BBi engine rebuild | FerrariChat
BBi engine rebuild
Discussion in 'Boxers/TR/M' started by Newman, Nov 10, 2023.
  1. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,450
    Canada
    Newman
    This engine is pretty original other than the usual EO services over the years. Reliability was the main concern so the goal was to replace the exhaust valves as a preventative measure before a head falls off one, perform the service and clean it up, detail etc.
    Leak down numbers showed 38% past an intake valve (lash setting was fine) and 8-10% being a combo of other valves and ring seal. Oil consumption was another symptom.
    ItalianOne likes this.
  2. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    scudF1 likes this.
  3. boxerman
    boxerman F1 World Champ Silver Subscribed
    May 27, 2004
    19,732
    FL
    Sean
    Going to do pistons cams and valves?
  4. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,810
    How many miles? Was all of the pitting at the "bottom" surface of the cylinders (condensation drops rolling down and sitting at the "bottom")?
    turbo-joe likes this.
  5. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    Looks like moisture, reminds me of one I did that lived in Hawaii and had a lot of pitting, oil consumption.
    No cams. Doing pistons of course and valves.
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,532
    romano schwabel
    and sleeves of course?
  7. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    Boring them oversize not replacing
  8. turbo-joe
    Apr 6, 2008
    9,532
    romano schwabel
    but for this you have to take them out. I once tried to bore them to oversize ( had at that time the machines). first was working, but the second one started to turn. so I took them all out and put in new ones with std.
    would it not be cheaper to take new ones? labor is the same.
    so put in higher compression pistons?
  9. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    They have to be taken out to properly rebuild the engine but they get put back in and machined in the block with a torque plate and a head gasket to simulate an installed cylinder head. The sleeves change shape when under compression so for the best results they need to be machined under those conditions.
    I'll up the compression ratio a little bit for an increase in torque.
  10. turbo-joe
    Apr 6, 2008
    9,532
    romano schwabel
    you are right paul. but I bored the sleeves outside, put them in then and honed them inside.
    good idea with the headgasket and a torque plate ;)
  11. Threeofnine
    Threeofnine Formula Junior
    Dec 11, 2020
    399
    Birmingham, AL USA
    Jarrod Heath
    Out of curiosity, about what would this cost?
  12. turbo-joe
    Apr 6, 2008
    9,532
    romano schwabel
    much much money - but worth every cent when doing right
  13. turbo-joe
    Apr 6, 2008
    9,532
    romano schwabel
    but only with very low "pressure" that the sleeves will not turn
  14. Threeofnine
    Dec 11, 2020
    399
    Birmingham, AL USA
    Jarrod Heath
    I would guesstimate $40k? Hopefully it will be a long time before my TR needs an overhaul.
  15. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,028
    New main bearings? Another 'while you're in there' event?
  16. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,028
    How do you torque those nuts for the mains? Looks like limited space.
  17. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,028
    Diff carrier?
  18. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    It already has one of my diffs in it but it was set up incorrectly wherever it was installed. Backlash is .012" and no preload by the feel of it so I'll tighten that up and check the pattern.
    Here's one I took out of a car, didn't look broken until I undid the left side support and it spread open. I'm making another batch of diffs because I've had some requests.
    I have a tool I made that's 2" long with a box end wrench end and a 1/2" drive for the torque wrench. It changes the actual torque setting I use because of the 2" added length.
    samsaprunoff likes this.
  19. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Agreed - my 78 had rust on the bottom of a few cylinders. It ended up being more cost effective to buy 12 new cylinders at stock bore size and install quality HC pistons. The car is as quick as my TR now.
  20. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,818
    Bologna
    Memories. I can vouch for Newman’s differential carrier. Installation in the TR was easy and the pattern was perfect, once Romano sent me a shim. Thanks again to both of you.
    EZORED, Newman and turbo-joe like this.
  21. 4right
    4right F1 Rookie Rossa Subscribed
    Sep 14, 2008
    2,966
    US/Japan/Singapore/Canada/US
    Like the new wall art!
    Newman likes this.
  22. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    Before pulling the engine I noiced the 2 groove a/c pulley which isn't right for a boxer. Check out the misalignment.
    I need a single groove, if anyone has one shoot me a pm please.
  23. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    Ferraripilot likes this.
  24. Rifledriver
    37,103
    If they are not honed with full torque on the torque plates it is pointless. BB cylinders balloon in the middle when under full pressure and will never seal well. One of the reasons for their well known smoke and oil consumption issues. That and the terrible rings and pistons used back then.
    Newman and Ferraripilot like this.
  25. Ferraripilot
    Ferraripilot F1 World Champ Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    Do you remember about how much the distortion was in the middle? Half a thou or so? Just curious for documentation purposes.
