battery are for. On the early 360's, the alarm siren earth wire was hooked up to the battery (not via the cutoff switch).
    I've seen videos showing at least one additional earth wire on the F430, but the wiring diagrams don't show the siren hooked up to the battery.
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    One of mine might be the tracker system that all uk cars are fitted with.
    Qavion likes this.
  19. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    wow! they don't give those away! looks nice....
  20. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    BrettC likes this.
  21. Snapshift
    924
    Centralia IL
    Lyle D. Pahnke
    If that is the case, then the whole purpose of the battery cutoff switch is defeated. I don't believe this to be the case. If there is any remaining ground(earth) connection that bypasses the switch then effectively the battery is still connected. As Qavion mentions it is not on the wiring diagram.
  22. Danedingerson
    Danedingerson Karting
    Dec 26, 2011
    236
    Maui
    Dane
    I dont see the tracker on the diagram either. How can it work if the trunk switch turns it off? Easy for tow truck thieves.
  23. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    Uk cars have trackers as standard with their own batteries, it even alerts to jacking it up or battery volts, broken glass etc. The engine can also be shut off if it has been knicked
  24. Qavion
    14,279
    Ian Riddell
    Note that I only have wiring diagrams for the Scud. The regular 430 may be different. I thought I saw a wire in a recent Tavarish 430 Scud video, but after rechecking, I'm not so sure.
    Screenshot from the Scud video:
    The middle terminal is the main one which goes to the cutoff switch. I'm sure the only negative battery cable which is cutoff from ground is the middle one. I don't see why the little wire I've seen on the adjacent negative battery terminal (in the earlier link to a USA 430 video) would also go to the same cutoff switch.... Why have two wires?
    Not sure why this inserted image is appearing as an attached file:
  25. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,223
    CT
    John Kreskovsky
    Disconnect the ground terminal first, assuming it is accessible.
