Best Brand of Fuel Stabilizer | FerrariChat
Discussion in '360/430' started by andrews1958, Oct 20, 2013.
  1. andrews1958
    andrews1958 Karting
    Apr 29, 2013
    166
    Maine / Namibia
    Myself and others will be storing our Ferraris shortly for the winter. What is the best name brand you have used as a fuel stabilizer for a 360?
  2. luvair
    luvair Formula 3
    Jun 4, 2005
    1,596
    My preference is StarTron for long term storage. Had good results with StaBil Marine too.
  3. Xcheckme
    Xcheckme Formula 3
    May 10, 2011
    1,682
    Tampa Bay
    Lukas
    I've used this for years with great results in my boats. You can get it any any boating supply store (west marine).
  4. jpk
    jpk Formula Junior
    StaBil makes a marine and an automotive fuel stabilizer. I use the marine in my boat, the automotive product in my car. The auto version has the red label.
    I've also used Ford Motorcraft fuel stabilizer and Lucas Oil fuel stabilizer. I generally stick to StaBil because it can be purchased in larger bottles. I get the Ford stuff at a nearby dealer as my second choice. The Lucas product is overpriced and I don't think I will use it again because of that.
  5. JSP
    JSP Karting
    Oct 5, 2013
    161
    Texas
    Steve
    StaBil marine in non ethanol gasoline for me.
    Googled "non ethanol" gasoline and found several nearby sources; have been using it for almost a year.
  6. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    #6 bisel, Oct 21, 2013
    You can acquire StaBil at Home Depot 32oz for $12. There are other alternatives and some use less to treat the gasoline so claim that more cost effective, but all will do same thing. If using Sta-Bil, you only need 12 oz to treat a full tank of gasoline in a 360. So will cost you less than $5
  7. star4747
    star4747 Formula Junior
    Dec 28, 2010
    363
    Midwest - USA
    Rick
    StarTron, I run it in all my watercraft (4) and have run it in 3 different Ferraris. I live in the Midwest US so everything gets stored in the winter. Never an issue. Available at AutoZone. Do a google search and read up on it...
  8. spooky
    spooky Rookie
    Mar 14, 2010
    29
    What is a "fuel stabilizer"?? Never heard of this.
    Is that really needed?
  9. jpk
    jpk Formula Junior
    It prevents gasoline from going bad. US gasoline has a surprisingly short shelf life (think gallon of milk), primarily due to the 10 to 15 percent ethanol blends that are mandated. If you leave the gas in your tank for six months, you are likely to find that it does not burn very well and your engine hates it. When I was a little kid forced to do chores, I learned this as my lawn mower ran horribly one season when I used a tank of gas saved from the previous summer. (My dad didn't believe gas could possibly go bad and blamed me for messing up the engine.)
    Anywhoo, you do not want to keep the same gas in your car for more than a few weeks without stabilizer. Stabilizer will help prevent your fuel lines from going bad, keep gunk from forming, and fight moisture buildup that could cause internal rusting. (Fortunately, the 360 engine is mostly aluminum, but still.)
  10. 9650max
    9650max Karting
    173
    StarTron is the answer. Defeats ethanol problems in gas. I use it in small gas engines that sit eight to ten months between uses and don't have any issues. Also use it in Ferrari and other exotics to protect the fuel system. A local motorcycle dealer went from numerous fuel issues over the winter storage period to no issues after using StarTron.
