Battery???? | FerrariChat
Battery????
Discussion in '365 GT4 2+2/400/412' started by tr0768, Aug 26, 2012.
  1. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    What size is reccomended for a 1982 400i ? I need to finally replace mone and the one in the car is undersize for the battery box. I wonder what size battery others are running?
    thnx,
    Howard Musolf
    1981 308gtsi
    1982 400i Cabriolet
    1994 348 spider
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I've always have seen Group 34 mentioned with dimensions of:
    10 1/4" Length X 6 3/4" Width X 8" High (incl. Posts @ 3/4"), I think that's about the largest you'll be able to squeeze in there.
  3. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,271
    MA
    That's the size that I have in my 400i. It is a NAPA Legend 75 Part # 7534.
    CA @ 32 deg F is 875 amps, CCA at 0 deg. F is 700 amps.
    Current price is $109
  4. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Kind of sounds like Jay Peterman from Pendant Publishing from Seinfeld. :D
  5. Ashman
    Sep 5, 2002
    33,271
    MA
    LOL! Everyone seems to have their favorite batteries and stories.
  6. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    yep
  7. jes-13
    jes-13 Karting
    Jun 9, 2006
    56
    California
    i'm using an Optima marine (blue top) group 34. It's been excellent considering the low usage... but that's the whole idea behind a marine battery. ;) plus there is no acid spills/leaks to worry about with the Optima.
  8. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I've always heard in the marine world that automotive batteries are used for the engine & marine batteries are used for house electrics. My understanding is that auto batteries are meant to be kept fully charged (via alternator) & marine batteries are meant to be cycled (drained, then charged).
  9. SCousineau
    SCousineau Guest
    Jul 17, 2004
    3,652
    S Cousineau
    After 9 years of ownership and who knows how long it was in there before I purchased the 400, my Interstate Battery has finally failed and it is time to replace it.
    Reading up on batteries on FerrariChat I found a couple references to the Odyssey AGM dry cells. This particular battery looks like it fits the group 34 specification and has 880CCA: http://www.odysseybatteries.com/battery/pc1500.htm
    The Group 34 Interstate MTP-91 is about 1/2 the list price:
    http://www.interstatebatteries.com/cs_eStore/Content.aspx?dsNav=Ntk~SearchGroup|batteries+automotive+mtp+91|3|,Arpp~12,A~Part+Number,N~21-2147384906
    I am wondering if anybody has experience to share with that Odyssey in a 400?
    I helped a friend install and Optima in a 348 and he was happy with it for quite a while.
    http://www.optimabatteries.com/us/en/shop/redtop/optima-batteries-8002-002-34-redtop-starting-battery/
    They appear to be a bit more than the Interstate.
    I am leaning toward a sealed solution as less acid sloshing about seams like a wise plan now that it is available.
    -sc
  10. jes-13
    jes-13 Karting
    Jun 9, 2006
    56
    California
    Marine batteries normally sit on board a boat or yacht, for sometimes long periods of time, before they are ask to crank the engine, usually Diesel. My limited experience is that they don't mind cranking at low voltage, were as a conventional battery generally is considered dead somewhere between 10.5 - 11.7 V ...
  11. SCousineau
    SCousineau Guest
    Jul 17, 2004
    3,652
    S Cousineau
    #11 SCousineau, Apr 24, 2013
    Time catch up on projects. Replaced the 400i battery today. The Interstate Battery shop around the corner had the MTP 24F's replacement in stock and it is now installed. Fits perfectly!
  12. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Yes Bruce...you a perfectly correct...... not even room left for an RCH. By the way.. the very last thing that you want to intentionally do, is try starting our cars on that low 10 volts, which is practically non- existent . Bad things happen. (I learned this first-hand). That is why marine batteries are specifically not intended for cars use. I am all ears as to learning of a smaller bat. size with the cranking power of the 34/78 group. Thank you. Jq.
