BB512 on Jack Stand to prevent Tire flat spot??? | FerrariChat
Discussion in 'Boxers/TR/M' started by Arakis36, Oct 27, 2017.
  1. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Ciao Amici
    Wondering if it is wise to put a BB512 on jack stands for seasonal storage (6-8Months) in order to avoid flat spot on the Michelin XWX tires... (Aware of the correct car lifting procedure)
    - Worried that using the frame as support for jack stands, may put stress and flexing the cage.
    - Considered 2 options:
    1) - If deemed OK, Lifting and putting car on jack stands using frame as support
    - To avoid having suspension hanging: Lifting it with Jack, then placing wood blocks under tire.
    2) Lifting car, then placing jack stand right under suspensions with special built wood block adaptors,
    then lowering car. Advantage: suspension remains loaded and not hanging while tires are
    off-ground. Issues: not sure if putting jack under suspension control arms is safe.
    Anyways, mainly interested in any advice to avoid tire flat spot when storing car with tires on...
    Molto Grazie
    Carlito
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,528
    romano schwabel
    I would it do like number 2
    but I would built a special adapter to put under the (mozzo per ruota - 103119, 103120, 115971 and 115972, ) front and rear wheel hub after removing the wheels
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,949
    The Cold North
    Tom
    Why not just over inflat the tires? Pump 45-50psi in there and you will not flat spot.
    Melvok likes this.
  4. dwhite
    dwhite F1 Rookie
    Why not just start the car and drive it when weather permits. It will cure many ills, the most obvious being the enjoyment of driving the car and as they are more comfortable to be in during colder weather, I try and get mine out as it helps me to cure the winter blues. :)
  5. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Yes also considered this option, since simple. But haven't heard if works well
  6. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Of course that's always the best option, unfortunately winter weather does not permit
  7. TerryG!
    TerryG! Karting
    Feb 12, 2017
    155
    Central UK
    A commercial storage company that I have used has all car's tyres at 45 psi while in store. They have been in business 40 years and the place is full of really high end vehicles.
    I'm prepared to take that as 'evidence' in favour of this solution.
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,263
    Mel
    Best way imo :D
  9. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
  10. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Yes I agree, after thinking it over, this seems the best, simplest solution
  11. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Thanks. Very interesting, after consideration, I will use this method...
