Best 308 mods/tweaks? | Page 3 | FerrariChat
Discussion in '308/328' started by Birdman, Jun 23, 2006.
  1. Dr Tommy Cosgrove
    36,287
    Birmingham, AL
    Tommy
    what are the numbers on the boxes, US vs euro?
    I want to keep my eye out for some
  2. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    803A & 805A . I'm sure there is (was) a refurb service where you could send your old ones and get new ones back. Whether they could switch USA <-> EU I can't remember. If you go to a Euro setup, don't you need different the cams also, ideally?
  3. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    Euro model 308 big front spoiler. Most of my
    Mods are to the engine. The engine also features the “Hot-rod” P6 cams, four higher performance Weber 44DCNF carbs with 34 mm venturis; Euro 308 headers and a Tubi stainless exhaust, all putting the power to the ground through a lightweight aluminum flywheel with a new AP clutch assembly. The brakes and suspension are improved thanks to 355 front calipers and Koni coil-over shocks with adjustable spring collars, upgraded adjustable anti-roll bars, solid suspension bushings and Boyd 5-spoke 16″ dia. modular billet aluminum wheels with excellent Bridgestone Potenza 205 X 55 X R16 front and 245 X 45 X R16 rear tires. The engine idles like a *****cat at 800 rpm, cruises down the road happily at 2,500 rpm and pulls like a freight train from 4,500 to the 8000 rpm redline thanks to the 10.2 pistons, P6 cams and oversized Weber carbs.
    And most recently, an XDi ignition system
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,776
    Cerritos, CA.
    Paul is right, from the
    US: MED 805 A to
    Euro: MED 803 A
  5. dave80gtsi
    dave80gtsi Formula 3
    1,910
    Ohio
    Dave Meredith
    The above info is for the QV models.
    For the 2Vi models, the USA DigiPlex is 801 A, while the Euro version is 802 A, shown below.
    A 100% plug-and-play swap, could not be any simpler to do.
    Notable performance boost via the use of the Euro version, which offers better ignition advance and timing.
    DM
  6. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,141
    Mansfield, TX
    Ron
    I seem to recall that the US version can be converted to Euro specifications.
  7. ferrariowner
    Feb 21, 2014
    1,141
    Mansfield, TX
    Ron
    Best mod--Turbo
  8. SaratogaCA
    SaratogaCA Formula Junior
    Sep 11, 2016
    319
    Saratoga, CA
    Sam T.
    A minor mod, but will give you great satisfaction: Replace the plastic clock lens with a glass lens. The original plastic lens invariably gets cloudy with passage of time. The glass lens, which is about $80 or so, does not.
    - Sam in Saratoga
    Crowndog likes this.
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Thanks for reminding me. The crystal for the clock I started back in 1982. I made up instrument crystals for many exotic restorations. Turned it over to Unobtaniumsupply and he produces a quality product.
