Belt Change and lift question | FerrariChat
Discussion in '308/328' started by millsj, Dec 27, 2016.
  1. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    The 328 is due a belt change. I have never done one and have been reading up on all the how-to's out there. I have a general sense of what needs to happen, but I am sure I will have questions once I start digging in.
    My question is related to a lift. I am looking to get a 4 post left in the near future and was curious as to if it would be easier to do the belt change on a 4 post left or on jack stands. With the lift, I could obviously raise the car to a better working position and have the car on jacks stands/trolley jack on the lift to raise it to remove tires. However, I could see the skids sort of being in the way. Jack stands (on the ground) give you great access to the wheel well, but you are working on the ground.
    Any thoughts?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    I just did a 328 timing belt thing totally on the ground, and I have a lift. It turns out 95% of what you need to do can be done with the car on the ground, on jack stand, and with the lid removed. 80% of the work is done from above.
  3. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    The belt change is relatively easy. The hard part with the Ferrari is access. Having adobe it from the ground having a lift would make it much more comfortable. Imagine taking the wheel off stooped over or at the perfect height. Not too high, not too low. Just right.
  4. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    I did the belt change on my 308 with it on my 4 post lift - it was easier than just using jack stands, in my opinion. There were plenty of tasks performed through the right side wheel well, that having it at standing height rather than just off the ground was a big advantage.
  5. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    No need to lift the car other than to remove the wheel. No need to remove rear deck. Easy. You can sit on a crate and its quite relaxing :)
  6. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    Thanks for the responses. Looks like about 50/50, so it sounds like it doesn't make much of a difference. First I need to get the lift for this to even be an option.
    I'm going to continue reading and come up with a game plan. I can be a little tough to keep the "while you are in there" list under control. Last year, most of the coolant lines were replaced, so most of those are done. I do want to replace some of the coolant lines around the water pump. I saved those for when I was doing the belt change. Seems like last year I was working on the driver's side of the motor. This year, it is the passenger side.
  7. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    If you are contemplating just a belt change then removal of the lid is not required. But if you want to do a complete major with valve adjustment, then life is much better with the lid removed. Plus, you will like yourself more if you have to wrestle with the AC compressor from above with the lid removed. Trust me on this one.
  8. Glassman
    Glassman F1 World Champ
    I use jack stands even though I have a pit that I can stand up in. With the jack stands it hurts to be on your knees but the advantage is you can easily see where everything is at as far as marks and TDC etc. I wouldn't like to raise and lower every time I want to take a look..............which is often in my case.
  9. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I recommend removing the hood for the belt service. It will make your job a lot easier. With the hood removed you can see much better as well. You really need to have good lighting.
    Over the years I have performed the major service many times, removed and overhauled the engine and every imaginable repair without a lift. A lift is not required, but it may make some jobs easier.
  10. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    I bought a MaxJax 2 post lift about six months ago, before I got the 308. I've managed to get by, doing pretty much everything imaginable over the past 40 years without it but honestly I wish I had gotten one twenty years ago. It really makes a lot of things much, much easier. I don't need to do my belts yet but I am going to do the axle CV's and won't be laying on any cold concrete to accomplish it.
  11. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    Looks like a major isn't necessary at the moment. I looked at the service records this evening and a 30k service was performed about 15k miles ago. That being said, there are some oil leaks I want to investigate. Depending on what I find may help determine how deep I dig.
    I've been wanting to tackle the shifter shaft leak, but that may happen later. I know that repair wil be easier on a lift.
  12. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    The greater question is how many years ago was the belt change last performed? If more than 5 years ago, it's due based on age.
  13. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    Belt change was 5 years, so that is a given. I'm not completely familiar with what all is supposed to be done at each interval, but sounds like a belt change and a couple other items will be done. I shouldn't have to go off the deep end.
  14. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    I did my belt change on a 4 post lift. Most of what you need to do for the belts requires access through the wheel well. I used the ramp as a table to hold the parts as I took them off. That way they didn't get lost and I put them back on in reverse order. It's not difficult, just take your time.
  15. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    #15 Fairview, Dec 28, 2016
    I like my mid rise scissor lift for 308 belt changes. It gives really good access to the belt/wheel well area. I always remove the engine lid, too. It only takes about ten minutes and two friends or relatives to safely remove it.
    I don't currently have a Ferrari picture with the lift, but here is a current project so you can visualize the access and work area.
    Best of luck with yours!
    Jeff
  16. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    I go to every possible length to avoid removing the lid as I hate doing it. There is always risk of damage when removing/fitting it and getting all the shut lines all round to be absolutely OCD correct takes ages of faffing about.
    Using the guide pin holes its possible to get it roughly correct but a tiny bit of misalignment at the hinge results in a lot at the end.
    I dont see any reason to remove it for a belt change but for a valve adjustment or cam seals definitely needed.
  17. Rifledriver
    37,126
    It takes me 15 minutes to remove and replace the hood, that includes making space to store it. It is an easy one man job and alignment was done by assembly line workers much faster than that and quite well. I suspect others can accomplish it too. It is a waste of time and a clients money not to get it out of the way.
    Guide pin holes? Never used them.
  18. yelcab
    Nov 29, 2001
    13,598
    San Carlos, CA
    Mitchell Le
    That 328 lid is not a one-man job for me. I am not big. But it should be removed if you are gonna do anything serious.
  19. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Guess I have never really got the hang of aligning the lid quickly.
    Any tips would be welcome. Last time I did use masking tape to mark the outline of the hinge plates on the lid which helped.
  20. Rifledriver
    37,126
    It is really simple. I look at how it fits and move it in the slotted holes accordingly.
  21. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Me neither.
  22. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Haven't done it yet but I've been thinking there has to be a way to do it one handedly. When I removed the hood from my truck I just set a big empty cardboard box on the engine lowered the hood onto it then unbolted the hinges, the hood balances on the box and can then be removed. Could probably do the same sort of thing with the 308, maybe even make up a simple hoist to lift and store it as well.
    So any tips from a pro who's been doing it for years would be welcome.
  23. Archer911
    Archer911 Formula Junior
    Sep 26, 2016
    907
    New England
    Tim
    It took 3 of us yesterday to get the engine cover back on. If you fabricate a hoist it will have to hold the cover at an angle to allow you access to reinsert the bolts.
  24. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    I'd love to hear the fast and accurate way to remove and re-install the engine hatch!
    I disconnected the gas struts, then used a few old couch cushions on top0 of the engine/bulkhead to prop the hatch part-way open, so I could access the hinge bolts while the hatch was part way open.
    Same for re-installation of the hatch - propped it on a few couch cushions, then I could angle it and make the first pass at bolting it on. However, it took me quite a bit of fiddling, ie loosening and adjusting the hinge bolts, to get the gaps and alignment close to correct.
  25. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    Paul
    Yes I imagine the first attempt would involve some fiddling, there would be a learning curve. But if a systematic method could be worked out it would make working on the engine a lot more pleasant, although I do currently use the rear latch hooks to hang a four foot LED shop light which is kinda nice for illumination of the work area.
