Bentley Continental Brakelight | FerrariChat
Discussion in 'British' started by drjohngober, Aug 14, 2009.
  1. drjohngober
    drjohngober Formula 3
    Jul 23, 2006
    2,040
    Cville and Gbury Tex
    Dr.John Gober
    The message center alert came on today saying brakelight out ( after carwash). Sure enough, my center LED brakelight not working now. Probably got water in it. Anyone have similar problem? Anyone replace themselves?
  2. JM4re
    JM4re Formula 3
    Aug 21, 2006
    1,022
    Nothingcouldbefiner
    JPM
    #2 JM4re, Aug 15, 2009
    Umm, I hate to tell you but if it is that huge LED strip over the rear window that you're referring to, that is not good. The light was originally intended to last the life of the car and I know it is not at all your fault, but as such they designed them to be in there permanently and are not easily replaced. Costs ~10k (yes I'm serious) to replace because they have to actually unseal the whole window and those seals can't be re-used. Then they break the window out to replace the light. Then they replace new window, new seals and re-seal it. Sorry to be the bearer of bad tidings.
  3. technom3
    technom3 F1 World Champ
    18,241
    Phoenix AZ
    Justin
    A friend of mines eventually dried out... and it started working again. the car washed do tend to kill them
  4. drjohngober
    Jul 23, 2006
    2,040
    Dr.John Gober
    Interestingly, mine appears to be working again this morning. Maybe they do tend to stop working after getting wet. For $10k, I think I will grab the blow dryer.
  5. JM4re
    JM4re Formula 3
    Aug 21, 2006
    1,022
    Nothingcouldbefiner
    JPM
    Excellent news.
  6. technom3
    18,241
    Phoenix AZ
    Justin
    awesome! glad it has worked out. i am not sure how many times it will survive that. you may want to see if there is something you can do to help ensure that it doesn't happen again. Such as making sure the car washers don't spray the rear window area with the pressure washer etc...
    I am really glad to hear it worked out...
    I will leave you with one thought... it wouldnt be british if something didn't go wrong when it got wet :)
