Belt line molding removal. | FerrariChat
Discussion in '206/246' started by Tycho, Feb 28, 2023.
  1. Tycho
    Tycho Rookie
    Mar 11, 2008
    31
    I fear damaging the belt line molding as I am not sure how it is secured. So, please, how is that molding removed ?
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Which molding are you referring to? I do not know that the Dino has any 'belt line' molding so perhaps the naming is confusing us. Maybe a photo or a better description and we'll be happy to help
  3. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    This is not the Toyota zone
  4. Tycho
    Tycho Rookie
    Mar 11, 2008
    31
    To be more precise : The beltline molding I referred to is now properly spelled with one not two words. The expression beltline molding refers to a metal or synthetic material. It is called beltline because that’s approximately where it is located on the doors - beltline high.
    On the Dino GT the part is chromed metal. It is positioned on top of the door just next to the glass but not touching glass. It’s not the fiber sweep against the glass.
    You will notice on your Dino that the chrome strip shows no screws or rivets and is secured flush on the alloy or later on the steel.
    Prying seems to be almost intuitive but not close enough; that’s what I fear doing. Is it secured from the bottom by welds or what ?
  5. pshoejberg
    pshoejberg Formula 3
    1,822
    Denmark
    Peter H
    First time I ever hear that Belt line expression. Why not take a picture - then you avoid the guessing game and pictures says more than a thousand words. Anyhow, fittings on top of Ferrari doors in belt line height normally is riveted to the door on the inside. That means you need to dismantle the door, remove the glass and drill out the rivets.
    Best, Peter
    TTR likes this.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,220
    CT
    John Kreskovsky
  7. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    You have to remove the door panels and the glass, along with the vent frame. it's a slightly different process coupe versus spyder. That piece is riveted onto the door frame, the felt piece is also attached to the piece usually with small screws.
    Sergio Tavares likes this.
  8. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    As Jon and Peter have already said removal of this trim requires a LOT of disassembly. Dino door assembly is one of the most time consuming parts of working on a Dino so prepare for a job that will take many solid days of work to do.
  9. TTR
    TTR F1 Veteran
    5,889
    Riverside, CA
    Timo
    If the discussed item is aforementioned upper door edge (outer) trim molding shown in post #6, aren’t they usually polished stainless rather than chromed steel ?
  10. racerboy9
    racerboy9 F1 Rookie
    2,645
    I think the earlier Dinos were chromed brass and the later were stainless.
    TTR likes this.
  11. TTR
    TTR F1 Veteran
    5,889
    Riverside, CA
    Timo
    Thanks. Learned something today.
    I just assumed (yeah, I know), since they were manufactured by Scaglietti at the same time with 365 GTB/4s and all of them I’ve ever encountered/seen have been stainless.
  12. Tycho
    Tycho Rookie
    Mar 11, 2008
    31
  13. Tycho
    Tycho Rookie
    Mar 11, 2008
    31
    Exactly what I thought. I appreciate the confirmation. Thank you. By the way, a picture being worth a thousand words is as reliable as saying that truth lies somewhere in the middle of two opposing opinions. Or that there are two sides to every story - I guess that’s Yin Yang stuff.
  14. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Is this 246 gt or 246 gts?
    The gts seems easier to replace these
