bbi Servicing Questions | FerrariChat
Discussion in 'Technical Q&A' started by muttsjet, Jul 4, 2022.
  1. muttsjet
    muttsjet Karting
    Nov 9, 2003
    74
    Getting car back up to speed and need some assistance:
    oil type - is Mobil 1 best alternative
    oil plug torques
    --pan ??
    --sump ??
    Brake/clutch fluid - DOT3/4??
    Tire alternatives for original TRX rims
    -- orig 240/55VR415 x 4
    -- other options
    --- read on forum the following for bb, but will they fit bbi
    Pirelli P600 235/60-15 (W speed rating) tires on the front
    Pirelli Scorpion Zero 255/60-15 (V speed rating) tires on the back
    Thanx much...
  2. Steve Magnusson
    26,839
    If you have 415mm wheels, you must use 415mm tires (not 15" nor 16"). Longstone Tyres may be your only option for 415mm tires (not cheap):
    https://www.longstonetyres.co.uk/240-55r415-michelin-trx.html
    The other option is to go to an (aftermarket) inch size wheel set. Search for prior threads.
    George Vosburgh likes this.
