Best Color For XPEL? | FerrariChat
Discussion in '458 Italia/488/F8' started by FFan5, Jan 17, 2021.
  1. FFan5
    FFan5 Formula Junior
    Jul 7, 2018
    550
    I have a white car, and you can see in the picture that the white paint is quite a bit brighter than the two year old XPEL. The car had this issue when I purchased it, and I immediately removed all the old PPF and put on the latest. Every time you talk to XPEL, they claim they've "fixed" this problem in the latest version. And while the film isn't yellow, it is not the same color as the paint.
    I've had a grey car before that looked just great covered in XPEL. Is the problem the white paint? Which colors would look good even as XPEL ages? Anyone have five year old XPEL on their car and it still looks invisible next to any unprotected paint?
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,732
    Just East of Weird
    Bob
    I had Xpel put on 2017 MB SUV and it doesn’t look like that. You can see the line at the half hood mark but overall it’s clear.
    Sent from my iPad using Tapatalk Pro
  3. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    If u don’t wanna see those precut line. You need to shop around for installers in your area. Some does amazing work for custom cut ppf work that wraps around the edges make it seamless on exterior.
    Boomhauer, jm2, ShadowLAP and 2 others like this.
  4. Thecadster
    Thecadster F1 Veteran
    7,644
    Terrible PPF install. Those seams could easily have been obscured. Also, the edges can be cleaned to standout less. Just mash a wet microfiber towel and rub along the edge. You would be surprised how much of that crud will come up.
  5. FFan5
    Jul 7, 2018
    550
    I get the install could be a LOT better. I did get what I paid for. However, the film itself is not aging well on white paint.
  6. Gh21631
    Gh21631 F1 Veteran
    9,143
    East
    #6 Gh21631, Jan 17, 2021
    STEK is our preference. It is coated and there isn't too much adhesive so it won't pull paint. The finish is clear and it lasts very well. They also have a satin, black and white ppf.
    SLDriver and Thecadster like this.
  7. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,642
    AUSTRALIA
    ANGELO
    You are seeing it because of the job with the gaps. But more likely because of the dirt edge. Remove that and you will most likely not notice it.
    IMO get a ceramic coat done again :) as that WILL clean up the edges.
  8. pninja005
    pninja005 Formula Junior
    Nov 10, 2010
    604
    Europe
    Do you really need to xpel your car? I've never done it in the past and I sure have some stonechips but..
  9. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    Yes. Then you won't have stone chips.
    Boomhauer likes this.
  10. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Lol. And yet people keep saying 3M and Xpel don't get "yellow".
    Get Suntek. Imo the most clear of the PPF's.
  11. soulsea
    soulsea Formula 3
    1,387
    29464
    So a couple of things to note here ...
    - Yes precut ppf is never going to look as good as custom installed one, especially on a white car where dirt gets in the edges (impossible to get that cleaned without pulling the film btw). However, you better have full confidence (and more disposable income) in your installer if you go custom, cause in questionable hands that razor can do a LOT of damage.
    - Custom or precut installation has nothing to do with film quality and discoloration. Yes you might see it more on a white car with precut film because you have available contrast, but the same discoloration would happen even if it were a custom instal, you just wouldn’t be aware of it unless you were parked next to an identical color car without ppf.
    As far as which colors work best with clear ppf, I would say that lighter colors tend to show less imperfections such as slight creasing. Black for example is generally the hardest color to wrap because it will show every minute imperfection in the instal. The lighter you go from black the less that is the case. Conversely the lighter the color the more the discoloration will be visible.
    Personally, I would do custom cut on a white or very light colored car and precut on any other color if for no other reason that the trapped dirt at the edges that drives me crazy.
    As far as which brand, I usually don’t care, I tend to focus more on picking the installer and use whatever film they use. If it does discolor it’s covered under warranty.
    jm2 likes this.
