Hi I would like to know whether it's possible to find a "bearing roller" ("roulement a billes" in french) for one of my rear wheels. It makes some noise and would like to know references of it if it exists outside Ferrari. Thanks a lot Olivier
Hi Olivier Check out this thread, there are bearing part numbers in there: http://ferrarichat.com/forum/showthread.php?t=64460 Gerrit http://dino308gt4.com
Thanks Gerrit I found this on the link you gave me : WHEEL BEARINGS, LARGE (REAR) SKF 62208-2RS1, SKF 101221 Does it mean 308 GT4/GTB and 328 GTB/S have the same wheel bearings references ? Did someone try to change its bearing on a GT4 ? Thanks a lot Olivier
there are two bearings per side on the rear. the inner one is SKF 62208-2RS1 the outer one is SKF 62207-2RS1 Best Regards from Germany Martin
