BCD Fuel Pump Rebuild | FerrariChat
Discussion in '206/246' started by Ducati348, May 22, 2019.
  1. Ducati348
    Ducati348 Karting
    May 15, 2009
    80
    Dallas, Texas
    Alex Scroppo
    Does anyone have a source for rebuilding a BCD fuel pump or a source for buying a rebuild kit or a rebuilt BCD pump?
  2. swift53
    swift53 F1 Veteran
    BANNED Rossa Subscribed
    Nov 17, 2007
    8,110
    E.S.
    Alberto
    Have you tried disassembly, and see what's inside?
    BCD still exists in Italy, and might have the kits.
    Regards, Alberto
  3. racerboy9
    racerboy9 F1 Rookie
    2,635
    I would take the bottom plate off first keeping the bottom facing up so as not to lose the little vanes from their slots. If you can turn the rotor freely, I would put the plate back on and give it a quick bump with 12 volts to see if the motor turns. Sometimes they get gummed up or stiction from setting unused for too long. I had a NOS pump that wouldn't run and I did the above and away she went.
  4. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    469
    Silicon Valley
    Mark
    Search for BCD Corona in earlier threads - I posted a set of photos for disassembly, cleaning, and reassembly a while back, as have others...
  5. swift53
    swift53 F1 Veteran
    Nov 17, 2007
    8,110
    E.S.
    Alberto
    Got 15 results, but none was on a rebuild.
    Mark, yours was not there.
    Regards, Alberto
  6. mar3kl
    Nov 17, 2011
    469
    Silicon Valley
    Mark
  7. swift53
    swift53 F1 Veteran
    Nov 17, 2007
    8,110
    E.S.
    Alberto
    Thank you Mark :)
    Regards, Alberto
  8. Ducati348
    Ducati348 Karting
    May 15, 2009
    80
    Dallas, Texas
    Alex Scroppo
    Thanks for the useful information. Much appreciated.
    Alex
  9. Ducati348
    Ducati348 Karting
    May 15, 2009
    80
    Dallas, Texas
    Alex Scroppo
    I found a used BCD pump on the internet and followed the procedure on taking it apart and putting it back together. It was actually quite simple. The pump was filthy and making all kinds of noise before disassembly. I spent a few hours removing the dust from the motor and soaking the mechanicals in lacquer thinner before thoroughly cleaning all the bits and reassembling the pump. The pump sounds much quieter and pumps perfectly. The only thing missing is the BCD sticker which is proving very difficult to find. Attached is a picture of the finished product. I’m now ready to remove the pump from my car and repeat this process. The good news is I now have an extra fully functioning pump just in case. Thanks for all the assistance.
    Cheers,
    Alex
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,201
    Norfolk - UK
    Tony
  11. mar3kl
    Nov 17, 2011
    469
    Silicon Valley
    Mark
    @Ducati348, check your private messages...
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Let me know if Steve is out, 6 months ago my friend, Donnie Callaway, was restoring a Boxer and asked the same so I turned him onto Steve and Donnie bought what he needed.
    I did buy a bunch from Steve in 2016 so not sure now.
  13. Ducati348
    Ducati348 Karting
    May 15, 2009
    80
    Dallas, Texas
    Alex Scroppo
    Thanks. Mar3kl was kind enough to send me information to make a sticker that worked perfectly.
    Alex
