News
Battery
Discussion in '360/430' started by Edgar Diaz, Oct 11, 2014.
  1. Edgar Diaz
    Edgar Diaz Karting
    Sep 13, 2014
    188
    Alabama
    Edgar Diaz
    Hey Guys,
    Wanted to know if anyone is using the Odyssey battery in a F430? They show a PC1500RT 34R-PC1500. I would like to know if it fits in the car's space properly, if it performs well. It costs $275.00. Is it a vented or sealed battery. Really welcome your comments.
    neil e dale likes this.
  2. Randy B
    Randy B Karting
    Jun 7, 2013
    69
    Didsbury AB,Canada
    I have one in my 360 and it fits fine. Just have to grab some longer J hooks since the originals will be about 1" short. It is a AGM so no venting needed.
  3. 67427
    67427 Rookie
    Nov 30, 2011
    14
    Paradise (Florida)
    Guillermo FQ
    +1 I have one in my 360 some folks also swear by the 925T for the 430. Do a search
  4. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,248
    Colorado Springs
    Do you have a picture of what you did? Where did you get the longer hooks?
    my Odyssey comes in this next week.
  5. Randy B
    Randy B Karting
    Jun 7, 2013
    69
    Didsbury AB,Canada
    I didn't take any pictures. The J hooks are available at any automotive parts store. Think I paid 4 bucks for the pair.
  6. Edgar Diaz
    Edgar Diaz Karting
    Sep 13, 2014
    188
    Alabama
    Edgar Diaz
    Would you guys say that the odyssey battery is a better choice than other batteries? Like interstate and other brand names? If it is sealed and roughed, I would think would be better choice. Comments?
  7. Need4Spd
    Need4Spd F1 Veteran
    5,432
    Silicon Valley
    Most of us drive our cars only in nice weather, and otherwise keep the battery on a tender. So batteries in our cars have an easy life, never having to crank engines in sub-freezing temperatures, for instance. As such, most any good AGM battery will do, so long as the quality is such that it doesn't fall apart or short out. Choose an AGM because it won't leak from any reputable maker such as Odessey, Interstate or Sears.
    neil e dale and whatheheck like this.
  8. jpk
    jpk Formula Junior
    Oct 29, 2012
    793
    WA & NV
    I use the Sears branded Odyssey batteries (Sears Platinum) in my marine applications, they are compact and lighter weight than a normal lead-acid battery. The Sears versions don't come in a reverse terminal design necessary for the Ferrari, so you have to get the R model in the Odyssey brand. It is a good choice. I currently have an Optima in my 360, fwiw.
  9. Dougster
    Dougster Karting
    122
    Dallas TX Area
    I have the 34R-PC1500 in my 2007 430. Fits fine except I did have to go to longer J-bolts.
  10. Falcon Wing
    Aug 4, 2010
    1,248
    Colorado Springs
    I just installed my odyssey today. I bought 8" j bolts and ended up having to cut about 1/2" off to allow the foot rest to be reinstalled.
  11. mountainman3520
    mountainman3520 Karting
    Nov 11, 2013
    202
    Silicon Valley, Cali
    Dan Gilley
    Could you post photos of the install and fit?
    I'm going to order the Odyssey 34R-PC1500.
    It isn't a good idea to use the smaller batteries such as the 925T. It may work under ideal circumstances but that doesn't make it a good idea.
    Choose a battery with equal or better specs compared to the OEM battery. So look at capacity and CCA.
    Also it needs to have reversed terminals (34R, not 34) to fit well without mods in the 360/430.
    And it needs to be fully sealed such as the AGM or gel due to the battery location inside the cabin. Its okay to have an emergency pressure relief valve, which probably all AGMs do have. But this valve only opens to vent pressure if the battery is being overcharged or over heated and is about to explode. The traditional lead acid batteries continuously vent gas as part of their normal chemistry. I do not think its a good idea to use a continuously venting traditional battery and count on the vent tube to extract that gas or overflowing fluid from the cabin.
    Overall Ferrari battery philosophy: I think its okay to deviate from OEM for this frequently replaced item, especially since the OEM is difficult to obtain except from Ferrari. But it is a Ferrari, so its not a good idea to skimp on quality to save a few bucks or performance to save a few pounds.
    neil e dale and shifter like this.
  12. neil e dale
    neil e dale Formula Junior
    Silver Subscribed BANNED
    Aug 27, 2018
    367
    Tucson AZ
    neil e dale
    #12 neil e dale, Nov 6, 2018
    have been researching batteries the Odessey AGM has a stellar reputation among the off- road racing 4WD crowd ! many say it has lasted for 8-9 years ! and withstands really tough , brutal conditions ! it is very heavy . Amusingly, they say it is made of "virgin lead " which they assert is superior ( to recycled lead ? ) LOL I have a PC1200 R I will fit to my F430 [​IMG]
  13. SoftwareDrone
    SoftwareDrone F1 Veteran
    Silver Subscribed Owner
    Jan 19, 2004
    6,112
    San Jose, California
    I can say from firsthand experience that the Lithium batteries are fantastic. I have two Braille Lithiums (@ $1,100.00 apiece) as well as a full sized Optima red top in my car. The Braille's are on a solenoid and are only used when needed.
  14. neil e dale
    Aug 27, 2018
    367
    Tucson AZ
    neil e dale
    brilliant configuration why not use just the braille's ? racers do ! you could lose what 37 LBS !
  15. Doctor Mark
    Doctor Mark Formula Junior
    436
    Georgia
    Mark Gronsbell
    Lithium batteries may be great but the cost is great as well. Have one in my McLaren and fear the day it goes belly up (2-3K). For all out racing the weight savings may be helpful but for a street car I will go AGM at a fraction of the cost of a Lithium battery.
    whatheheck and neil e dale like this.
  16. neil e dale
    Aug 27, 2018
    367
    Tucson AZ
    neil e dale
    OhIi agree ! but for some ? $ is not an issue ! for them ? lithium is the way to go ! I have heard that the McLaren are quite expensive to maintain and no way can you DIY as they have dealer only limitations . ? I can do nearly everything on my Ferrari ! and am glad of it ! what a gift to a retired mechanic to be able to fix, fettle your very own Ferrari ! LOL
  17. Doctor Mark
    436
    Georgia
    Mark Gronsbell
    You are correct about maintenance being more difficult on a Mac due to limited options for parts etc. Sadly no Ricambi or Eurospares equivalents.
    This has been a disappointment to me as I enjoy turning wrenches but maybe with time it will improve.
    Ferrari is my first love but the pricing and games have been a turn off in recent years.
  18. SoftwareDrone
    Jan 19, 2004
    6,112
    This is what I need the lithium batteries for.
    I haven't had time to fabricate a fixture to hold another lithium behind my passenger foot well.
    F430Rod likes this.
  19. shifter
    shifter Formula Junior
    267
    Maryland
    Joe
    I use lithium batteries in motorsports but wouldn’t use them in my 430. I’ve had too many thermal events and sudden failures from vibration and deep discharge.
    For optimum performance they require special chargers and although some manufacturers suggest continuous charging from a traditional lead battery designed charging system is fine, you’ll be pressed to find an expert that would agree.
    Joe
  20. SoftwareDrone
    Jan 19, 2004
    6,112
    Braille wouldn't sell me their lithiums unless I also purchased their lithium charger. It has a small footprint and is easy to use.
  21. neil e dale
    Aug 27, 2018
    367
    Tucson AZ
    neil e dale
    Yes, the lithium do require a quite sophisticated BMS = Battery Management system ! - to forestall disaster! witness this A123 battery fitted to some MB cars !, EG the BMS is built into this battery [​IMG]
  22. DefunctNeurons
    DefunctNeurons Karting
    May 15, 2018
    106
    Atlanta, GA
    Trevor
    My 2017 BMW M3 came with a Lithium battery. I had to buy a CTEK lithium charger for it but it’s been great and is much lighter than the AGM battery my regular 335i had. However, the replacement cost is apparently around $1200 or so. Not looking forward to that!
  23. neil e dale
    Aug 27, 2018
    367
    Tucson AZ
    neil e dale
    #23 neil e dale, Nov 13, 2018
    PS as I live in the warm sunny Arizona in the Sonoran desert we can get away w/ a smaller battery! hence this PC 1200 will do fine! BTW my version of this battery even has a metal case ! as it was originally selected for fitment in a very hot Saab 9-3 Viggen turbocharged engine bay! ( the Viggen even has a dedicated cooling air vent hose fr the front to the battery box ! )
  24. neil e dale
    Aug 27, 2018
    367
    Tucson AZ
    neil e dale
    you could doubtless find a equivalent Lithium battery ( or two smaller ones ) for far less than the mac price !
  25. Doctor Mark
    436
    Georgia
    Mark Gronsbell
    Unfortunately the Mac has a third battery lead which makes it a Mac only system. It can be rebuilt but the cost is almost as much as a new unit. Supposedly the battery lasts the life of the car but frankly, I do not believe that story.
    Pay to play.
