Best Battery Tender? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by 4RE886, Jul 11, 2009.
  1. 4RE886
    4RE886 Formula 3
    Feb 10, 2009
    1,184
    California
    Bob
    #1 4RE886, Jul 11, 2009
    Going to buy a battery tender - does anyone recommend one vs. another? I keep on seeing Deltran as a popular battery tender brand? 12Volt vs. 6 Volt? Thanks in advance!
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #2 Wade, Jul 11, 2009
  3. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    I've had very good results with the Deltran "Super Smart" battery tenders. Good warranty (something like 10 years?), decent price, and seem pretty reliable. As to 12V vs 6V - which you get depends on what kind of electrical system your vehicle has...
  4. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,599
    Gates Mills, Ohio
    Jon
    I've been very happy with Griot's Battery Manager Junior for a couple of years. It's the small one that plugs into the lighter socket. I like it because it has the lights to show you when it's charging versus simply monitoring, and it's small.
    It may be made by Deltran for Griot's, not sure.
  5. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #5 Spasso, Jul 11, 2009
    I have no problems with the Schumacher 1.5 amp tender on mine, at a fraction of the cost of the ones previously mentioned.
    It comes with a quick-disconnect plug you can pre-wire to the battery so the clamps shown are not required. Run the plug outside the battery box off to one side. When the time comes just set the tender on the floor and plug in. The electronics are the same, the principles are the same. It has the "Float" feature as well. Three indicator lights, Green=Float, Red=Fault, Yellow=Charging
    30.00 or less
    If your car is 12 volt you use 12 a volt charger. A 6 volt charger would be a waste of time although this charger has both options.
  6. jasonporsche
    jasonporsche Karting
    May 7, 2007
    192
    auburn, al
    jason gautney
    I to am a fan of the good old walmart schumacher battery chargers and tenders. I had one that I paid no more than 25 bucks for and it works great, never had a problem.
  7. tazandjan
    39,182
  8. stuckinkuwait
    stuckinkuwait Formula Junior
    Jul 25, 2004
    630
    Northern New Jersey
    Lenny S
  9. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Good info, perfectly timed for me.
    PDG
  10. donv
    donv Two Time F1 World Champ
    26,136
    Portland, Oregon
    Don
    I have Deltran battery chargers. You can often find them on sale, they're not all that expensive.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #11 Wade, Jul 11, 2009
    I'll say... thanks Taz
    BTW, what's a Rocket Scientist doing in Albuquerque? I thought they were all at WSTF ;)
  12. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Deltran Battery Tender here too. Been using them for years with not one issue.
  13. tazandjan
    39,182
    Wade- AF Research Lab is here, as are Sandia and (90 mins away) Los Alamos National Labs. Lots of high tech in NM, including the first commercial space port under construction as we speak, and WSMR, which you mentioned.
    Taz
    Terry Phillips
  14. JCR
    JCR F1 World Champ
    10,921
    H-Town, Tejas
  15. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    This is the one I have, and it works fine. I don't use the clamps though, I have a separate piece bolted right to the postive feed on the right side of the engine. I will take some pics tomorrow and post.
  16. Jackmb1
    Jackmb1 F1 Rookie
    Dec 27, 2005
    3,329
    +1, works well for me.
  17. 4RE886
    4RE886 Formula 3
    Feb 10, 2009
    1,184
    California
    Bob
    Thanks guys! As always you guys come through everytime. I just purchased a Deltran battery tender online.
  18. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
  19. ENDOSURG
    ENDOSURG Karting
    Dec 9, 2008
    70
    Massena,New York
    Vijaykumar Mandalaywala
    It works very well. It came with my f430sp.The car end of the plug in wire is different.It plugs in under the passenger side dash/glove compartment close to the door.The light cycles goes through from red to green .It repeats itself.
  20. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    WalMart carries a battery charger called "Smart Charger" that blows away the battery tender IMHO. This charger will detect defects in batteries, state of charge and health of the battery on top of that it is quite quick in bringing up a low battery.
  21. Nero308
    Nero308 Karting
    Jan 2, 2004
    190
    NorCal
    Yoshi
    Have you used or heard of "Save A Battery" by Granite Digital? http://www.saveabattery.com/ Any information please. How does this compare with the Deltran Battery Tender?
  22. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    #24 410SA, Jul 13, 2009
    Deltran make a couple of versions - a regular that charges at 1.250 A and a Jr. version that charges at 750Ma
    I have both kinds and they work just fine. The Jr's work great on older cars with smaller batteries and the regular ones are suitable for modern cars that have huge batteries.
    You can find them online really cheap.
    The Ferrari factory one made by CTEK is simply too expensive IMO for what it does. The Deltran is all you need
  23. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    #25 miketuason, Jul 13, 2009
