I just bought a Red Top ultima from Automotive Superstore for about $150 less than the local supplier quoted. Free postage. Rolled up in a few days, and I installed it as per the Moretti battery installation video. Job’s a good’un.
Steve, do you need to buy that fancy machined aluminium base to install an Ultima? https://www.batteriesdirect.com.au/shop/product/13079/Optima Hold Down Tray.html
No, Ian. The battery comes with some hard plastic bits that you can use to “fill out” the existing tray and then it bolts down very securely.
Ok I've got the new battery in and put back the other stuff i had to remove to get the battery out.....now what ? what is all this about the system having to relearn ?
There’s nothing to relearn. Turn on the ignition, wait for the warning lights to go out after self check and start it up. Let it idle for about 10 mins then go for a drive. You’ll be good to go. Sent from my iPhone using Tapatalk
Giz is feeling a bit negative today. And you'd better stop generating all these puns, Horse gets solenoid.
