BB lights on runs hotter | FerrariChat
Discussion in 'Boxers/TR/M' started by J.P.Sarti, Aug 15, 2007.
  1. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Drove my BB the other evening and noticed it running a bit warmer when I had my lights on, a bit past the middle mark on the temp gauge, the extra power drain must have slowed the fans down, granted it was a hot evening at 100' so if it was signifcantly cooler probably wouldn't have effected the temp as much, anyone else notice this?
    I would assume with BBis it wouldn't be as noticeable due to extra alternator helping out
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,468
    Canada
    Newman
    Well, my car never runs over 90 C but from time to time the gauge hits 100. Yes im contradicting myself, read on.....When my car reads 100 I tap the gauge with my finger, presto 90C again. My friend spent over $1000 going through his cooling system to solve the same problem I have only to find a tap of the gauge glass put the gauge back to 90 C LMAO, I rub that one in on the regular basis. :) Verify your engine temp is indeed what the gauge says, easy to do with an infrared temp gun. Perhaps not your problem but something to keep in mind.
  3. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    That brings back memories. My BB512i routinely ran 85-90c water temp on the hottest summer day. A few years back my BB512i started running a 95-100c water temp. I replaced the temp sensor, thermostat, had the radiators rebuilt... all with no change. A friend of mine then ask had I had the alternators checked...so, I drove the old girl down the Autozone where they plugged one of those electronic auto electrical system diagnostic machines up which showed that both alternators were bad. I had the alternators rebuilt at a local auto electric shop for about $200 each and my water temp went back done to 85-90c even in these 100f Georgia summer days...teh battery alone does not put out enough current to spin all three fans at fun speed...after the rebuilt alternators were installed you could hear and feel the air from the fans was much stronger...you can fly a kit over the front vents now! LoL...Ferrari's are odd machines...take you Boxer to Autozone, Pep Boys or NAPA and they will check your alternators in their parking lot for free..report back what you find...
  4. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    It might be your alternator, or it might be your fans too.
    My car started overheating a little last summer. Turned out the brushes in the fan motors were pretty well shot. There were still making full contact, but were so short I don't think the spring pressure was great enough to allow full voltage. After replacing the brushs the fans all ran with noticeably more gusto!
  5. thecarreaper
    thecarreaper F1 World Champ
    18,074
    Savannah
    many of my lesser v8 Ferrari's would have changes in the gauge readings with the lights on. i never worried about as it was a predictable change that i could duplicate during the day with the lights on.
  6. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    #6 Arvin Grajau, Aug 16, 2007
    nope,never had a issue.
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    This observation is spot on... Both the oil pressure and water temperature readings will increase by approximately a
    "needle's-width" or so, with the headlights on. My BB has done this for 20 years...and have seen this in many 308's, as well. The vehicle does not even have to be moving, or the engine running to see this oddity. Just one of those quirks that makes these cars so endearing...
    Regards,
    David
  8. Arvin Grajau
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    they are so underated IMO,great to drive with all that noise and drama.
  9. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Aftermarket fans are not necessary. If everything is working as designed, a Boxer or any other Ferrari for that matter will not run hot at all. My BB512i water temp runs ~90c even on these recent 100f+ Georgia summer days with OEM fans...unless you are racing it, if a Boxer needs aftermarket fans you must have some other problem that needs repair. I would not mask that problem with aftermarket fans...just my HO...
  10. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    The temp increase was real it seemed, I would say 1/8" past the middle of the gauge, as I reached an area where I could drive faster about 50-60mph steady the temp cooled back down to close to the middle of the gauge.
    I had ran a jumper in the fuse box to keep the 3rd a/c fan on all the time and this kept the car cool in the highest temps above 105' when in traffic, that fan began rubbing against a piece of radiator shroud so I disconnected that fan awhile back, since I moved out to the country I haven't had a cooling issue since I don't have stop and go traffic anymore in the extreme heat, this was the first time in over a year I drove the car at night with lights on, so quite a temp increase with them on, btw all the fans were rebuilt by me a few years ago so they are okay
  11. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,533
    Tuscaloosa, AL
    Drew Altemara
    On my BB512 my gauges go up around 10% when I put the lights on. I believe that this is just due to the old grounding of the instruments behind the dash ro maybe the gimpy rheostat. One of these days I will pull the dash to recover it. When I do I'll make sure to clean these points. For now it's just not a big deal.
    As a foot note, my Daytona's ammeter use to swing wildly until I went through the entire car and cleaned every friggen ground and major connector. Took a day. But now the gauge is rock solid.
    Drew Altemara
  12. Newman
    Dec 26, 2001
    14,468
    Canada
    Newman
    I wish I could see my gauges at night, I just look for the glowing red ball in the fuel gauge area of the dash and know I at least wont run out of fuel. As for temp and other readings at night, I need night vision goggles or I need to make the lights brighter.
  13. Drew Altemara
    Feb 11, 2002
    1,533
    Tuscaloosa, AL
    Drew Altemara
    I think that's the rheostat. John Corbani in the Dino section had a good post about why the interior lights on these period cars as so dull. Basically, you can modify the rheostat so that contact is made more directly when in the full position. For the heck of it, pull the tach and short through the rheostat by connecting the two wires. I bet you will be amazed how much brighter the interior lights are.
  14. Newman
    Dec 26, 2001
    14,468
    Canada
    Newman
    I plan to, the time is the problem, the 308 suffers the same problem - great italian wiring and switches.
