BB and BBi - wheel balancing and alignment w/vintage tires | FerrariChat
Discussion in 'Boxers/TR/M' started by NGTTwo, Sep 16, 2025 at 12:00 PM.
  1. NGTTwo
    NGTTwo Rookie
    Tuesday
    3
    Northeast
    Basel Basel
    I have a BB here which wears new but period correct XWX tires - 215/50-70 and 225/50-70 if I'm not mistaken. Tires are probably ~2 years old.
    Getting a front - right side vibration at around 60-70 mph and appears (?) to be tire related. I was surprised to see that none of the wheels have any balance weights on them.
    Does this seem incorrect?
  2. NGTTwo
    NGTTwo Rookie
    Tuesday
    3
    Northeast
    Basel Basel
    Sorry typo above 215/70-15, 225/70-15 for the tire sizes...
  3. bjunc
    bjunc Formula Junior
    Jun 18, 2023
    504
    Miami, FL
    Robert
    I would think it's more likely that you had weights that fell off.
    samsaprunoff likes this.
  4. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    Very rarely tires balance without weights. Then again, if you shift the tire on the machine it could change. I watched tire guy spin balance my DD tires on the machine. Drive it, and vibration at certain speed. Bring it back and get it rebalanced. Maybe his machine is the problem? Or like above, maybe weights fell off. There are some newer machines that balance with a type of road device!
  5. fatbillybob
    Aug 10, 2002
    29,272
    socal
    1- balance the wheel/tire combo
    2- check shocks
    3-check a-arm bushings
    4-check steering rack bushings
    5-check ball joints
  6. Dr Tommy Cosgrove
    36,599
    Birmingham, AL
    Tommy
    Nope.
    There is absolutely no possible way on earth that you have FOUR wheel/tires that require no weight balance.
  7. NGTTwo
    NGTTwo Rookie
    Tuesday
    3
    Northeast
    Basel Basel
    Thanks I have an appointment with a local expert on tires who will look at it...go through each wheel + tire, check whether there may have been internal balancing (?), and then check the suspension/alignment.
    Any tips from the experts here on the suspension setup other than what's in the workshop manual? We got the shims pack for the 1 - 3+ mm in steps of 0.5 mm just in case.
  8. bjunc
    Jun 18, 2023
    504
    Miami, FL
    Robert
    I'm not an expert, but I did just make some suspension changes so it's somewhat fresh in my mind.
    IMO, I think the factory specs are fine for most people. They are designed around the weight / spring balance of the car, for higher speed stability, and with some understeer.
    Personally, I'm running a little more camber (both front and rear), and a little less toe in the rear. I guess you can say it's a slightly more sporty setup than factory. Dialing in rear toe can be a little finicky because it uses shims; which impacts your camber. So I found that if you take camber tweaks into account before you set the toe, then the toe shim will push the camber the rest of the way there. Unless you're super picky, you probably won't notice or care about that though (we're talking tenths of a degree).
    NGTTwo likes this.
