BBi frunk panels removal | FerrariChat
Discussion in 'Boxers/TR/M' started by bjunc, Sep 6, 2024.
  1. bjunc
    bjunc Formula Junior
    Jun 18, 2023
    458
    Miami, FL
    Robert
    Hi all,
    I think I know the answer to this, but as I work on the upgraded radiator setup and electronic AC, I'd like better access below the fiberglass covers.
    It seems the side "Bonnet Panels" (the ones that mount to the wheel arches) would serve the least benefit to remove, as well as the most visually obvious. It seems the biggest benefit (to me) would be removing the spare wheel related panels, but I'm not sure you can do that without also removing the side panels.
    Are there any tricks / tips I should know about this? Other than working from underneath, it seems removing the numerous rivets is the only way to go?
    Thanks in advance.
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,465
    Canada
    Newman
    Post a picture of what you're talking about
  3. bjunc
    Jun 18, 2023
    458
    Miami, FL
    Robert
    In the diagram, I'd like to remove parts 5 and 18 (spare tire carrier / cover). It seems they are at least riveted to parts 3 and 4; which are riveted to the wheel arches; which is coated in the texture that looks like LizardSkin. Not sure if it's an all-or-nothing kind of thing.
    Thanks Paul.
  4. pshoejberg
    pshoejberg Formula 3
    1,827
    Denmark
    Peter H
  5. pshoejberg
    1,827
    Denmark
    Peter H
    The panels are all mingled together so you need to carefully drill out and remove all rivets and remove all involved panels. Big job but perfectly feasible.
    best, Peter
  6. pshoejberg
    1,827
    Denmark
    Peter H
  7. bjunc
    Jun 18, 2023
    458
    Miami, FL
    Robert
    Thanks Peter, this pictures are especially helpful. You confirmed my suspicion that there really aren't any shortcuts with this.
  8. bjunc
    Jun 18, 2023
    458
    Miami, FL
    Robert
    @pshoejberg I removed most (all?) rivets. The side panels came right off. The middle panel (the big one, aka "spare wheel carrier") doesn't want to budge. My car ('83) has a lot of thick light gray adhesive on the center panel, all around the bulkhead area. Did you have that too? I don't see it in your pics. Trying to resist the temptation to go medieval on it...
  9. pshoejberg
    1,827
    Denmark
    Peter H
    Removing the glassfiber panels from these old Ferrari's take's some nerves, force and occasionally also some cutting to get the panel free from the geometry of the steel frame. There are basically rivets on all 3 the sides of the wheel carrier. Some of them are hidden by a thick layer of flexible "adhesive" as you call it. Against the bulkhead you also might find some glassfiber matt's that you need to cut and move as I recall it. I have hundreds of pictures from my adventures some years ago and below is a few more from the assembly process. Note that there is no rivet holes along the edge of the carrier at this stage in the assembly (All my glassfiber was repaired and holes re-drilled later).
    Best, Peter
  10. pshoejberg
    1,827
    Denmark
    Peter H
  11. bjunc
    Jun 18, 2023
    458
    Miami, FL
    Robert
    Thanks Peter, that's all very helpful. By the way, looks like you did a great job on your restoration. A lot of attention to detail.
    pshoejberg likes this.
  12. bjunc
    Jun 18, 2023
    458
    Miami, FL
    Robert
    Wrapping this up for future readers. I was able to remove all of the frunk panels. The glue / adhesive was not the main culprit for the stubborn panels, but rather many haphazard / hidden rivets. Eg, the RH corner (near the bulkhead) had 8 randomly placed rivets.
  13. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    Fiberglass is easily repairable, so should be no problem.
