Beechcraft Duke Purchase | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by dmark1, Dec 18, 2008.
  1. dmark1
    dmark1 F1 World Champ
    BANNED Owner
    Feb 26, 2008
    11,439
    Americas Team Headquarters
    Mark
    Thanks, I would appreciate the information. I have also expanded my search to a Superstar 700P (Aerostar conversion). I am familiar with Aerostar and love the quality build of the
    airplanes, but it is very hard to pony up 160K + my airplane for a bird that looks almost identical to what I already have. I think that the engine out capability of the 700 will beat anything
    piston powered however,,,,
    Right now it is (1) DUKE (they are like a stripper, all looks and you know your gonna have problems, but JEEZ, do you see how she looks!)
    (1a) Aerostar 700P (Fitness chick, hot, great body, but been there, done that)
    (2) Cessna 340 with Ram VII conversion (Good looking gal that is more reliable than the others, but will my eye wander when I have her?)
    Turbines are out,,, too expensive.
    Any other suggestions out there??
    Mark
  2. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Mark:
    I have a bit of time in one of them. A buddy of mine has one, and I've got 50 - 100 hours in his. DONT BUY ONE!!!!! The engines have major problems, the cams get eaten. If the engines don't have the latest oiling system, you can plan on a very short TBO, and at 60K per side, it's an expensive proposition. There is a fix with lifters, but it isn't STC'd as far as I know, so it might be an illegal solution. End result, with a 1600 TBO, and with major problems with the engines, it will cost a lot to run this plane. They are ground hogs, require much more runway than the books say, don't climb well. I've seen as high as 300 kts in his plane, but we had a great tailwind that day. Generally expect 220 kts cruise in the low 20s. If you have to get pressure, look at a 58P, one with the 325HP engines, not the 310s, and a 79 with the better pressure system.
    Art
  3. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Thanks Art for your information. I have checked into the cam problem and it has been solved by the Firewall Forward Centri Lube cams and the new carbon tipped lifters. The aircraft I am considering has both (yes they are STC'd) as well as the pre- oilers. I have talked with 5 different owners of Dukes (not ones for sale) and they told me that they have NEVER (!!) failed to make TBO with these engines as long as they are operated properly. One owner even went to 2500 hours before overhauling his as he had no oil consumption and his compression remained in the high 70's. The 58P does nothing for me. Kind of like looking at a Ferrari and buying and Aston Martin. Does your friend have problems with his engines? What other problems has he had with the airplane. As far as climb capability I have been told 1000 FPM to the high teens does this sound about right? It seems to be coming down to Beech Duke vs. Aerostar 700. Both have the same fuel consumption with the Aerostar about 30 knots faster while giving up some cabin comfort.
    Thanks for your help
    Mark
  4. lzjrviper2006
    lzjrviper2006 Rookie
    Jan 3, 2009
    1
    I DO own one with Firewall Forward conversion and disagree with Solofast. It is probably one of your best choices for an affordable pressurized twin. You won't find the interior space, solid engineering and payload for anywhere near this price point. YES, it will cost more to maintain. Parts are getting harder to come by so the prices are higher than you would expect. Also, fuel burn is more like 55 gph. Everything else you've read about performance is correct (assuming it has VG's). Average speed, no wind, is 210 - 220 kts. Cold weather performance is solid. The $100/hr maintenance may be a little low. As someone said, it'll have a great deal to do with how many hours you fly it. The Aerostar won't give you near the interior room and if you intend to fly into known icing you're far better off with the Duke.
  5. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Well I got to fly my first Duke today, after all that looking. My impressions were that it was a solid Beechcraft airplane with a lot of interior space and good quality finish. I was surprised at how well the airplane
    climbed ( although a cold day 500 lbs. below gross) 1400 FPM. I was also surprised at how much fuel it ate for the speed you got. While we didnt' go over 12000 feet the fuel flows were around 50GPH for a 200 knot cruise. Not so good...
    The airplane flew like a Lexus drives,,, smooth and without many flaws. I am not sure how it is going to stack up against the Aerostar ( I fly it tomorrow) but I will keep every apprised if they care.
    Mark
  6. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    #31 dmark1, Jan 6, 2009
    Went completely off the track... bought a 1974 Mitsubishi Mu2K!! The guy selling it has 10 of them operating them in a charter business.. Very nice and reputable guy with a LOT of good information about these fine airplanes. Although
    the reputation of the aircraft scared me, he showed me how most of the problems that have been associated with it are as a result of operator error and that thorough good training solves that issue.
    As a professional pilot, this is the best of all worlds.
    280 Knots at 75gph with brand new motors...
    AHHHEEEEEEEEEEEE
  7. donv
    donv Two Time F1 World Champ
    26,394
    Portland, Oregon
    Don
    I've never flown an MU-2, although I have quite a few friends who have lots of time in them. They all say it's a great airplane provided you are trained properly, keep ahead of it, and respect it's limitations. It is not a forgiving airplane in any way. It will bite hard!
  8. jgcferrari
    jgcferrari Formula Junior
    926
    Jose
    The MU is a great plane, but as Don said, be sure you or your pilot gets the best training possible, these planes have been also quite controversial due to the difficulty in flying them, and I remember having read
    somewhere that there was and investigation by the FAA that determined that the MU meets all the safety requirements, and that many of the accidents have been mostly due to the pilots inexperience with this
    particular plane.
    Have fun with your new plane and be sure to fly safe
  9. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Scheduling time with Professional Flight Training (Mu2 Specialists) in Salinas for Initial Training next week . !2 hours in cockpit and 32 hours ground school. Should be fun!
    Mark
  10. donv
    26,394
    Portland, Oregon
    Don
    Why not simulator training?
  11. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    As an airline pilot, I see enough simulators in a year. I feel that the level C simulator (at best) provides a poor representation of aircraft feel and
    that as a new MU2 pilot I will be better served by training in my own aircraft. The simulator is excellent for procedures such as ILS, SE work, etc. etc. but
    does not give a true picture of how the "airplane flies". Since I already undergo sim checks every 9 months, I feel that the actual airplane work will be a better
    intial training experience, at least in this airplane.
    Mark
  12. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Delivery scheduled for the 14th pending a pre buy at Intercontinental Jet
    Into the fire from the frying pan???
    Mark
  13. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    I can endorse this from my experience of both aircraft. I had a 4th owner Duke in the mid 80s and still know the guy who owns it. He says maintenance is $100 per hour plus a reserve of $25 per hor for contingencies. And he ahs plenty of these because he has older steam powered avionics. If the plane you are looking at as a panel and a/p that was fitted no later than late 90s you may be able to get away with $100 plus 10% per hour. As many have said, this is a marginal twin at gross +20. But like Ferraris, if you consider it a 2 seater plus bags you will be able to operate it relatively freely. Its once you add the 3rd or 4th that your range/payload on any type of FAR 25 derivative gets to become hopeless. I also had the 700 -3rd off the production line and first international delivery. It has contra rotating (the wrong way) props which makes it less noisy than the 602P but its still noisy and consideraly more than the Duke. Parts costs were Duke prices in 1985 when mine was delivered and given the tiny number produced, I have to believe that it will be a difficult plane to support today without a lot of Aerostar tribal knowledge. Mine tued out at a shade of 230 kts at ISA +5 usually at FL 170 and was slower as you went higher. But still a lot faster than the KA 90 with whom we used to race from time to time. It was as quick as the 200s in our area and if you stayed low it was faster than the Cheyenne III but not the IIIA or IV. Motors were hard to keep cool and like the Duke be very careful to make sure the baffles are all 100% intact inside the cowling.
    I realize you have probably pulled the trigger by the time this is posted, but what the h...
  14. vlamgat
    Jan 9, 2004
    776
    Sorry about the late post of my earlier. Good decision the MU2 IMO - badly maligned by inexpereinced KA 90 drivers. Just becareful of those 331s. They take some care to operate, nothing like the plug and play of the JT8 or the PT6. But very efficient with some good upgrades. And with this you will not have to worry quite as much about that engine out at V2 which a Duke or 700P just assume you can figure out with an overspeed t/o.
  15. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    Did you buy from Air 1st??
  16. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Yes I did. Mike Laver is a prince of a guy.
    Mark
  17. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    Did you research the one in Nashville, TN for $399?? Just wondering if you had the scoop on it.
  18. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    #43 dmark1, Jan 13, 2009
    YEs I did, as a matter of fact I looked all around the country but found this one to be the best one for the money. 1900 SNEW engines with
    0 time hot sections and gear box inspections + the relationship I have built with the seller (Mike Laver - one of the best in the business!) gave me
    a comfort factor that I was unable to find with any other dealer/owner. The airplane has an impeccable record, is one of only 3 airplanes that have
    an aux tank (400 gallons usable!) and has been gone through stem to stern.
    I am attaching a picture.
    Best
    Mark
  19. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    Beautiful!!!! Let me know when you fly it long distance and how you like it.
  20. WJGESQ
    WJGESQ Formula 3
    Dec 30, 2004
    1,477
    So can a C55 Baron. With no problem.
  21. Tcar
    Tcar F1 Rookie
    Look, ma... no ailerons!
    Great choice.
  22. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    #47 cheesey, Feb 4, 2013
  23. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    #48 dmark1, Feb 7, 2013
  24. boxerman
    boxerman F1 World Champ
    19,994
    FL
    Sean
    After seeing this thread I read as much as I could on the MU2. Some fllight tests seem to indicate that if you loose and engine at liftoff with gear and flaps it wont climb. Seems most of the reposts show it will climbl slowly from 100ft with gear on the way up, so is between ground and 100ft a huge danger zone? Also reports seemed to indicate that the 331's are far less relaible/prone to flamouts than a PT6.
    Please forgive the ignorance of my post, I am not apilot but an aeroplane buff. A MU2 starts to make sense as personal aircarft as it has speed, range and comfort on par with a commercial jet, for a price that one can actualy see swinging. Everyhting else in this range is either piston and small with little payload to really be useful.
    I know of course maintanance is a cost as well as hangerage and fuel, so what is the cost factor per hour. Can some costs be balanced with chartering or is that false economy. Have any of these planes been upgarded with glass cockpits, is that worthwhile. Are they really noisy inside.
  25. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    the transition to a clean airplane from take off can be a bit unnerving from all the drag when one is not used to flying a MU-2... not an issue if one does it by the book...
    the Garretts are a good engine and not an issue... if there is a problem they need to go to an authorized Garrett service center which may be away from the home field, where as the PT-6 can be worked at a lot of shops ( the flameout issue is most likely from lack of maintainance, the igniters will wear and not deliver... possibly related to service centers being away from home field )
