News
Best F1 Pump Protection
Discussion in '360/430' started by lkstaack, Mar 19, 2021.
  1. lkstaack
    lkstaack Karting
    191
    San Diego
    Lars
    What do you think is the best way to protect the F1 Pump?
    As many know, the F1 Pump Relay is prone to failure. I believe this is because the F1 pump occasionally calls for more power than the 30A relay can reliably provide. The relay eventually wears out, causing the expensive F1 pump to run continuously until it overheats. Some of those with F1 transmissions will replace the relay prophylactically every other year or so (cost about $8US). It’s an easy replacement.
    Another option, as described by Aldous Voice (aka “voicey”), replaces the regular 30 amp relay with a 50 amp Challenge Stradale relay and socket (cost about $25US)
    https://aldousvoice.com/2015/10/15/ferrari-360-f1-relay-upgrade. Not only can this relay handle more power, it switches .5 ms faster. This is a relatively easy and inexpensive solution, though it requires rewiring of a relay socket. I haven’t read any first-hand accounts of those who have done so.
    One final option I'm aware of is purchasing and installing the Scud Ing Swiss “Smart EMT F1 Relay ECU” (about $235US) https://www.scuding.com/Shop/en/ecu-solutions/101-smart-emt-relay-ecu.html. Scud Ing Swill claims improved performance and reliability with this solid state device over a mechanical relay. They assert that mechanical relays can be harmful to the TCU due to power spikes, with a 50A relay potentially more dangerous than a 30A, but their solution is safer for the TCU, provides variable power up to 250A according to the demands of the pump, and is quicker. It is also plug and play, plugging directly the 30A relay without any rewiring. I have read a couple first-hand accounts about this device, all of them positive.
    So, I request that those who have used one of these three options chime in with your experiences and recommendations for saving the F1 pump.
  3. Jb-Slow
    Jb-Slow Karting
    May 11, 2020
    87
    I have the Scud ing smart relay, I didn't have a problem before install and I still don't after, so..... Yeah. The little led monitor thing is cool though, having a little advanced notice will be cool if something ever happens.
  4. Skidkid
    Skidkid F1 Veteran
    Rossa Subscribed Owner
    Aug 25, 2005
    6,732
    Campbell, CA
    John Zornes
    Your failure drive is kind of wrong but the conclusion is correct. I think you stacked them up pretty well. Honestly, 50A vs Scud Ing Swiss is probably a push for reliability. One is easy to install costs a bit more; the other is cheap but a bit more work. Pick one and go.
  5. kes7u
    kes7u Formula Junior
    Oct 18, 2017
    762
    Shorewood, MN
    Kevin
    In my opinion, the best way to go is the solid state device, the Scud Ing. I chose to go with the one without the blinking and beeping. I just wanted it to function as a plain old relay.
    Kevin
  6. tazandjan
    33,717
    There are upgraded 30 amp relays, too. I have had one in my 575M for 10 years with no problems.
    Skidkid and flash32 like this.
  8. Extreme1
    Extreme1 Formula Junior
    Jun 27, 2017
    514
    Santa Clarita, CA
    Taz, can you post a link for the upgraded one?
    Do you happen to know if the 2009 MY came with an upgraded one?
  9. tazandjan
    33,717
    #7 tazandjan, Mar 19, 2021
  10. lkstaack
    lkstaack Karting
    191
    San Diego
    Lars
    Even back in 2010, Juri reported that the Tyco V23134-B57-X266 "was produced by Tyco for a specific manufacturer and is not sold via electronic parts distributors or from Tyco directly".
    BMW Part # 61-36-1-393-403 cross-references to V23134-B57-X152.
  11. tazandjan
    33,717
    Lars- Yup, but there is one (-X266) in my 575M. Bulletproof so far.
  13. Extreme1
    Jun 27, 2017
    514
    Santa Clarita, CA
    Thanks Taz, my car is a 2009, so I’ll just stay with what I got until there’s a problem.
  14. wbt
    wbt Karting
    Nov 28, 2014
    162
    New Zealand
    I replaced the original grey relay with the 430 red version. I fitted a new relay socket of correct size (very easy with correct crimp tool) and added flyback diode protection across the motor terminals and the relay coil. With the flyback affect suppressed, sparking across the relay terminals is removed therefore almost no risk of the terminals welding themselves shut (which causes the F1 pump to run continuously). 3 years later with no issues.
  15. AandSC
    AandSC Karting
    225
    Jax, FL
    Allen
    I went with the Scud Ing Swiss and have been happy with my decision. No worries and notification of any issues you might not otherwise be aware of.
  16. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,461
    Uk
    Out of interest does someone have a pic of the location of the F1 pump relay.
  17. Flea7
    Flea7 Formula 3
    Rossa Subscribed Silver Subscribed Owner
    Feb 25, 2010
    1,226
    Seattle WA
    SKIM
    I like to keep it simple. Upgraded to Juri pump motor. 50amp fuse & 70amp relay.
  18. lkstaack
    lkstaack Karting
    191
    San Diego
    Lars
    Select the Scud Ing Swiss link above. They have pictures on the site.
    Sent from my SM-G781U using FerrariChat.com mobile app
  19. lkstaack
    lkstaack Karting
    191
    San Diego
    Lars
    Did you get upgraded components from Juri's Ebay site?
  20. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,226
    Seattle WA
    SKIM
    Just the pump motor with the heatsink. I sourced the 70mp relay (which is used for land rovers) and a 50amp fuse.... These are cheap.
    In my opinion, the Scud ing system is overkill. Just maintain/service your system and you won't have issues.
  21. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,226
    Seattle WA
    SKIM
  22. Snapshift
    Snapshift Karting
    160
    Centralia IL
    Lyle D. Pahnke
    I use the Scud ing Swiss relay F1Pump relay monitor system version 3 with the monitor lights. Kinda reassuring that it is quiet and always showing a green LED. Simple to install but I like the simplicity and peace of mind. So far, no F1 issues. May be overkill I don't know but if it saves the F1 pump from self destruction it probably will have paid for itself.
  23. becausephilchow
    becausephilchow Formula Junior
    Sponsor Rossa Subscribed
    Aug 26, 2016
    496
    Hong Kong
    I have the Scuding Solid State Relay. I chose the basic one, because I was never going to look at it anyways, haha.
    kes7u likes this.
  24. captglen
    captglen Formula 3
    1,756
    West Palm Beach, Fl
    Glenn L.
  25. honda corse
    honda corse Karting
    Jul 20, 2011
    57
    Vancouver BC
    Mark
    +1 for scud Swiss
    I had it installed to diagnose a shifting issue when the car was hot. I used the error codes to chase down the issue to a faulty accumulator. It works as advertised, really nice product.
  26. nickorette
    nickorette Karting
    212
    Toronto
    Use the scud inc. Have it hidden in relay box and set to only make beeps if there is a problem
  27. catdog
    catdog Karting
    Aug 18, 2010
    147
    Hi,
    I got the scud ing. relay for my 2007 f430 and it seemed to make the car shift slightly better but it gave me a warning sign and actually the car failed two weeks later. I changed the accumulator tank and it ran fine for a while but I went back to the original relay. 1 month later my F1 developed a recurrent fault that the local F1 dealer couldn't diagnose and I had car modified to manual transmission by EAG.
    I got another scud ing relay for my 2009 Maserati GranTurismo S and again seamless install but got a transmission fault signal 2 weeks later and had to switch back to stock relay. Car drove perfect with no F1 issues for another year until I sold it.
    Both felt great with a subtle improvement in overall function. The quality of the manufacturing and support is excellent. In my case the underlying F1 hardware may not have been perfect so the Scud Ing relay made things difficult, though it may have helped if I had an excellent F1 mechanic available to troubleshoot.
  28. kes7u
    Oct 18, 2017
    762
    Shorewood, MN
    Kevin
    Water under the bridge at this point, but perhaps you should have purchased the basic version or turned off the notifications, thus simply using the unit as a solid state relay. Its not clear to me why you had to change back to the stock relays because the Scud Ing was giving you an error notification? The relay would still have functioned normally, and changing back to the stock relay would not alleviate whatever underlying problem the Scud Ing was indicating.
    Kevin
