Belt dilemma | FerrariChat
Belt dilemma
Discussion in '308/328' started by Steve King, Dec 30, 2009.
  1. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Well I just discovered that my lower timing drive pulley seal is leaking. This is the front (rear of the car) one so it looks like I'll be fixing this next month. So here is the what would you do question. I replaced the belts and bearings in Jan 2008 and only have around 4000 miles on them. So do I do new belts and bearings or just replace the belt on the bad side. Do I pull the bearing on the firewall pulley and replace it also. Just looking for some opinions here. I'm almost shut down here with weather so it's no problem with doing the work. I'll have to start getting the parts lined up so I'm trying to assess what I need. Also I understand there are 2 variations of the pulley bearing. I have a 77 GTB so is there a sealed bearing replacement or do you use an open cage bearing with a separate shield. I've seen the various posts on how to do the change and it doesn't look to bad so I'll give it a go. Oh last question has anyone used hex nut replacements to the special Fcar nuts. If so what did you use and were they nylok aircraft type. Thanks
  2. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    Preventative maintenance is always a good thing.
    Replace both belts and both bearings. You will sleep better at night.
  3. Steve Magnusson
    26,786
    I believe the change to the "inboard lip seal + outer sealed bearing" was done early in the 1978 US 308 model year on the F106AE engine family -- so your '77 probably has the (flakier) "inboard open bearing + outboard lip seal" arrangement (but it's not impossible to swap engines so you'd have to check).
    Even though the 5-8 drive side lip seal may not be leaking, if it's never been replaced, it's probably hard as rock -- how many total miles and have these areas ever been refreshed before? Also, I'd check the 5-8 side for excessive bearing play before deciding if it would be better to do both sides now, or just the 1-4 side now and do the 5-8 side at the next belt change.
    Based on your low annual mileage usage, even if replacing both belts, I'd reuse the tensioner bearings and keep the Jan 2008 date as the last major service marker (i.e., even if you replaced all the belt stuff, you are not putting in new cam seals, dist seals, etc. so not really a complete major service redo) -- JMOs.
  4. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,251
    Indiana/North Carolina
    JIM
    Belts are cheap and bearings reasonable. Well worth the $ for preventive maintenance IMO. You are there anyway and they are easy to do, so why not. :)
    JIM
  5. Steve King
    Feb 15, 2001
    4,367
    NY
    Thanks Steve. Engine is a 106AB so I would assume it to have the old style. I'll have to verify next month when I do the job. I was kind of going with replace both belts as well as doing the lower pulley bearings. I will check the tensioner bearings and if they still feel good I'll leave them in . Just a question here will the newer post 106AE bearing work in the earlier engines or is the cover design changed ? All of the cam seals are still good so I'll leave them alone. The car has 59K miles and the lower bearings have not been touched. Thanks for the input.
  6. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
  7. Steve Magnusson
    26,786
    No, not only is the outer cover changed, the internal gears+shafts are different as well.
    And ~33 years! ;) I'd say that you could do the outer bearings and lip seals on both sides without regret. I had the (better) later design, and the outer bearings were in pretty bad shape at ~90K miles -- so ~60K miles on the old design is not an unreasonable max life IMO (the radial load on the outer bearing in the early design is probably 30~40% higher than the later design). Please give us a data point when you do the work by guesstimating the radial play at the drive pulley before and after replacement.
  8. Lorenzini
    Lorenzini Karting
    Sep 3, 2008
    85
    Granite Bay, CA
    Kenneth D. Lawrence
    Replacing the cam drive bearings is a straight forward job, however you do need an internal bearing puller of yo can attempt to fabricate one. The out bearings are double sealed-not shielded where as the inner bearing run in oil and are open. When pressing the new bearing back in plase be cautious and do not press or tap on the out race as you will damage to the bearing. The Ferrari retaining nuts are a must and/or a suitable bearing nut. These nut are face controlled and exert an even pressure on the components, a nylock nut of any grade is not face controlled and will shorten the life of the bearings.
    How do I know this, I am an old time Bearing Engineer. Good luck kdl
  9. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    #9 ramosel, Dec 30, 2009
    Steve is spot on here. I just did mine earlier this month (with 50K on the motor) and the outer bearings were toast. Both were almost devoid of grease, both had significant discoloration of the balls and races due to heat and they had been so hot I had to scrape melted (nee COOKED) rubber from the bearing seals and the shaft seals off the inner snap ring when I removed it. The outer bearing seal was so hard and fragile, I got it off in many pieces. Pic below, keep in mind A) the cage has to be destroyed to used the blind puller - so I did that, the cage was fine when I got to it. B) this is the BETTER of the two bearings - this is the front. The other (rear) was practically bone dry and more heat discolored. To get back to your original title, change both belts... cheap insurance.
    Rick
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    It's easy to throw money at a ferrari. What's tougher is to throw it intelligently, and perhaps in so doing have a little more in the bank to pay for your kid's college educations (or your own retirement).
    As suggested above, based upon your low usage and recent repair work, I'd replace the belts and re-use the tensioner bearings assuming everything looks OK with the bearings (no oil/debris contamination, no excessive grease leaks, smooth operation and feel, no discoloration/blueing, no excessive humidity in storage, etc.).
  11. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    #11 Artvonne, Dec 30, 2009
    According to the eurospares website, the drive shafts are the same up through 1980, and from 81 up through the QV use a different part number. I didnt dig into it very deep, but assume the changeover occurred at the same engine serial number that other changes in the cam drive took place.
    Also, the bearings should be the same width regardless whether they are sealed or not? And if so, wouldnt the new style sealed bearing fit the older cover?
    And a technical question, what was wrong with the original bearing being open to engine lubrication that would have changed for the better having the bearing sealed? My experience has always been that oil bath ball bearings last far longer than sealed bearings, provided adequate maintainance is kept up. Could it be Ferrari saw how awfully Americans maintained things (like not changing oil often enough), and coupled with stricter EPA 5/50 emission warrantee and all, weighted the change?
    I would second the thoughts to just fix whats wrong as best as common sense dictates and continue on toward your next scheduled service. However, if you replace both belts, both tensioner bearings and both drive bearings now, you could conceivably reset the clock for 30K miles/or 3 or 5 years, and leave the rest of the engine alone for now. This all assumes the last service was thorough, along with degreeing, etc..
  12. Steve Magnusson
    26,786
    #12 Steve Magnusson, Dec 30, 2009
    Can't agree with this. The (euro) SPC labeled as "308GTB 1980" at eurospares shows that 4 different gear+shaft PNs were used up thru 1980: 104913, 109616, 112017, and 112856. The US 308 SPC 161/78 (1978) shows two different gear+shaft PNs specifically associated with this change: 104913 and 112017 (my guess would be that the additional PNs in the euro SPC are for the dry sump engine). Also, in the old design, the lip seal rides on an OD feature of the sprocket; whereas, on the new design, the lip seal rides on an OD feature of the gear+shaft -- so the shoulder on the shaft of the new design that contacts the inner race of the outer bearing has to be extended further away from the gear and the OD of this shoulder has to be a good quality surface for the lip seal to contact.
    The outer dimensions of the bearings are the same (so the bore size is OK), but the axial positions of the bearings relative to the gear are different so the grooves in the bore for the snap rings that retain the outer race of the outer bearing are in different locations.
    No argument that, if all things were equal, the splash lubrication would be superior. The problem is that the geometry for the older splash lubrication design is poor. The primary reason for the change wasn't to go to a sealed bearing -- it was to reduce the overhang distance from the pulley to the outer bearing. These sketches aren't exactly to scale, but they are in the right ballpark -- they illustrate the benefit (lower forces on the bearings for the same belt tension) of moving the outer bearing closer to the belt centerline (a secondary benefit is the radial play of the pulley is also reduced for the same amount of radial play in the bearings). Going to a sealed bearing was a (negative) compromise that they were willing to accept in order to improve the geometry and reduce the bearing loads, and, hopefully, improve the outer bearing (and lip seal) life:
  13. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    nice statics lesson Steve, i found myself summing the moments to check the reactions :)
  14. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Steve, Great job explaining and showing the differences!!
    Rick
  15. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    To: Steve Magnusson,
    As one who has paid the price (literally), seems as though they could have made the sealed bearings a larger diameter and "deeper". Comment?
  16. Steve Magnusson
    26,786
    Yes, but that requires a much more serious change to the outer casting (which takes a lot longer to implement and is much more costly); whereas, the change they made only requires a machining change to the existing casting (that can be implemented very quickly and lets you use the existing inventory of castings). Also, bigger is not always better -- even though the load rating will be higher for a larger diameter ball bearing, the ball speed can become a limiting factor.
    In fact, let me say a few words in defense of the original designer -- one problem is that manufacturer's bearing life calculations are typically based (and tested) on the bearing being fairly heavily loaded compared to its static load capacity (like a slow-speed wheel bearing). When you use these life calculations on a very lightly loaded ball bearing in a high-speed application, the resulting predicted life comes out to be a very, very long time. Consequently, even though the radial load on the outer bearing is 2X the belt tension with the old configuration, this life calculation still would still (wrongly) predict a very long lifetime for the outer bearing so I can understand why the original designer might have accepted this 2X higher load for the benefit of keeping the outer bearing splash lubricated (because the manufacturer's equations would still have shown a very long life at the higher load).
  17. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    All valid points. Thank you.
