BBQ's (Again).......Damn you Darth! | Page 2 | FerrariChat
Discussion in 'Other Off Topic Forum' started by PeterS, May 4, 2008.
  1. PeterS
    PeterS Five Time F1 World Champ
    52,655
    Goodyear, AZ
    PeterS
    DARTH! Post a link to the DEEEET-DEEET-DEEET vid :D
  2. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    :D
  3. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    #28 BT, May 6, 2008
    No, but the smoker I got is by the same company. At only $69 it is a little down on the totem pole...
    The one I got is called the Brinkmann Gourmet Electric Smoker or something like that. A pic is attached.
    :D
    BT
  4. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
  5. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    I had a birthday yesterday: best present ever, my very own Big Green Egg!
    Life is worth living again.
  6. GuyIncognito
    GuyIncognito Ten Time F1 World Champ
    100,344
    happy birthday Uro!
  7. anunakki
    anunakki Seven Time F1 World Champ
    79,685
    Las Vegas Nevada
    Jerry
    Happy Birthday ! Did you cry ?
  8. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
  9. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    #34 Dcup, Jun 8, 2009
  10. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    Nice! :)
  11. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    Congrats!
    A couple pointers--don't bother with the expensive Big Green Egg lump charcoal. I've been getting mine for 1/2 the cost at Fresh Market. Whole Foods has some decent stuff too. When you get the fire going, make sure it is evenly lit, otherwise you'll have hotspots. Once the coals are burning you can stir them a bit to even out the fire. Make sure your first slow cook is a pork butt. Takes 16-17 hours, but totally worth it! Invest in the cast iron grate and a platesetter for the slow cooks.....
  12. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,479
    SFPD
    Dirty Harry
    #37 wax, Jun 9, 2009
  13. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
  14. Ike
    Ike F1 Rookie
    Nov 4, 2003
    3,543
    I have been thinking about buying a BGE for a while now too. Went and looked at them they had the small one in the shop I think I would need the larger one. I have also looked at gas grills but most of them seem to be built pretty poorly, they don't feel like they will hold up. The lids wiggle and are thin and don't seem like they would hold heat in either.
    I like to cook with apple and hickory and rarely use charcoal. For those of you with the BGE does it work well with wood in it? Does the wood have to be chopped up small?
  15. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    I use the chunks. You don't need a lot of wood.
    If you want the smoky flavor from the wood one trick is to soak a few chunks in water overnite and throw them on top of the coals a few minutes before you start cooking.
  16. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    #41 UroTrash, Jun 9, 2009
  17. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    Thanks for the tips.
    Do you have to add any extra charcoal when you go 17 hours?
  18. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    You'd have to, I reckon.
  19. GuyIncognito
    100,344
    a urologist eating asparagus, now that's funny :)
  20. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    Nope! You'd be surprised at how much is left. You get the fire going as usual, then throttle the egg way back. Since you're doing a slow cook you are shooting for a dome temp of 210-220. There are some pointers you should follow, like sorting the charcoal and putting the larger pieces at the bottom of the egg. The main issue during a slow cook is temperature control. I usually start the cook at night and get up every few hours to make sure everything is working properly. As long as the airflow is ok the egg will stay on a slow burn.
  21. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    It would be even funnier if he was a proctologist since he had corn. :D
  22. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    By the next day you must have a ring of neighbors surrounding your yard after sleepwalking there with forks in hand!
  23. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    Well, when you do a pork butt, you have enough to go around, the things are about 8lbs. We like to shred the meat and serve it on a bun with some BBQ sauce, pulled pork style.
  24. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    Sounds like our wives both have great taste in b-day gifts. I got mine back in November.
    You absolutely must cook a nice steak on there, if you haven't already. My local BGE store has a steak seasoning that is quite good. Get a couple (or however many people you want to feed) of thick filets and coat them liberally with the seasoning. Get the Egg up to 550 degrees and cook the steaks for 3 minutes at a time, flipping 3-4 times total (9-12 minutes of total cook time) depending on thickness and desired internal temp. Best steak ever!
  25. darth550
    Jul 14, 2003
    61,183
    In front of you
    BCHC
    Have you tried one at 800 degrees?
