Bersa Guns | FerrariChat
Bersa Guns
Discussion in 'Other Off Topic Forum' started by venusone, Oct 10, 2010.
  1. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    The lacal gun shop is trying to talk me into a Bersa .380. Never heard of it. Feels good in the hand but I was really looking for a name brand.
  2. tblount
    tblount Karting
    Sep 29, 2007
    212
    Bersa is OK for the price, but definitely not the best out there. What are you going to be using it for? Concealed carry? Also keep in mind the .380 round is not the most powerful round out there and it is a little bit more expensive as well.
  3. Kds
    Kds F1 World Champ
    #3 Kds, Oct 10, 2010
  4. madmaxatl
    madmaxatl Formula Junior
    Mar 22, 2007
    687
    Buckhead, Palo Alto
    Don Johnson
    Depends on your price range and its intended usage. If you are looking for a reliable self defense gun for a relatively low price buy a glock. Keep in mind that the safety on a glock is on the trigger. If there is a round in the chamber and you pull the trigger it will fire, period. expect to pay between $400-500 USD
    Going up a notch the Sig P220 is a great gun. Reliable, easy to clean, very accurate and not to large. On the down side it's in .45 and as such it is not a gun for an amateur. It will take quite a bit of practice to become proficient. An entry level P220 is around $400 USD
    Finally the top of the line. My personal favorite and what I carry, the HK USP Tactical in .45. With well over 1,000 rounds its never jammed. It's extremely accurate, easy to break down and clean, less recoil than other .45's, great feel, perfect trigger pull, not too heavy, pre-threaded for a suppressor. Virtually everything about this gun is perfect. If you find it a bit large go for the smaller version the USP CT. For a new one expect to pay $1,100 USD
  5. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    #5 texasmr2, Oct 10, 2010
    From a law enforcement aspect aswell as from someone who has sold guns the Bersa .380 is a nice CCW. The aspect you must think about, and you mentioned it in your first reply is feel, and then decide what your price range is. Remember its mostly about shot placement and secondly about the number of rounds you have. Range time will be your best best friend.
  6. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,410
    SFPD
    Dirty Harry
    Reviews [The 15-rounder is a Thunder 380 "Plus"]
    2002
    http://www.gunblast.com/Bersa_Thunder380.htm
    2007
    http://www.genitron.com/rev-bersa-380/p2-bersa-380.html
    Non-dated
    http://www.chuckhawks.com/bersa_380.htm
    http://www.pistolguru.com/bersa-thunder.html
    Onward to a review about Thunder 380 Corbon being put through the paces with Corbon.380 DPX ammo.
    http://www.hipowersandhandguns.com/Bersa%20Thunder.htm
    From the above - the line; "My particular Bersa usually runs about 30 to 50 ft/sec slower than my Walther PP or FEG PMK 380 handgun" stood out, as I was quite familiar with the FEG PMK 380, which is quite comparable to the PP [Not PPK]. After all, it was through repeated reviews and extensive comparisons to PP that I acquired it to begin with. But, I found the FEG PMK had an annoying tendency to remind my hand it had a slide, and it has gone on to other hands to which the fit was best suited.
    - In a nutshell: As the tang & slide are well-positioned on the Bersa Thunder, if the grip suits you, you're all set.
  7. thecarreaper
    thecarreaper F1 World Champ
    18,056
    Savannah
    #7 thecarreaper, Oct 10, 2010
  8. texasmr2
    22,232
    Houston
    Gregg
    My "on duty" pistols are all Tuarus's, a PT24/7 Pro .40cal and a 111 .9mm.
    I have a Glock 29 10mm on the way for another duty weapon.
  9. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    #9 venusone, Oct 11, 2010
    Never heard of them but local shop is pushing. Don't even know how to spell the name. I was wanting a 9mm type simi auto. What is this gun?
  10. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,961
    Wellington, FL
    Duane
    Cheap Argentinian guns I think. For a few more dollars you can get a Springfield XD9.
  11. tblount
    tblount Karting
    Sep 29, 2007
    212
    There are responses in your other thread you started yesterday, why the new thread?
  12. tblount
    tblount Karting
    Sep 29, 2007
    212
    And it's Bersa. And I wouldn't buy one. You will be disappointed in their fit and finish, and performance for that matter. Ive put a couple hundred rounds through a couple of different Bersa's and they all had failures to eject too often. I wouldn't feel confident with one.
  13. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    Threads merged.
  14. texasmr2
    22,232
    Houston
    Gregg
    Nothing alittle gunsmithing would not cure on the ejection port and different manufactures loads perform differently and with each gun. Aswell lets not forget that the 'fit and finish' is less important to others than some but your insight is a great tool for reference. I'm currently saving up for my Kimber and I love them, top of my CHL and police academy class, but others have issues with them so it's a fickle area.
    Simply put range time and alittle studying will set one on the right path. I am no gun nut by far but I try to offer alittle 'newbie' style insight to those looking for a handgun. A helping hand from someone with experience goes along way.
  15. tblount
    tblount Karting
    Sep 29, 2007
    212
    I may be coming at this thread from the wrong angle anyways. The OP may just want a fun cheap gun to maybe get some trigger time and get use to how they work. And in that case the Bersa would fit the bill nicely. I was thinking she was wanting it for concealed carry. In that case a lot more gun can be had for not much more $$. Taurus has been really making a name for itself lately and a nice one can be had for about a 100 bucks more than the Bersa, and would require no work to get it to function flawlessly.
    What model Kimber are you going to get? They are a fantastic pistol. I am surprised you have heard people having issues with them. But then again in the world of gun nuts, its basically a pissing match between people that prefer one manufacturer over another. No one will ever agree on one manufacturer being the best.
  16. Il Vecchio
    Il Vecchio F1 Rookie
    Dec 27, 2007
    2,573
    Near Pasadena, CA
    Peter B.
    Um, I wouldn't post this in an unsubscribed thread. Just sayin...
  17. thecarreaper
    18,056
    Savannah
    #17 thecarreaper, Oct 12, 2010
    why. i can have silencers and machine guns where i live, legally. but thanks for caring. i dont keep the guns at my main house, either.
  18. Samimi
    Samimi Formula 3
    Oct 17, 2005
    1,699
    North of the 49th
    S.
    Does the silencer make the front end very heavy on the Glock 26?
  19. texasmr2
    22,232
    Houston
    Gregg
    #19 texasmr2, Oct 12, 2010
    My .40cal 24/7 Pro shoots low and to the left by about 3-4 inches yet my Millennium Pro 111BP-12 is very accurate. The 24/7 will soon be at the gunsmiths for the accuracy issue and a thorough going through.
    I used a Pro Carry I in the academy yet cannot decide between the Custom II Stainless,Pro Carry II or the Ultra Carry II. I should be recieveing my Glock 29 10mm anyday now and cannot wait to shoot it. One of my good friends has a Glock 30 and I was surprised at how well the gun shot as far as accuracy and distance. I got my CHL back in '07 with a Glock 22.
  20. thecarreaper
    18,056
    Savannah
    not "very heavy" but you do notice it. practice trains you to deal with it. Plus, it is utterly silent with subsonic 9mm ammo, i mean, you hear the firing pin, and the slide, and nothing else.
    suppressor is a YHM Phantom with 1 tablespoon of Teflon wire pulling gel for cooling and sound.
    ALL NFA LAWS APPLY.
  21. Ike
    Ike F1 Rookie
    Nov 4, 2003
    3,543
    I've got a bersa .380 that the gf keeps with her. I bought it when I thought I wanted a ppk as a carry gun, a gun dealer I trust told me to get it instead. It was cheap but has been more reliable than some of my higher dollar guns. Has always fed anything I put in it and is pretty damn accurate, easy to take down and clean and oil.
  22. thecarreaper
    18,056
    Savannah
    duh. too many cans its a YHM COBRA on the 9mm. i just got a Phantom for my .30 cals, so its fresh on my mind. sorry for the typo. i still would buy a Taurus or a used Glock over a Bersa. I dont like Beretta either. :)
  23. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    I have a Charter Arms 5-shot 38 that I got from my grandmother if you can imagine that. I'm thinking a Glock over the Bersa too. How can you not like Beretta?
  24. thecarreaper
    18,056
    Savannah
    the Beretta 92 Military weapon has a problem with cracked slides. Yet the Taurus m92, based on the Beretta design, does not have this problem. Beretta could are less if you gun breaks a year or two later. maybe the Beretta .380 or .32 is ok? Dont know, too small for a defense gun, and i am not a fan of 9mm either, i just own a few because mine are completely silent.
    Taurus has a no questions lifetime warranty. I have a very old, and suppressed Taurus M92 in 9mm that never, ever fails, and its very accurate. Some of the old Beretta guns from the 80's and 90's are "ok" but for self defense, i WOULD NOT buy one.
    The Charter Arms is a very fine piece, and sought after by collectors now. Revolvers are best if left loaded for long periods ( 3-5 years) over spring fed magazines.
    Thin Blue line in Garden City has a nice selection of Glocks. Tell Tony i said hi.
  25. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    The place I went to is on the corner of Whitebluff & MontgomeryXRoads in that little strip mall. They specialize in "custom" guns & sell on consignment. Will order new guns & customize for you. I’m looking to sell my Ruger Blackhawk 357. They have some really nice engraved stuff in there.
