Belt squealing noise... how many belts are there on the 360? | FerrariChat
Discussion in '360/430' started by elmani, Feb 3, 2010.
  1. elmani
    elmani Formula Junior
    Oct 7, 2008
    253
    austin Texas
    marc b
    hi guys
    i just got the timing belt changed a week ago... after that i noticed in the morning i hear like a belt squealing fo r like 10 to 20 sec and it stops. Could it be the main timing belt or other external belts like on regular cars... I never had the chance to look into that: how many belts does the 360 have?
    thx
  2. Oengus
    Oengus F1 World Champ
    r u sure its not the fuel pumps?
  3. Rifledriver
    36,769
    Squealing fuel pumps?
  4. Rifledriver
    36,769
    The car has a power steering belt, an A/C belt and an alternator/waterpump belt. The belts really need to be adjusted with an ultrasonic tension meter. The alternator belt adjustment is a fine line between not making noise at startup and destroying the bearings in the waterpump. People try and shortcut them all the time and your experience is one of the two usual results of that practice.
  5. RayJohns
    RayJohns F1 Veteran
    7,821
    West Coast
    Ray
    #5 RayJohns, Feb 3, 2010
    I have a Hz belt tension meter for sale - hint, hint :) I think it's still listed in Ferrariads.com
    I'll 2nd what Brian mentioned about the Alternator belt. That applies to all cars, not just the 360 - although I'm sure it's even more critical as far as the adjustment goes on a car such as the Ferrari.
    With regard to the alternator specifically, you have to keep in mind that the alternator is basically a motor that is putting out electrons instead of using them. There is an armature which rides on bearings or bushings inside the alternator. I don't know the specifics the Ferrari design, but the issue boils down to this: if the belt is too tight, the lateral force on the armature will destroy the bearings in the alternator. If/when this happens, typically the alternator will seize, which of course, is not good. When the alternator stops turning, usually the belt keeps going and is shortly after that destroyed. Again, speaking in general terms. I had this happen once on a Datsun motor that I built and it's no fun. Keep in mind, anything else powered on that same belt (such as a water pump, etc.) loses power. This can be a critical event to your motor. There are plenty of stories of people who lose an alternator belt and think "no problem, I'll drive home on the battery and fix it". However, if the belt also runs across the water pump pulley, then you are driving home with not only no alternator, but also no circulation in the cooling system. Bad idea.
    The line between too much lateral force on the alternator shaft (and thus bearings inside the alternator) and too little - which will often result in the belt squealing when cold - is a very fine line indeed.
    I would be very careful taking the car back with instructions to quiet the belt. If someone just adds tension to the belt without regard for the forces that it's applying to the shafts that the pulley(s) are attached to, you can end up fixing one problem and creating several more.
    One solution is to purchase some silicon grease (the kind used for brake pads, etc.) You can apply that to the belt and it will quiet things down for a few months at a time. It's not as good a solution as getting the belt's tension within specs using a sonic Hz meter, but it's one possible solution that I have used in a pinch (and while it's not a permanent solution to the underlying problem, it usually doesn't cause any harm either).
    Ray
  6. Oengus
    They do buzz a little, maybe the OP is confused.
    maybe I am :)
  7. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Whatever else, be assured that it's not your timing belt so you're not in danger of immediate destruction!
  8. elmani
    Oct 7, 2008
    253
    austin Texas
    marc b
    Thanks guys a lot... you saved me the time and hassle to take the covers out and check the belt myself... i understand that most probably the alternator belt needs a slight tightening which was my original guess, since the sound is similar to a BMW or Mercedes belt slip... i wanted to make sure that it is not the main timing belt that i am hearing... i will take the car for service as soon as i come back from my overseas trip.
    Apreciate it
    cheers
