Belts and bearings | FerrariChat
Belts and bearings
Discussion in 'Technical Q&A' started by CarlH, Oct 1, 2006.
  1. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    Question on sources for QV belts and bearings. I checked Trutlands and they ask $375 for a set. SuperPerformance looks to get about $180 plus or minus for exchange rate. Are they selling the same make of part? If they are different, are the superperformance parts quality? Hate to pay 2X for no reason, but hate more to have a belt break.....
  2. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    What Ferrari are you researching for? £60+ P&P is the UK average for 308's
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I've picked up belts from www.evansauto.com very reasonable. I htink about $30/belt.
    I also picked up belts and bearings from T. Rutlands and didn't think it was even close to $375... maybe $225.... that was about 4 years ago though.
  4. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Superformance parts are top quality, I can highly recomend them
  5. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    Thats what I worked them out at for a Mondial or 308 Qv
  6. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    ALso as you are in the States you could try site sponsor Dan at Ricambi
  7. CarlH
    CarlH Karting
    Feb 5, 2004
    81
    MD
    Carl H.
    Thanks all - I will also try Dan at Racambi. I reciently purchased the incorrect water pump belt from them and Dan returned my call promptly and sent the correct belt before I returned the first one. Good service there.
    It was installing this belt that I noticed the tension on the cam belt to be rather loose. Only 5K miles on the cams, but seven years so time for a change.....
  8. racespecferrari
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    I'm 6 1/2 years on my belts but with about 2000 miles on them
