Belt tensioner bearings - need/basis for changing? | FerrariChat
Discussion in '308/328' started by s219, Oct 5, 2021.
  1. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    So I am looking at a 328 to buy that has very good maintenance records with numerous belt changes over the years (last in 2021) but I saw no mention of the tensioner bearings ever being replaced anywhere on the engine (not in labor or parts listings on any of the comprehensive service bills).
    After looking in the manual I see there is a tensioner pulley for each timing belt, a tensioner pulley for the water pump belt, and a tensioner pulley for the AC compressor belt (the alternator belt is tensioned with the alternator itself and has no separate tensioner). So that's four tensioners and I am sure some of them have two bearings, in other words, a lot of bearings.
    I was under the impression this service was important, just based on word of mouth. But I looked in the 328 owner's manual maintenance schedule and it's not called for anywhere.
    I'd like to discuss this with the seller and his mechanic, but it would be good to have some background info since I'm otherwise ignorant about this. What is the basis for the frequent tensioner bearing changes I see mentioned all the time? Seems like this is routinely done when belts are changed or at least during the more major "30K" services, correct?
    thanks,
    219
  2. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    To be absolutely honest with you those timing belt tensioner bearings are pretty big, it's a wide belt, and they don't really have that much of a load on them. Even the belts themselves, on this engine there are two and they are pretty short because they have their own dedicated drive sprocket. So, in reality the belts are probably fine for 50,000 miles and the bearings 100,000 miles.
    But nobody is gonna tell you that.
    mike996 and Dave Bertrand like this.
  3. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    I replace mine every other service
    SAFE4NOW likes this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    The last 328 I worked on had the bearing grease leaking out all over the place. Will it last another 100,000 miles? Who knows but since I was in there anyway, they got tossed out and replaced with Hill Engineering Bearings. I know those last 10 years.
    Your money, your chances, your choice.
    Yo328 likes this.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    FWIW, belts degrade with time, whether running or not; bearings pretty much don't degrade with time. I replace belts based on mileage or time, whichever comes first and bearings based on feel. IOW, if the bearings turn smoothly/no play, I don't replace them. That is true of any bearing - whether it's a cam tensioner bearing or a wheel bearing! In my experience, bearings provide a rather lengthy period of roughness/noise long before they actually fail...:D
    I realize that others disagree but I do not believe in replacing components that are working fine. You can't break/strip/lose a fitting, etc if you don't take the item apart. :rolleyes:
    waymar likes this.
  6. Dr Tommy Cosgrove
    36,436
    Birmingham, AL
    Tommy
    I always thought the bearings were changed when the belts were, pretty much universally.
  7. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I think we're challenging that need right now.
    Most of us only put 5k to 10k miles on the car between belt changes which apparently is far below the service life of a bearing (although yelcab's grease comment is noteworthy).
    Certainly when belts are done professionally and the job costs $3k (or $5k) (or $10k) the $200 cost of the bearings is trivial. The new bearings provide risk reduction (or at least do no harm) with the cost being pasted onto the customer.
    A DIY belt change costs $72 and the risk stays with the owner no matter what is changed.
  8. Dr Tommy Cosgrove
    36,436
    Birmingham, AL
    Tommy
    I would not use a garage that charges or needs 20 hours to swap belts
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    "I always thought the bearings were changed when the belts were, pretty much universally."
    That does seem to be the case...
    But does anybody change alternator bearings/bushings when they change alternator belts? Does anybody replace their wheel bearings when they install new tires?
    Certainly they need to be checked for smoothness and appearance. In the case noted where a lot of the grease has leaked out is, of course, a concern.
    Interestingly, bearings can fail early due to too much grease. A friend was a supervisor in a Corning glass plant that was having trouble with bearing failure on one of their large machines. They called in a rep from the machine supplier and he discovered that the Corning techs were over-greasing the bearings during normal maintenance. They figured that MORE Grease must be better then the machine-factory spec which called for a specific quantity of grease that looked to them "too dry." But the excessive grease caused early failure. When they applied grease per the spec, the failures disappeared.
    Hey, maybe that tensioner bearing mentioned in post #4 was just trying to get rid of the excessive grease! :) Unfortunately, it could end up on the belts which is not the best thing for them...:(
  10. Dave Bertrand
    Dave Bertrand Formula Junior
    824
    Castle Rock, CO
    I agree, though belts degrade from use much faster than time, and I've never heard of any other manufacturer recommending such a short time interval for belt changes. It's typically something like 100,000 miles or 10 years for interference engines, which is an indication of how long they expect belts to last. Are the belts we use on Ferraris of lesser quality than those used on all the other cars in the world? Not likely. As for the bearings, you are right that they wear out slowly and provide plenty of obvious warning when they reach the end of their life.
    I think the practice wasn't challenged early on, and gradually became gospel. I don't think tensioner bearings need to be replaced every 5 years with the belts, but instead should be replaced as needed, with their condition being assessed at each belt change. it's my opinion that the adherence to the 5-year belt/bearing major service interval was borne more out of paranoia than common sense. I'm reminded of an independant Porsche tech's remark to me years ago: "Porsche owners love to spend money on their cars". If true, it's probably doubly so for Ferrari owners.
    Another thing to think about is that when you decide to sell your car, prospective buyers may be put off by the fact that you didn't follow the universally accepted guidance, unwarranted as it might be.
  11. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    I got some more records on the car I am looking at, and both timing belt tensioners were replaced in 2015 -- not just a bearing swap, the entire tensioners. Don't know why other than maybe the shop swaps assemblies rather than doing rebuilds themselves. That just leaves the other two tensioner's bearings not accounted for. I plan to ask about that during the PPI. Both look easy to do on my own if I decide to take care of it at the next belt replacement. Thing is, the car got all new belts in May of this year so it could be 5+ years before belts are needed again.
    I do agree with @mike996 that bearings will usually start making noise and/or showing some slop as a warning sign. The shop that worked on this car was thorough and wasn't shy about doing work for the previous owner, so I think they would have recommended those for replacement if there was an excuse to bill for it.
    The other thing I haven't seen on any records going back to 1999 is any work on the water pump. I frequently see that being proactively rebuilt on the 308/328 during major services, in some discussions. I've seen those fail before and they would also show some signs if there is any distress, usually leaking at the shaft seals or noise.
  12. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    Also, alternator was replaced in 2017 (old one wasn't charging anymore). So that takes care of that belt-driven accessory. AC compressor seems to be original but still working OK. They have gotten the system recharged every few years.
  13. Steve Magnusson
    26,825
    For those of us who actually drive their Ferrari = yes :)
    The Owners who (rightfully) have trouble with this decision are those who do the 1000 total miles in 5 years. In that situation, it's more about the grease life that you're comfortable with.
    GordonC likes this.
  14. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    You forgot the $100 coolant drain.
    Brian A likes this.
  15. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    857
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    It makes sense to change the tensioner bearings .Just had the main polybelt on a Bentley GT done .It’s Bentley lifed for 10 yrs .
    seeing as the whole front of the car has to come off inc rad swinging out , fluids drained .Think what needs to be dismantled to access a 308 motors belts , then the single £40 tensioner is a no brainier as the serpentine poly belt is £100 .
    It not the cost its more “ while we are in there “ .
    If you are a DIY er then skip the Ferrari tensioners and skip the Bentley tensioner .
    You can always another winters day “ dig in “ .Again !
    But if you are paying a guy shop Labour hrs ……..get it done .
    As said they are not catastrophic the Bentley squeals on cold start at tick over .When warm or revs the squeal disappears.You can put 10s of thousands of miles on them in this state .
    So you do get tell take sounds .
  16. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Yo328 and GordonC like this.
  17. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Unless you open it up, how would you know what it looks like inside? And if it looks like this inside, what would be your recommendation?
  18. 430tdf
    430tdf Formula Junior
    Aug 7, 2008
    281
    Canada
    Brett
    One thing to keep in mind is that if the tensioner bearing fails you're looking at 10k + in repair bills if not a new engine. With all the other bearings you're only replacing an inexpensive (in the Ferrari world!) part.
    GordonC likes this.
  19. Dr Tommy Cosgrove
    36,436
    Birmingham, AL
    Tommy
    If you are being told you need to replace the water pump with every belt change, you are either being lied to or you are dealing with a shop with zero experience.
    I have had this conversation many times.
  20. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    Well, as has been said many times, do what you are comfortable doing. If you believe the cam tensioners need to be replaced at a belt change, do so. FWIW, in my '89 328 manual Ferrari didn't call for replacing the tensioners in a belt service. Did they change that in a later bulletin? If not, when/why did this 'tensioner change as a normal procedure' begin?
  21. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    SO what are we looking at in that photo, bad bearings? I don't have experience with Ferrari water pumps but on other brands, when they fail it's either an impeller problem, a bearing problem, or a shaft seal problem. The last two you can usually diagnose without a teardown. Shaft seal is not catastrophic but bearing failure could be if the pump seizes up and the belt jumps off or self destructs. If an impeller fails usually that has different symptoms -- the engine gradually overheats from cold and you make a diagnosis by excluding the other simpler reasons then check out the pump.
    It looks like the Ferrari water pump is old enough to be using a good quality metal impeller, so I imagine that will outlast everything else. I once dealt with a failed water pump on a 1980s Alfa Spider where the impeller broke where it attached to the shaft (torsional failure of the metal, nice helical fracture caused by a defect in the casting). The only symptom was the engine overheating. By outward appearances the water pump was fine. Pulley still spun freely and smoothly, bearings still good, but shaft was not attached to the impeller anymore so it did not pump.
  22. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    #22 mike996, Oct 9, 2021
    I suppose that when you consider that, AFIK, the warranty on these cars was one year for the earlier models, 2 years for the later ones, there may be good justification for the view that Ferrari's choice of ancillary parts/equipment was...uhh...less than stellar! :eek: It's also well-known that Enzo didn't care a whit about the road cars. So they probably didn't spend a dime more than they had to for parts adequate to sustain that one/two year warranty. Therefore, better bearings/other parts in the various locations could certainly be a good thing. Once installed, whether those better parts need to be changed regularly - like the Hill bearings - is a different, and personal comfort decision. Normally, in the automotive world, parts that are other than routine maintenance are not replaced until there is a sign they need replacing.
    OTOH, my original 1989 water pump is still working fine. So the biggest problem might simply be lack of use if the cars aren't driven much. The worst thing for any mechanical device is to NOT be used. ;)
    My Hill bearings have a bit over 10k miles on them and were still smooth as silk when I replaced the belts a few months ago. Of course, 10,000 miles is nothing on a 'normal' car and if bearings had to be replaced in less than 100k miles, we'd call that a poor quality bearing/car. Go figure...:rolleyes:
  23. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    Are you being serious? You can't actually believe that crap do you?
  24. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,872
    Mike 996
    Are you being serious? You can't actually believe that crap do you?"
    I certainly do believe it.
    Enzo's view of Ferrari's road cars is well known and documented. He stated that he only made them to make money to finance the race effort; he didn't care anything about them and said so in those words (well, the Italian equivalent) on several occasions. ;)
    Re lesser quality ancillary parts, several well known Ferrari-trained techs that frequent this site have stated exactly that - that Ferrari sourced lower cost ancillary parts, not necessarily parts of the best quality.
    Just to emphasize, I'm talking about ancillary parts/systems, not the basic engine/drivetrain construction.
  25. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    What we are looking at is a rusted bearing from inside an old 308 pump. Unlike others, my feeling about water pump (on all my cars from BMW, Audi, Porsche to Ferrari) is that they are a maintenance items. That means they are replaced BEFORE they go bad and leave the car either stranded by the side of the road, or one of the girls I care about standing by the car with the engine up in steam and a rebuild coming.
    Rust comes from age, not mileage. Pick the age at the point where you want to replace the water pump and do that. For me, 10 years on a Ferrari water pump is plenty long for a $300 item. It so happens that coincides with every other timing belt jobs, how convenient?
    My labor is free to me so I am very liberal with what I replace. For example, my BMW 530Xi gets its entire cooling system replaced at 100K miles, water pump, thermostat, radiator, all coolant and heater hoses, coolant tank. That job is coming up again... I have driven BMW long enough to know that at 101K miles, the radiator plastic neck breaks. So I don't let it happen. The Porsche 997 that the wife drives also gets its cooling system done at 60 K miles. Simple, do that or a $25k engine rebuild.
    There are other things on a 308 that will leave you stranded and waiting hours for a damn tow truck. Don't let it happen to you.
